Hi All,
Had my fault codes read today for both the CEL and the Airbag light (thanks Todor!) and I believe this is what they are:
Airbag
02 18 03
Section 02
18 - Seat Occupancy Detector, Passenger
03 - Supply Voltage
I read this as a bad Seat Occupancy Sensor. Is this the right assumption? I assume that the 03 code is linked to the seat occupancy failure.
CEL
P0446
Evaporative System Monitoring for M52 TLEV Vacuum type only.
P0446 - shut off valve stuck closed
What is this? Ideas?
EDIT: I did some more searching.. http://forums.bimmerforums.com/forum...d.php?t=241612 and http://forums.bimmerforums.com/forum...e+stuck+closed.
I think i have PO446 squared away too.. thanks to the good ol' search button.
thanks
Tim
