After replacing the '92 325 motor(non-vanos) in my 325I with one from a '93(vanos), the check and check engine lights are on. It was an automatic and I couldn't get 1st gear to work so I did the 5-speed conversion, thinking the CEL would go off then. It didn't. Runs pretty good but idles @1400rpm. Any ideas why? ( I need it to be fixed in order to pass emissions.) It has a small issue with erratic idle but not bad.
Do the stomp test and see what the issue is
2001 E53 X5 - 5.3 Procharged, 4L80E RWD, Brembo, 20" alloy, EBC race, Forge, A2W intercooled, Alcantara interior, 3.62 LSD and more!
2005 E53 X5 - 6.0TT, 4L80E RWD, 20" alloy, EBC race, Forge, A2W intercooled, Alcantara interior, 3.62 LSD and more!
1996 E36 335ti - N54b30, A2W intercooled, ZF 6speed rwd, 4.10Lsd, Speedline magnesium rims, Brembo, S55 exhaust, 245/40/17-295/30/18, idrive, Forge, logic 7
1999 E36 360ti - 6.0, ls6 springs, ls6 cam, hardened pushrods, trunion, racing baffle, t56, ls7 clutch, m3 brakes, 4.10lsd
Did that and it just reads "input time". However, the check engine light went throught some cycles; blinking once, 6 times, and two times. I tried it keeping my foot on the pedal after the last stomp, and by letting the pedal return; both ways. Which is the correct way? Do I need the onboard computer from a '93 5-speed or is it the same as the '92 automatic? Would it possibly be the TPS?
If the TPS was faulty, you couldnt do the stomp test at all, so if you can initiate it, then the TPS is fine. Do the stomp by holding the pedal to initiate it and stomp again once one code is read to get to the next.
Thanks BB. I'll try that. {I noticed that you have an M-50. I have an M-50 block from my '92 that apparently had a blown head gasket. (The head was missing when I bought the car.) The block is complete except for the head and such things as alternator, p.s. pump, fan, A/C compressor. It seems to be good. What is it worth roughly?}
1999 ///M3 TiAg | Heated Power Vaders | DDM Projector36 5000K 55W HIDs | DDM 3000K 35W HID Fogs
DDM Smoked Corners | DDM Weighted Shift Knob | K&N CAI | Mishimoto AL Rad w/Zionsville AL Shroud
Stewart HiPo Water Pump | Samco Hose Kit | 16" SPAL Puller Fan | Viper 5701LE Security
E36 OBC is now open! Join the effort: BF.C Thread | openOBC Wiki
Washedit1 by thedude60526, on Flickr11/10's Racing
94 325i #36/64 TEAM PENISTON OILS/ LARSENS BISCUITS
OK. Just found the full instructions from "Pelican Parts". Makes sense now. For example, if it flashed 1-2-6-2 then it would be a problem with the idle speed actuator.
The stomp test went as follows: Check engine flashes once; then once; then twice; then once; then 6 times. I'm assuming the first flash is just for fun and the 1,2,1,6 is the code. Repeats in the same way.The Pelican info states that 1216 refers to the throttle potentiometer. I'm guessing this means the three terminal TPS. I replace the part with used twice and still have the CEL. I guess the next step is to run tests on the TPS?
