Preliminary investigation question.
If I do a LS swap, can the ABS system work stand alone? I do not need or want to use the DME/adaptor setup. The car is track only an I would prefer to remove all the harnesses and rewire only what I need.
Is there a stand alone aftermarket ABS controller that won't rip the budget?
Dan "PbFut" Rose
The abs will work fine without the DME, no standalone system needed.
Wait, I didn't need to rewire my ABS when I lengthened(sp?) it?
If it's got wires, then wouldn't that mean that it needs to be wired up?
NEW HEART
If you can't see the future, then you're not driving fast enough
If it has Asc, I recommend swapping to a limited slip rearend from a earlier 3 series, asc will not work. But you can have working abs. Well the good news is new age is working on making the dsc work with ls2 in our e46 kit, so we have no more problems like this .
ShaggsM3 your all set with a 95, your abs will work fine.
