how do you get rid of that sun baked stuff.
my spoiler has some sun sunburn on it and it looks like (correct me if i am wrong) the clear coat is kinda flaking off. I can actually use my fingernail and flake it off.
thanks in advance.
chris
Have anyone used the 5 star shine formula? like it isn't wax, it is used by Nasa/Navy and so on? I like to get my car clean again just wanting to see what the best product is out there.
"To make dreams come true, the first thing you have to do is dream... Peace & Love" - Nacho
I've had that happen before. The loop in microfiber towels tends to get a death grip on little wood chips...the only solution is to sit there and meticulously pick out each piece by hand.
I've got an alpine white 325is thats starting to show its 310k mileage. Overall the paint is in fairly decent shape but i would like to get rid of the swirl marks. I've never done any paint cleaning other than wash/wax/hand polish. What would be the best product for me? Preferably something that i cannot mess up my paint with.
what is the best product to use on my wheel?
Maya STM, Polished Lip with Clear Coat...
I also have some scratches on there from when i wiped them down... there were some small pebbles on there.... scraaaatched them....
Mother's suggested a their Plastic Polish.... and their powerball w/ scratch remover compound... i just want to know if this is safe, and if there's another product recommended....
another person also suggested using Rejex? apparently used on airplanes and stuff... nothing will stick to it...
please let me know if you can help... thanx!
I know I have a separate thread for this, but I thought I would post it here as well. Hope you don't mind.
I'm looking for some recommendations for a 2 hour level of detailing, something along the lines of washing, claybaring the more necessary areas (grille, mirrors, spots), and a single coat of wax, polish, or maybe some combination. I'm sorry if the idea of a 2 hour detail is considered a half-ass job, but seeing as I haven't waxed this car EVER because I can't find the time to commit 5-8 hours, I thought I might be more realistic. The 2 hours doesn't have to include the interior, because I can typically devote an hour once a week to vacuuming/cleaning the interior at a separate time.
01 330Ci 5spd / 07 Honda Pilot EX-L
Will read/reset SRS codes in South Florida for beer money
That should work well. Take a look at Mothers PowerBall Mini for tight areas.
Since wheels get so hot, I would suggest using a product designed for wheels that is designed to take the heat. My choice would be DP Wheel Glaze.
Using a machine polisher like the Porter Cable 7424 or the Flex XC3401 will save you lots of time when it comes to polishing and waxing and they will provide better results than doing by hand.
Keep in mind, I would spend more time if it was possible. If I was pressed for time and only had 3 hours to work on your car's exterior, this is a possible scenario:
Clean wheels, tires, wheel wells 30 minutes
Wash and dry car 30 minutes
Detailing clay 30 minutes
Tape off all trim 10 minutes
Machine polish 45 minutes
Apply wax 35 minutes
Last edited by Matt@Autogeek; 11-18-2008 at 09:33 AM. Reason: Automerged Doublepost
thanx for your help, Matt!
I recently bought myself a 95 325i, it's a forest green color, but it's got some scratches on it and because of the dark color they're very noticable, whats the best way to get rid of them or cover them up?
^ Depends what kind of scratches. Light stuff, just use one of these detail kits that people begin with (PC7424 or the like). Deeper, larger scratches will probably need touch up paint.
Matt, do you guys still have the UDM?
I just bough a Schwarz Black M3, paint is in good condition and clean, no rock chips, but it looks like they dried it with an old terry towel before I picked it up.
There are very tiny swirls everywhere. What polish do you recommend?
I plan on using Poorboys EX-P as a sealant with XMT 180 on top. I need a polish (going to be using an orange pad.
And also, I have glass headlights that are a bit scratched...how can I clear up the glass?
Two '97 M3 with 175K and 145K miles and a 1990 300ZX with 210K - swirls, scratches, and chips - is this the best kit for me? Anything else I should add to the order?
I'm not sure what the best polisher is nowadays. Can I use them all as sanders (not for the car obviously) also?
Matt,
I have always been an avid care person I believe that your car is a reflection of yourself and keeping it looking its best shows your attention to detail.
I currently have a polish master 2000 orbital buffer with microfiber bonnets which i use to apply and remove product. I normally use Meguairs gold class, and their white clay if needed. My clean up schedule is weekly with waxing every other wash.
I want to upgrade to equipment and products that will give me the professional finish. I have seen where most all of you guys are using a orbital like the porter cable, or flex with foam pads. Will you suggest which one of these would be best and what pads I should get as well seeing as I have no idea what pads do what.
Next, what polishes and wax/glaze/sealants (please school me like a first grader if you have time) should I be using with this machine. To clean the wheels and tail pipes I use the same Meguiars gold class wash I use on the car, is there a different product I should be using.
I don’t mind putting in the time I normally spend 5-6 hours doing my normal clean up. I have decided if I’m going to put in the time I ought to be using the correct tools and products.
Could you put together a wish list for me and that way I have a jumping point and then i can use these forums for technique with the pads.
Thank you in advance
I'd go for Meguiar's #105, either by hand (suicide if you're doing the whole car - better do it over a weekend at least), or with a PC 7424 as mentioned.
Nope, no more UDMs. Look into the Meguiar's G110 which is very similar.
For the glass lights, have a look at the Diamondite Resurfacing Creme.
For your swirls, to do it right I would go with Wolfgang TSR 3.0 + Orange pad, followed by Wolfgang FG 3.0 + Green pad.
That is a great kit and will tackle 90% of jobs out there For anything that kit won't remove, I usually reach for Meguiar's #105 and an orange or yellow pad. Yes, you can use the PC 7424 as a DA sander which is its original intent.
Have a look at the Wolfgang kit already mentioned in this post - http://www.autogeek.net/wolfgang-por...l-remover.html
The buffer you're using does not come anywhere close to the PC 7424. If you're looking to take your detailing regimen to the next level, this is the way to go.
Awww. Why was the UDM discontinued?
I'll look into the Megs now.
Would you say it's on about the same level as the UDM (as far as how it compares to the 7424, being a slightly more powerful version of it)?
- Meghan
Meghan@autogeek.net
** 10% off @ Autogeek.net- PinnacleWax.com -Wolfgangcarcare.com - Coupon Code = clubmember
I'm in the market for a buffer and starter kit. I've never used one and I'd like to start on my E34. I'm also planning as a Christmas present to buff out my father's '01 740iL, which has some pretty deep scratches (can feel a bit w/ fingernail) that I'm hoping to minimize.
What kit do I purchase? I'll only be doing BMWs, with the E34 having MAJOR swirls and a bit of oxidation...the paint is a bit dull.
-Denton
Im restoring my vader on my car and I need to use a crack filler,dye and all the works.Do you have a kit with all the items needed for the job? Do the kit comes with instructions?
