EDIT: I have a legitimate question that doesn't have its own kit on AutoGeek.net now.
Dwayne,
I'm starting my own detailing small business and am trying to get a feeler on my rates. Does this look good to you? Anyone else is free to chime in as well.
[my last name] Auto Salon Operates on an “à la carte” basis. A flat rate of $80 is charged for a detailing job that includes:
Hand washing the vehicle,
Clay barring the vehicle to remove particulate and grit embedded in the paint,
Applying finishing polish,
Applying wax,
Cleaning & dressing tires and rims,
Cleaning & dressing vehicle trim (if equipped),
Vacuuming interior, cleaning windows in & out,
Cleaning & protecting dash,
Cleaning vents,
Wiping down leather with cleaner/sealer (if equipped),
Clean & organize trunk (a no-cost option),
and applying Rain-X to all glass and headlights.
We do provide suggestions based on your desired final product, but feel free to exercise your freedom of choice!
CAS provides two choices for the initial wash of the exterior:
Detailer’s Pride Auto Bath Shampoo – A gentle, pH neutral shampoo with lubricating oils and cleaning agents that removes dirt and grit without damaging the finish. Smells great as well. $0
Detailer’s Pride Extreme Foam Formula Auto Shampoo – This high yield foaming auto shampoo bursts into mounds of suds when introduced to water and agitated. The bubbles work to encapsulate oily residue and dirt even before we touch the paint. This rich foam - combined with our own advanced cleaning agent- leaves your vehicle looking and feeling fantastically clean and bright. +$15
We provide three types of final coatings for the exterior. In ascending order:
Pinnacle Liquid Souverän Wax – the only liquid wax that comes close to the deep, sizzling shine that great paste waxes produce. Not as deep or wet of a shine as true paste wax, but a good wax nevertheless. It’s great on light colored cars and lasts 3-4 months. $0
Detailer’s Pride Max Wax – a No. 1 grade Brazilian Yellow Carnauba with engineered polymers that help the wax bond to the paint. DP Max Wax lasts 2-3 months and gives all colors a deep, wet shine. +$20
Pinnacle Souverän Carnauba Wax - It is a blend of natural Brazilian Ivory Carnauba and natural oils that give the paint an unmatched depth and richness. It is exceptional on all colors, but stuns on dark, bold colors. Reds radiate energy, blacks, and other dark, deep colors take on the shimmer of an infinitely deep pool. This premium wax lasts 2-3 months as well. +$30
Other Exterior Care Services:
Paint Swirl Removing: Swirls in the paint from previous washes, road grit, and abrasives can be incredibly unsightly, especially under the sunlight of summer. We use a dual-action orbital buffer to safely remove swirls from paint in a comprehensive three-step removal process. The swirls are first removed with a medium pad with Wolfgang Swirl Remover 3.0. The paint is then polished to perfection with a softer pad and Wolfgang Finishing Glaze 3.0. Finally, Wolfgang Deep Gloss Paint Sealant 3.0 is applied to create a lustrous and durable finish.
+$80 full vehicle or +$20 per body panel
Headlight Restoration: Today’s headlight lens covers are made of polycarbonate, a hard, impact-resistant plastic. While polycarbonate is more resilient than the glass lenses of several years ago, it can dull and yellow in a matter of 1-3 years. Dull, ineffective headlight lenses are a bigger safety risk than you might think. Clouded lenses can reduce the amount of light illuminating the road by as much as 90%. The oxidized plastic refracts the light that is passing through the lens cover, creating a glare that is distracting to other drivers. CAS enhances, polishes, and protects neglected and hazed over headlights, improving light output and driver safety incredibly – not to mention looks. +$20
Under hood Power Wash and Degrease: The engine compartment is the last place many drivers clean, but it is important to the beauty and performance of a vehicle. For example, think of how difficult it is to find an oil leak if the entire engine compartment is covered in grease. Many engine problems are just easier to diagnose and repair when the mechanic can locate the problem on a clean engine. DP Engine Degreaser is a blend of surfactants, sequestering agents, and emollients that loosen and lift greasy buildup from engine surfaces. This formula is based on remarkable cleaning technology that’s used to clean up oil spills in the ocean because of its ability to break up oil and encapsulate it. This same technology powers through layers of grime on engine components to uncover a factory-new looking engine. A high-pressure power wash completes the cleaning. +$50
Interior detailing service:
Leatherique Two-Step Leather Care – for 30 years Leatherique Rejuvenator Oil has been used by museums, collectors, decorators, and auto enthusiasts all over the world to maintain valuable leather. It is known worldwide for its ability to soften and restore even cardboard hard leather back to useful condition. It is complex blend of proteins and collagens, with absolutely no fillers of any kind. We apply the Rejuvenator Oil liberally (about 4 oz. per seat) by hand, massaging the oil well into all the surfaces and natural folds of the leather. This puts natural ingredients, not harsh cleaner, back into the leather and forces out dirt. We then apply the Pristine Clean to remove the contaminants that have floated to the surface of the leather and buff the leather to a luxurious finish. +$80 (all leather surfaces)
Detailer’s Pride Carpet and Upholstery Cleaner – thislifts stains out of carpet and fabric using the latest advanced surfactant technology (surfactants and wetting agents grab the foreign particles and release them from the individual fibers)
. They are then suspended on the surface of the fibers at which point they are wiped away. Removes food, make-up, grease, oil, fruit juice, and pet stains from fabric seats and carpet. Surfaces will feel clean and soft, never stiff. +$20 (all fabric surfaces)
Hot-Water Carpet Cleaning – Most carpet soil left behind by a vacuum is bonded to the carpet by oil or grease. Oils and grease act like glue to hold soil in carpet and upholstery fibers. What can break these bonds? A blast of hot carpet cleaning solution makes these stains much easier to remove. No stain can stand up to 200° hot water. We use a professional hot-water carpet stain extractor and DP Carpet Pre-Treatment. +$30 (all carpeted surfaces)
Important Notes:
We will match ANY competitor’s prices. Bring us the ad or price table and you’ll get it for that price.
- We provide mobile as well as valeting service. If you would like the detailing to take place at your location, please be able to provide a working hose and a power outlet. If it would be more convenient for CAS to retrieve the automobile from you and return it when the services requested have been performed, that can be arranged as well. We will also fill the tank upon request. The gasoline charge will be added to the total bill with a 5% discount.
- We will do our utmost to care for your finish like it is our own, but we cannot be held responsible for repainted panels which have uneven coats of paint and clearcoat in the event our tools ever go through the clearcoat.
- Due to the increased size of SUV’s, more product must be used in addition to the added labor of detailing a vehicle of large size. For this reason, the base detail price for an XL SUV is $80.
XL SUV’s include:
Cadillac Escalade/Pickup/EXT,
Chevrolet Tahoe,
Chevrolet Suburban,
Chevrolet Any Pickup,
Chrysler Aspen,
Dodge Durango,
Dodge Any Pickup,
Ford Expedition,
Ford Any Pickup,
GMC Yukon/XL,
Hummer H1/H2/H3,
Land Rover LR3,
Land Rover Range Rover,
Lexus LX,
Lincoln Navigator,
Mercedes Gl,
Mercedes G,
Toyota Sequoia,
Toyota Land Cruiser,
Toyota Tundra.
If you feel your vehicle is oversized and it is not listed please contact us.
