Thread: What did you do to your E30 today?
  1. #5626
    Dec 2018
    Germany
    1990 E30 325i 4 Door
    This is what i started with, removed the radio and saw this behind. Just a bunch of wires, crimps and electric tap which made me worry.
    Later, after following the wires, i was very fortunate to have only the speaker wires cut.
    There was no way i could get a solder in there, too little wires and too close to the plug (i live in an apartment, no cable long enough to use an electric soldering iron, butane portable one was too risky for me).
    Ended up using connectors and using shrink wrap to prevent any contact, basically taking the speaker wires directly from the harness back to the plug.
    Everything fitted nicely, E36 adapter that came with the radio is a 100% bolt on and even the pins are correct.
    The unit is not 100% secure, i have an extra set of clips to hold it in place, will deal with that later, fit and finish looks great.
    So far, no static, no signs of connection issues, but i really want to replace that manual antenna in the rear to an E36 style one to get better reception.
  2. #5627
    Dec 2018
    Germany
    Radio installed!
  3. #5628
    MauiM3Mania's Avatar
    Jan 2002
    Central Pacific
    88M3 99M3 04M3 ITBx16
    Spanky, to share photos with the forum, load the images to a Photo Hosting Site, such as Flicker, Google Photos, 500px, etc. Avoid using Photo Bucket or ImgUr as both make it difficult to link to forums.
    Once uploaded to a hosting site, copy the link of the photo into a forum message. The link would be something like; http://hosting_site.com/your_pic.jpg
    Ask if you have questions!
    88M3 AW 43k miles Project FS
  4. #5629
    Dec 2018
    Germany
    Quote Originally Posted by MauiM3Mania View Post
    I will thank you and i apologise.
  5. #5630
    Jun 2008
    PIttsburgh PA
    13 128i cabrio, 84 325e
    Reinstalled the radio. Installed by the PO. Looked like a kid installed it. I didn’t take a picture of what it looked like but here it is now. Next is new infinity speakers that just arrived.
  6. #5631
    Dec 2005
    corpus christi, texas
    No e30s, again :(
    I like infinity speakers. I had them in my 89 325i, back in the day. they are nice speakers.
    my youngest son and I started working on the superE. we painted the grills and mirrors back to black. he vacuumed it out and we have been driving it around the neighborhood to work on any kinks. I ordered a master and slave cylinder so we can fix the clutch pedal issue and then after that, I think we might have to replace the steering gearbox because its hard turning right but normal turning left.
    after that, off to inspection and daily driving by my son, probably. I will probably be driving the s10
    No e30s again.
  7. #5632
    Jun 2008
    PIttsburgh PA
    Went from terrible red to faded raisin back to proper cardinal on my sun faded rear interior vinyl. The dye/paint from World Upholstery is an exact match and wears well.
    Almost finished. Had to order a new latch release. It disintegrated when I pulled it to release the top lid.
  8. #5633
    Dec 2008
    Las Vegas NV
    91 318i 04 325i
    Installed a new coolant pump in the 91, with the previous one lasting 71,000 miles before leaking too much for my liking. Unlike other horror stories of these pumps getting stuck, mine came out really easy.
    On Christ the solid Rock I stand, all other ground is sinking sand. (Edward Mote 1797-1874)
  9. #5634
    Jan 2020
    Hartford, CT
    1987 BMW 325is
    Just disconnected my mid pipe from the headers and that was a couple hour excursion. Next is to drop the drive shaft and tranny to replace all the transmission seals, rear main and rebuild my shifter.
    '87 325is
    Build Thread Here
  10. #5635
    Dec 2018
    Germany
    Discovered some oil seepage on the driver's side of the block, right on where the "bitch tube" sits under the intake, sleeping onto the block. Looks like the large intake gasket (the one with 3 holes one piece) is not sealing correctly allowing the blow by to leak.
    Funny, i have done so many smoke tests, no smoke from the engine bay, all out the muffler and now i see this. Looks like i need to remove the intake, replace the gaskets and tube o-rings.....not to mention replacing the coolant.
  11. #5636
    Jan 2020
    Hartford, CT
    1987 BMW 325is
    Quote Originally Posted by H.J. 1981 View Post
    Sounds like a good opportunity to repaint the manifold!
    '87 325is
    Build Thread Here
  12. #5637
    Jun 2008
    PIttsburgh PA
    Quote Originally Posted by DanZ3 View Post
    Installed the new speakers. Started with the rears (non-premium in rear of cabriolets) made a huge difference in sound quality. I installed the front kick panels (premium speakers) and was somewhat disappointed. Like most 5 1/4 speakers, little bass. I put the premium speakers back in and am quite happy. One was a new speaker while the other was original. I read many posts on how good the bass was in the BMW speakers but didn't believe it. Overall sound is good.
  13. #5638
    Mar 2013
    So~Cal
    2003 E46 M3 / E30 Vert
    Test fit my wheels, going to be a tight fit
  14. #5639
    Sep 2019
    Newport Beach, California
    What 5 lug setup are you running?
  15. #5640
    Jan 2020
    Hartford, CT
    1987 BMW 325is
    Just popped my trans out today...Replacing EVERYTHING so i dont have to do that again for a VERY VERY long time.
    '87 325is
    Build Thread Here
  16. #5641
    Dec 2018
    Germany
    Quote Originally Posted by ZeroDarkE30 View Post
    False alarm actually, turned out to be some cable grease i sprayed the entire underside and mechanical parts of the car with. Some of the grease was sprayed upwards, and made it look like some manifold leak.
    Besides, i do not like painting engine items, or calipers. I like the zinc plating to show off the metal.
  17. #5642
    Mar 2013
    So~Cal
    Quote Originally Posted by Awe90m3 View Post
    I'm running the E30 sports 4x100 to 5x120 Stud conversion 18mm kit
    https://e30sports.com/product/bmwvwa...5x120-adapter/
  18. #5643
    Chicago, IL
    1987 325i Vert
    I had the same color combo vert that I sold in Virginia in 2012. Missing it hard lately.
    Sent from my Pixel 4 XL using Tapatalk
  19. #5644
    Jun 2019
    Lexington Tennessee
    1986 325e 1977 280Z
    Started painting my motor in anticipation of reassembly.
    Sent from my SM-N960U using Tapatalk
  20. #5645
    Dec 2005
    No e30s, again :(
    I learned yesterday afternoon that I have to replace the motor mounts and probably transmission mounts.
    the kids said the car was dying and felt weird so I popped the hood to look and sure enough, the arms are barely sitting on the rubber part of the mount from moving to the driver's side during (probably hard) acceleration.
    I love cardinal. I had that in the past and liked how it looks versus some of the other interior colors
    Quote Originally Posted by Invalidbassist View Post
    No e30s again.
  21. #5646
    Jan 2019
    Evansville,IN
    87 BMW 325i Convertible
    Removed the rear subframe, diff to replace bushings. While i am in there, I painted the subframe, trailing arms, and midpipe. Used Rustolem BBQ ultra statin black spray paint. Turned out much better that i thought. Bought Stainless Steel exhaust from ebay. Had to go cheaper and take a chance on ebay because i already spent $$$ on other parts. It is basically the ireland engineering clone. Replacing the rear bearings, brake lines (i found one of the hard lines crushed somehow and another the nut was fused to old soft line). Braided steel lines all around. Putting in short shifter with garagistic dssr. Replacing the gear shift seal. Now i know why they called the "bitch clip". Stuff still to do: new driveshaft going in, new radiator, hoses, upgrading to t-icv and simplifying vacuum hoses. Trying to eliminate vacuum leak.
    1987 BMW 325i Convertible
    “Speed has never killed anyone, suddenly becoming stationary… that’s what gets you.”
    Jeremy Clarkson
  22. #5647
    323i E30's Avatar
    323i E30 is offline ⅂!ʈө !ƨ l!ʞө ɐ ʇөlөbµouө
    Jan 2013
    Europe
    M52 E30 touring & E91
    Indirectly worked on my car today, by telling my 4 year old son how to replace the window crank and handing him the tools.
    I just watched him replace it, and when I asked if he wanted me to check his work, he told me that it was good so I didn’t. Yay
    ^ true story
    D̶i̶b̶s̶ ̶o̶n̶ ̶t̶h̶e̶ ̶E̶2̶1̶
  23. #5648
    Dec 2012
    USA
    F10 6spd 3 E305speed
  24. #5649
    Sep 2019
    I bought... motor(s)....
  25. #5650
    Jan 2002
    Central Pacific
    S52 on the right?
Page 226 of 237 FirstFirst ... 126176201216217218219220221222223224225226227228229230231232233234235236 ... LastLast
