Thread: What did you do to your E30 today?
  1. #5526
    Aug 2017
    Hamilton, New Zealand
    1994 BMW E36 M3 Eu Coupe
    Where'd you have them coated and polished? Did you send them out or find someone local?[/QUOTE]
    In NZ had them done here http://www.hpcoatings.co.nz/Home.aspx
    Sent from my iPad using Tapatalk
  2. #5527
    Dec 2005
    corpus christi, texas
    No e30s, again :(
    dude, secniv, those look awesome.
    my son reported he has had an increase in gas mileage in his 86 325e since we put the 4.10 diff in versus the 2.93 that came stock. since he almost exclusively does in town driving (the highway is only 5 miles from our exit to the one in town) he said he now gets 220 per tank instead of 180ish. the 4.10 caused him to slow down to only 60 on the highway, which is good since he always was doing 80mph on the highway. so, this will improve his gas mileage and driving record, ha ha ha.
    No e30s again.
  3. #5528
    Sep 2016
    Texas
    '92 BMW 318i Convertible
    Finished putting new interior in this weekend. Got refurbished front sport seats, rear seats, rear trim panels and front door cards and handles from a guy on eBay. Was previously a cloth interior (Natural) that was quite shredded up after 26 years. Pretty pleased with the outcome. Now I have a bunch E30 cabrio interior pieces to sell, too.
    OBu1uGZ.jpg.
    nLjlVJq.jpg.
    Finally getting some cooler weather in the southern US..
    bvP3grP.jpg.
    '92 318i Cabrio- Alpine White
  4. #5529
    Aug 2013
    Orange county
    1987 325i Cabrio
    Quote Originally Posted by CzarNick View Post
    Attachment 639505
    From materials I've seen on youtube (and the owner's manual) I think the top should fold away without needing to walk around the vehicle and tuck the fabric in to clear the rear seats. Mine doesn't, but I can't see anything obviously wrong or missing.
    I'm wondering if there's some cable or strap missing or incorrectly installed that would pull this bit to the rear and allow the top to stow in one motion?
    Attachment 639506
    You can see the folding really nicely in this video at around the 1 minute mark: https://youtu.be/dejwrEcvO1c?t=60
    Cheers
    Well even my new top I have push the strap in the other side.
    I have no idea what’s up with it. I thought it was just 80s vert shenanigans.
  5. #5530
    Dec 2012
    Grandview, MO
    1989 Bmw325IC
    Mine does the same - have to tuck in the top on other side. But when I bought it in 1997, you didn't have to. I think it's the old straps that are causing the tuck in problem.
  6. #5531
    May 2018
    Pittsburgh
    1991 325ix
    9CED314A-2FB1-4307-9F50-D5707083AB9D.jpg Just did some tear down today.
  7. #5532
    Wichita Falls, Texas
    1997 BMW Z3 2.8
    Wired my 1984 325e for daytime driving lights. The hardware came to $36 dollars, a five pin relay, a pigtail for the relay, and two inline fuse receptacles. I had the fuses, twist ties, and the 12 gauge and 16 gauge wire. Found switched power from an empty receptacle in the fuse box. Drilled an opening the the clear plastic lid on the box to tap into the power with a spade connector. Power for the lights comes directly from the battery cables coming into the drivers side fire wall (battery in the trunk). I used wire nuts to splice the wires. Get the switched power from the relay to the top wire (of three) going to the outer, low beam bulbs. Then run the power to the other low beam bulb with a wire run across the car in front of the radiator. Use zip ties to secure all wiring. Low beams will come on when the key is switched on. I used a 20 amp fuse from the fuse box to the relay and a 15 amp fuse from the relay to the lights.
  8. #5533
    Dec 2008
    birmingham, al
    M42,M60,M62,M62TU
    e34 540i/6 :: e30
    M62/6 :: e30 318is :: c5 Z06
  9. #5534
    May 2016
    Lakewood, Ca USA
    1985 Baur Cabriolet
  10. #5535
    Aug 2017
    Drove 500kms (300mls) catching bugs.. summer in NZ
  11. #5536
    Dec 2005
    No e30s, again :(
    just that motor swap in the 86 325. now it has a 2.5. all that is left is to do the suspension and I will be able to move on to the 87 325. I already fixed the horn and tail light issue on it so it will pass inspection 100% so it can be stickered and driven. after that, its time for all the fun stuff; suspension, exhaust, valances/spoilers, tint, etc.
    No e30s again.
  12. #5537
    Feb 2018
    California
    1991 BMW 325i Sedan
    I ended up finding a clean set of OEM U.S. Ellipsoids in the Los Angeles, CA area so I drove up for them. Then I bought some new "pigtails" for the wiring harness off of eBay. Just finished the installation and soldering of the wires tonight. Super satisfying and such and improvement all around. I filmed some of the process and put it on YouTube as an installation diy. I don't post much here, but I own what I believe to be a rare 91' 325i Sport Sedan in Laguna Green (most laguna green e30's convertible and some come in a coupe). I post my project process on the IG: @e30gumby
    Here's the quick video I put together of what I was able to film:
  13. #5538
    Dec 2005
    No e30s, again :(
    nice /\
    No e30s again.
  14. #5539
    Feb 2018
    California
    1991 BMW 325i Sedan
    Got my Turner Motorsports Performance Chip for my 1991 325i off eBay for a steal. Decided to bring my camera with me during the installation.
  15. #5540
    Jul 2012
    Spring Texas
    1990 325i turbo
  16. #5541
    Dec 2005
    No e30s, again :(
    i always wanted an e30 pick up truck. I couldn't get myself to cut one up though because I am not that good at body work
    No e30s again.
  17. #5542
    Aug 2017
  18. #5543
    Dec 2018
    Germany
    1990 E30 325i 4 Door
    Ordered some "small" parts such as new front wheel bearing, transmission mount(s), engine mount(s), aux belts (a/c, p/s and alternator) along with new cap, rotor, coil, wires, filters etc.
    I screwed up the driver's side front hub when i replaced the dampers and springs (it was not sitting straight) and one of the inner bearing cap(s) came loose.
    Also stripped the stud on one of the transmission mounts, bentley manual indicated a high 42 nm torque spec on the lower nuts. They are M10 sized and one nut just stripped a mount, but they are Meyle brand, so ordered a new febi brand instead (a tad more expensive).
    Since the cylinder head is 2,000 kms old (was installed in 2017) along with new rod bearings from the PO as a safety precaution, i will be doing a full service (fluids, belts and filters) as well as a tune up including new injector seals (and cleaning).
    The timing belt is also 2,000 kms old installed in 2017 along with the water pump. Already replaced the fan clutch, will probably replace the t-stat since the invoices show it was last replaced in 2013.
    The only thing worrying me is the head gasket, i am uncertain what brand was used and it maybe leaking oil (common front corner for oil return). I will replace the valve cover gasket (needs to come off anyways) and the rocker plugs when doing the valve clearance adjustment. I really hope it is one of those seals, i would hate to tear her up since after this i can finally start working on upgrading the seats, stereo (some cheap brand is in there), rust repair and paint repair.
  19. #5544
    Feb 2018
    California
    1991 BMW 325i Sedan
    My stock exhaust muffler on my 91' E30 was completely rotted out. So, today I installed the MagnaFlow Exhaust Muffler 14815. I recorded a little before & after video for anyone looking to compare look and sounds.
    IG: @e30gumby
  20. #5545
    Dec 2005
    No e30s, again :(
    we finally got the parts to finish my son's I swap. we put the fuel injection on it, instead of the eta fuel injection. so much more power and fun, plus, no more hunting idle. the eta system is so sensitive to vacuum leaks
    No e30s again.
  21. #5546
    Jan 2019
    Evansville,IN
    87 BMW 325i Convertible
    To date (had this car for 6 weeks), new brake pads, rotors, calipers, master cylinder, brake hoses, brake booster (finished today). New control arms and bushings, shocks, strut carts, trailing links front and rear, new tie rods. New intake hoses both front and rear of maf. Used about 5 cans of mink oil trying to resuscitate the seats. Previous owner butchered the stereo wiring and trying to fix. Ordering missing parts. Top in great shape but had to fix support struts on top door.
    1987 BMW 325i convertible with Dinan package.
  22. #5547
    Dec 2005
    No e30s, again :(
    nice, dinan package. I had a buddy with an e30 m3 with the dinan package
    No e30s again.
  23. #5548
    Jan 2019
    Evansville,IN
    yea... i am looking forward to driving it. I babied it coming home (no brakes) and unknown on timing belt. Never changed one in my life. Got all the parts to do it now, but nervous about doing it.
    1987 BMW 325i Convertible
    “Speed has never killed anyone, suddenly becoming stationary… that’s what gets you.”
    Jeremy Clarkson
  24. #5549
    Dec 2018
    Germany
    Replaced the headgasket, it was Victor Reinz and leaking, checked the head, valves etc all good.
    Did all the front engine seals since i do not trust the shop the PO took the car, new timing belt, tensioner, spring, pin water pump, thermostat , all belts, intake gaskets, exhaust manifold gaskets, all new ignition system (cap, rotor, coil etc). A couple of cooling hoses look swollen to me, maybe i will bite the bullet and replace all the hoses (€230 from BMW).
    Also replaced all the engine sensors (both cooling temperature sensors, ICV etc). engine is bone dry (knock on wood) but a faulty TPS sensor is getting to me, new one is here just need to swap it out.
    Stupid rear transmission output shaft is leaking, there is a new seal and i used curil K2 twice now and still leaking. Collar is free of groves and scratches, i shall be using loctite 270 since Curil is always "wet" and clearly oil is seeping past it when i removed it.
  25. #5550
    Raleigh,NC
    1989 325i
    I installed the shifter bushing upgrade kit from ECS tuning. It was fun.
Page 222 of 237 FirstFirst ... 122172197212213214215216217218219220221222223224225226227228229230231232 ... LastLast
