Thread: What did you do to your E30 today?
  1. #5451
    Apr 2017
    Sc
    1987 325e, 1989 325i
    754E23D3-0BBD-4765-9C75-8BD3E4CE87C4.jpgNew rotors and pads all the way around today, plus some deep cleaning of the wheel wells....
    1987 325e, coupe, 5speed
    1989 325i, sedan, 5speed
  2. #5452
    Athol, MA
    87 M6, 90 325iC, 89 iX
    Installed a new water pump (timing belt and idler while I was in there) because it was, I think, leaking. I put everything back together only to have it still leak. Took everything back apart again and have ordered another gasket for try #2. I am hoping it isn't, if even possible, the head gasket at the front of the block or the freeze plug under the cam sprocket.
    "Life is too Short to drive boring cars"
    1986 325E
    1989 325iX (Long term 5-speed/refresh project)
    1993 MB 300E
    1995 MB E320
    2000 Audi TT (Winter AWD snow beast)
    2007 Porsche Cayman S (Summer car)
    2009 VW Touareg
  3. #5453
    Dec 2017
    Seattle Washington
    1984 e30 318i
    M42 engine swap
    Hey Im new to forums and i do not know where to ask this but ill just go ahead. I bought a 1984 318i with an M10 obviously. But i threw a rod and now i want to do a swap (on a budget). SO i did some research and found that the easiest and cheapest swap is an m42. Found a guy on CL selling a 1995 M42 and it has around 200k miles on it. Im kinda of concerned about the mileage but idk how well these run. can anybody shed some light on this? thanks
  4. #5454
    May 2017
    Mooresville, NC
    2017 X5, 1992 325iC
    Quote Originally Posted by e30auburn View Post
    You might want to try this link for more info on the m42 https://www.google.com/search?q=bmw+...w=1200&bih=530
  5. #5455
    Nov 2017
    San Francisco
    1987 BMW 325is ///MSport
    Quote Originally Posted by TheCathedral View Post
    Those seats look good! Can you share the link to where you got them?
    Sorry for the late reply but here is the link http://stores.ebay.com/zoomzoomzoom-ing
  6. #5456
    Apr 2017
    Sc
    I managed to install new light bulbs in my hvac panel, somehow I lost the lighting on my 6 button clock panel tho, waiting for new bulbs in the mail. They worked before I took everything apart and now they don’t, so I’m stressed out about it.
  7. #5457
    Dec 2008
    Las Vegas NV
    91 318i 04 325i
    Four victories today with the 91. Had no gauges except speedometer, no blower, no reverse lights, blown fuse 10. On another BMW forum, someone mentioned pulling the K5/K7 unloader relays, and a new fuse 10 held. Subbed in some salvage yard relays with good results, and the blower motor works again as well.
    After an unsuccessful effort replacing the odometer gears on an eBay VDO speedometer, used the Garagistic odometer gears to repair my Motometer speedometer and that worked. As a bonus, reset the steering wheel so it's not cocked when driving straight ahead, and secured it with a new nyloc 22 mm nut torqued to 58 ft-lbs.
    On Christ the solid Rock I stand, all other ground is sinking sand. (Edward Mote 1797-1874)
  8. #5458
    Apr 2017
    Sc
    Got the lights in the mail to re-ignite my lowly 6 button obc. Looks beautiful
  9. #5459
    Jan 2018
    Malta
    1987 BMW E30 316 Sedan
    Cleaned the engine bay
  10. #5460
    Jul 2016
    Wichita, KS
    1987 BMW 325i
    Installed black door pulls and map pockets for the 2 tone look and love the change. Also installed some US ellipsoids. Very productive.
  11. #5461
    Dec 2005
    corpus christi, texas
    No e30s, again :(
    yesterday after work: pulled the trans on the two door, for the second time. learned I didn't set the torque converter correctly so pump is dead in that trans. dug out spare trans from garage and hung it on the engine.
    today after work: install starter, drive shaft, exhaust, heat shields and hopefully drive it around.
    tomorrow after work: pull auto trans and block from four door, pull standard trans from parts car. bolt standard to spare engine and prepare to install in four door.
    after that, we are supposed to have rain till sunday so probably nothing will get done till than
    No e30s again.
  12. #5462
    Wichita Falls, Texas
    1997 BMW Z3 2.8
    New to me 1984 325e. Very well maintained mechanically and a Conforti chip for about 145 hp. Silver paint is shot, however. So...got out the clay bar, rubbing compound and liquid Meguier's wax. Lot of imperfections remain, but at least they are shiny now.
  13. #5463
    Dec 2005
    No e30s, again :(
    cool
    I never made it through all of my previous list.
    got to the drive it around aprt and it started slipping after about 10 mins of driving so we changed fluid and drove some more. the nastiest junk is coming out in the fluid.
    still have pull block/trans from four door but the temp dropped into the 40s so that isn't going to happen till the temps go back into the 60s, or higher
    No e30s again.
  14. #5464
    1997 BMW Z3 2.8
    Just about to finish installing a third brake light in my 84 325e. Bit of trial and error finding the hot lead to the drivers side brake light, to tap into. Read somewhere that third brake lights became standard on e30's in 1986.
  15. #5465
    Dec 2008
    Las Vegas NV
    91 318i 04 325i
    Belated milestone achieved on my daily driver
  16. #5466
    Dec 2005
    No e30s, again :(
    dang, I have not updated this in a while.
    two door white car got inspected and registration and is being used again. I did order new rear wheel bearings for it though.
    four door is waiting for delivery of replacement head so new gaskets, timing belt, head, etc will go on once the head shows up
    also, the two door got a cup holder installed from the guy on rev that makes the wire one that sticks out to the passenger side. it works fine
    No e30s again.
  17. #5467
    Nov 2017
    Mallorca
    1989 E30 316i Coupé
    20171217_180940.jpg20180128_133131.jpg Gas tank fix, doing things right (before and after)
  18. #5468
    Dec 2005
    No e30s, again :(
    new head is installed on four door. still need to hook up some lines and install the radiator and fill it. the two door got a valve body from the spare trans and runs great. I ordered a new upper seat frame for the passenger sport seat to fix it, in the two door. i think that's everything. the two door needs an alignment, for some weird reason. ever since the place aligned it, it is twitchy while moving, like its toe'd in to much, and when you hit the brakes it pulls left so i have to figure that out.
    i am going to order slotted front and rear rotors for both cars though, and new pads. and i am thinking of doing coil overs on both too. you can't get one kid one thing and leave the other out, you know?
    No e30s again.
  19. #5469
    Dec 2005
    No e30s, again :(
    ok, finished the four door up last night at cruised the neighborhood with my youngest son (that car is being built for him, he is about to be 15). we are going to do an oil change and figure out why the temp sensor is pegged and then it will be ready to roll. it was so nice to cruise it around again. and jarrod loves it because kids at his school and the junior high recognize the e30. his brother dropped him off the other day, in his two door, and a few kids commented to jarrod what a cool car that was.
    No e30s again.
  20. #5470
    1997 BMW Z3 2.8
    Chasing a high idle in my 84 325e concurrently with shooting the lower side valences, originally black, with body color silver which I think will make my lowly e appear a little more sporty. That's the ideal, anyway
  21. #5471
    May 2017
    LI New York
    1990 325i convertible
    1990 e30 325i convertible (BMW noob)
  22. #5472
    Mar 2018
    Newark CA.
    1987 BMW
    Is the wiring of an 87' BMW 325i and '88 325i the same? If not, what's the difference?
  23. #5473
    Mar 2018
    Zagreb, Croatia
    E90 320D, E30 316
    Replaced the front hood shock and radiator cap.
  24. #5474
    Dec 2005
    No e30s, again :(
    My son and i put new bearings in the trailing arms. And one new cv assembly. The bearings sucked at first because the all thread i used for the puller stripped. We moved up from 3/8 to 1/2 all thread and didn't have any issues from then on so after up sizing, we have built our bearing remover kit and have it set aside for future use. 3" pvc was used as the stand off to set the plates on and some different aized washers to fit the out race and allow the all thread to pull against.
    For all the complaining i read about doing those, it was super easy. It was way easier than doing the rear sub frame to unibody bushings, that is for sure.
    I still have to do the stupid freeze plug on the other e30 though. Maybe tomorrow?
    Still no reverse on the one we did the bearings on. Odd, i don't know why, it just left. Now we just park whete we can pull through till we are bored enough to put the 5 speed in
  25. #5475
    Mar 2018
    Floirda
    98 BMW 325i
    Pulled the oil pan to fix an oil leak...
    Sent from my SM-G955U using Tapatalk
Page 219 of 237 FirstFirst ... 119169194209210211212213214215216217218219220221222223224225226227228229 ... LastLast
