Thread: What did you do to your E30 today?
  1. #5376
    May 2017
    Mooresville, NC
    2017 X5, 1992 325iC
    Quote Originally Posted by rustneversleeps View Post
    Thanks man but wish i could read German The price i understand is great...
    Use google translate HERE
  2. #5377
    Jun 2017
    Chincoteague Island, VA
    89 E30 Cab, 03 E46 330i
    Good luck! I think there may have been a different style strut on earlier model cabrios, so definitely take a look before you order. If you see that ball-andsocket-style lower connector then it's the same one I listed.
    My E30 weekend was frustrating. I replaced my windshield washer check valve because the old one was completely plugged and nonfunctional. After an hour of cursing at old clamps, fishing uncooperative tubing, and getting everything together I still don't have functioning washer nozzles.
    Looks like the nozzles themselves are plugged
    It's always something lol
  3. #5378
    Feb 2015
    Maryland
    325ix, 325ix, 540i
    e38s have heated windshield washer nozzles if you feel so inclined to pick some up at a junkyard and wire them in.
    If your e30 runs bad, switch to Megasquirt first. Then try new spark plugs, cap and rotor, wires, oxygen sensor, crank shaft position sensor, coolant temp sensor, air flow meter, idle control valve, throttle position sensor, digital motor electronics unit, harmonic balancer, fuel injectors, engine harness...
  4. #5379
    Jun 2017
    oooo good idea - and that's at least +5 hp
  5. #5380
    Feb 2015
    Maryland
    325ix, 325ix, 540i
    That's 5 hp PER nozzle.
  6. #5381
    Jan 2017
    Redmond
    1989 325ic
    Replaced folding top struts - thanks CzarNick for the great tutorial - works like a champ!
    Cleaned & greased hood hinges and latch points - no more squeak, and it opens easy now. Had been a hard enough pull that, combined with the squeaking, I was afraid something was gonna bust.
    Got the windshield replaced, along with putting in a new chrome trim strip. The trim strip was black coated when I got the car; the black coating was cracking and coming off dirty with every wash. I think the original trim strip was chrome.
    Removed rear license plate frame. Replaced mounting studs & screws.
    Registered for the E30 Picnic this Sunday at Marymount in Parkland WA. Looking forward to meeting fellow E30 enthusiasts!
  7. #5382
    Dec 2008
    Las Vegas NV
    91 318i 04 325i
    Ordered odometer gears from garagistic for eventual installation in the 1991 318i.
    On Christ the solid Rock I stand, all other ground is sinking sand. (Edward Mote 1797-1874)
  8. #5383
    Jun 2017
    Quote Originally Posted by bobdavisnpf View Post
    Awesome - Glad it worked for you! I find myself dropping the top a lot more now that it's easier
  9. #5384
    Mar 2017
    Ladson, SC
    1986 BMW 325 Sedan
    Replaced left side headlights with smoked drop smileys..won't be able to do the right side until Sunday probably
  10. #5385
    May 2017
    Mooresville, NC
    2017 X5, 1992 325iC
    Installed a strut tower brace to reduce roll and body flexing, verts are very flexy and this fixed the problem.
  11. #5386
    Jan 2017
    Redmond
    1989 325ic
    Nice pics of the strut tower brace. What make & model is that brace? I see it isn't adjustable - did it fit right off, or did it take some persuasion?
    I'm getting ready to add the same, and an X brace underneath, and a rear brace if anyone makes it for the vert. For pretty much the same purpose: add stiffness and (hopefully) improve safety or crash worthiness.
  12. #5387
    May 2017
    Mooresville, NC
    2017 X5, 1992 325iC
    Thanks Bob!
    The installation wasn't too bad although it fought me a bit, had to raise the front to flex the body and got it to fit in a few minutes. If you don't have a brace I highly recommend one you can feel the difference immediately after installation. I searched for a rear brace with no results, the vert mechanicals are in the way so that's a big obstacle in the way of installing one.
    An adjustable brace will go on much easier. I got my brace through ebay here's the listing http://www.ebay.com/itm/Black-powder...72.m2749.l2649
    Mike
  13. #5388
    Mar 2017
    Ladson, SC
    1986 BMW 325 Sedan
    New head unit..got BT
  14. #5389
    Nov 2014
    Ukraine
    1988 BMW e30 325i
    Hi, guys.
    I'm trying to repair my 89 325i.
    This story started at 2013 and not completed yet.
    I planing to start write my story here if you wanna (in separate Thread) =)
    And sorry for my English. I'm from Ukraine.
  15. #5390
    Feb 2013
    Palmer, AK
    2011 BMW 328xi
    New control arms on the iX. Spendy project...
  16. #5391
    Jan 2017
    Redmond
    1989 325ic
    Brake line power flush and new reservoir grommets.
    Also got a new-to-me strut tower brace added (a "souvenir" from my shop's old E36 racing days):
    Had a hard time determining how much of the improvement this made is real, and how much is wishful thinking. Does not make sense to me how much better this car seems to handle with such a simple addition.
    E30Garage, thanks for advice re: your experience. I've got plans to add a skid plate, X-brace, and butt brace from Racing Skids next month - will let you know how it goes.
  17. #5392
    Nov 2007
    Austin, TX
    '92 325iC, 99 Z3M
    Even if you can't verify improvement, I'm jealous. Great addition to an e30. I've been wanting one for my cabrio.
    1987 325is Zinneberot 5spd totally stock multiple show winner
    1992 325iC M-Technic factory appearance package, Diamantschwarz metallic, black nappa leather, black top, Dinan chip, K&N CAI, Remus exhaust
    1997 528i Schwartz II, 5spd stick daily driver
    1999 M Roadster, Dakar Yellow II, Dinan Stage 3, Dinan CAI, Dinan throttle body, Redline driveline, LiquiMoly 5w40 engine, BC Racing BR coilovers, Motion Motorsport under panel, S54 radiator and fan delete, BavSound speakers, Kenwood CD/iPod/aux/Bluetooth
    2001 Z3 3.0i coupe, Sapphire Black, auto (dang), suede headliner, LeatherZ sunroof screen
    2016 228i, Sapphire Black, 6 speed, M Sport Package
    1993 325iC, Schwarz II, custom leather, Bilstein HDs, Ansa sport, Royal Purple engine and driveline SOLD
    1997 318ti Active, Bostongruen, daily driver SOLD
  18. #5393
    May 2017
    Mooresville, NC
    2017 X5, 1992 325iC
    It looks great Bob Congrats!
    I'll be interested in the butt brace for my car as well, look forward to your post.
  19. #5394
    Dec 2008
    Las Vegas NV
    91 318i 04 325i
    Swapped cigarette lighter receptacles as the orange illumination ring broke on the 91. Put the 1990 vert up for quick sale:
    https://www.bimmerforums.com/forum/s...6#post29776596
  20. #5395
    May 2017
    Mooresville, NC
    2017 X5, 1992 325iC
    I just purchased one an X brace for my car!
    The X brace is on sale for $200 shipped from Garagistic http://www.ebay.com/itm/281610526268
  21. #5396
    Jan 2017
    Redmond
    1989 325ic
    Great price on the Garagistic X brace!
    I cleared my cart at Garagistic, just picking up the clutch pedal stop and the fancy-ass light-up BMW key blank.
    Also installed the seat shock springs I'd picked up at E30 Picnic. Such a treat to adjust the seats without stopping the car and getting out to manhandle them into place. Seat heights other than all-up or all-down are another bonus. Not to mention that time the seat dropped in weather and traffic - disoriented me to the point where I drove over a low divider, was lucky to not cause drive train damage. From a safety standpoint, the new seat shocks are worth it for that alone.
    Quote Originally Posted by E30Garage View Post
  22. #5397
    May 2017
    Mooresville, NC
    2017 X5, 1992 325iC
    I'm experiencing the same issues as you, where can I buy these seat shock springs? Part numbers?
  23. #5398
    May 2017
    Mooresville, NC
    2017 X5, 1992 325iC
    I did my due diligence and found the seat shocks here http://bmwseatshocks.weebly.com/
  24. #5399
    Jan 2017
    Redmond
    1989 325ic
    E30Garage - looks like a good source. I got mine from username rzmoser at r3vlimited forum - looks like rzmoser has the same source as the weebly guy.
    jeffnhiscars at r3v also sells them - he uses different strengths and labels them accordingly. He also sells cabrio top and lid shocks, another must-have wear item for us 'vert folks.
  25. #5400
    May 2017
    Mooresville, NC
    2017 X5, 1992 325iC
    I installed the garagistic X brace on my E30, it's a very nicely built X brace powder coated black, new bolts were included, a thirty minute install, I highly recommend this.
Page 216 of 237 FirstFirst ... 116166191206207208209210211212213214215216217218219220221222223224225226 ... LastLast
