Thread: What did you do to your E30 today?
  1. #5276
    Feb 2017
    Hawaii
    91' E30 325i
    Starting a project on this 91' 325i, going to restore and rebuild from shell up. Started stripping her down.
  2. #5277
    Dec 2008
    Las Vegas NV
    91 318i 04 325i
    Replaced two broken antenna masts on two Hirschmann Auta 6000 EL electric antennas, both requiring disassembly to remove broken pieces of the nylon toothed cable from the cable storage area.
    On Christ the solid Rock I stand, all other ground is sinking sand. (Edward Mote 1797-1874)
  3. #5278
    Maine
    84,86,87,88,89,90 3'ers
    put a new battery in my iX today, bought the 91 vs the 90.
    also put a deposit down on some new wheels/tires for summer, as its right around the corner and the studded snows have to come off by april by law.
    Quote Originally Posted by stevie30
    The e30 is the '57 Chevy of the European imports. Quote me on this.
    1986 325eS - cosmosblau, sold
    1990 325i sedan - bronzit, sold
    1984 318i coupe - delphin, sold
    1987 325iS - zinnoberrot, sold
    1988 325iS - zinnoberrot, sold
    1989 325iX sedan - zinnoberrot, current project/daily
  4. #5279
    Dec 2008
    Las Vegas NV
    91 318i 04 325i
    HVAC panel.JPGFigured out how to re-secure the stereo head unit on my 91. There is a break at the arrow in the HVAC panel. Pulled out the hazard flasher, and that gave me enough room to lift the cracked piece, get the stereo bracket all the way in, lower and realign the cracked piece, and finally reinstall the flasher.
  5. #5280
    Frederick, MD
    '87 e30, '02 e39 Dinan
    everything new exhuast, started it up on the new turbo, new catch can.
    Capital Driving Club Car # 102
    How to turbo your car:
    Step one. Install ecu and learn to tune and or have it tuned.
    Step two. Install injectors and retune.
    Step three. Install turbo parts and bits. get it running with out leaks. DO NOT DRIVE IT. Idling should be ok
    Step four. Retune car
    Step five enjoy
  6. #5281
    Feb 2015
    Maryland
    325ix, 325ix, 540i
    Euro grills. And bought another e30.
    If your e30 runs bad, switch to Megasquirt first. Then try new spark plugs, cap and rotor, wires, oxygen sensor, crank shaft position sensor, coolant temp sensor, air flow meter, idle control valve, throttle position sensor, digital motor electronics unit, harmonic balancer, fuel injectors, engine harness...
  7. #5282
    Sep 2015
    Washington
    1979 BMW 320i
    Painted my tail light corners amber to match! Used 3 coats on the corners and 1 coat of red on the whole thing (minus reverse light). Then two coats of clear coat. Looking pretty snazzy. Will install tomorrow.
  8. #5283
    Mar 2015
    Salt Lake City UT
    BMW 330i ZHP, 88 M3 Cab
    Drove the beasty to work today.Working on touching up some of the road rash on the car. Called several pin stripe guys as I want to do subtle ///Motorsports strips down the side. Got the LED bulbs in. DANG what a difference! 0221171403.jpg
  9. #5284
    Maine
    climbed some snowbanks:
  10. #5285
    Nov 2016
    Gibbstown New Jersey USA
    bmw e46
    Went to try to get the old girl started after sittin for 10 years. She needed a new battery and some fresh gas.
  11. #5286
    323i E30's Avatar
    323i E30 is offline ⅂!ʈө !ƨ l!ʞө ɐ ʇөlөbµouө
    Jan 2013
    Europe
    M52 E30 touring & E91
    Threw in some new floor mats.
    Also fixed my temp gauge by grounding the engine. Yay.
    ^ true story
    D̶i̶b̶s̶ ̶o̶n̶ ̶t̶h̶e̶ ̶E̶2̶1̶
  12. #5287
    Apr 2016
    Stamford, CT, USA
    1988 BMW 325ix
    My brother was driving on the way to school and we locked up. No abs and 15 year old tires. It can be fixed but sad
  13. #5288
    323i E30's Avatar
    Jan 2013
    Europe
    Ouch..!
    ^ true story
  14. #5289
    Jul 2012
    Longford Mills, ON, Can
    Ouch indeed... but seriously, 15 year old tires??? You really shouldn't be driving them past ten years. You're lucky it wasn't worse.
    1986 325 ~Elsa~
    Alpenweiss
    Need a photographer, come visit my site: http://estoguy.wix.com/unique-perspectives
    "The future is uncertain and the end is always near."
  15. #5290
    Mar 2017
    Montreal,QC,Canada
    1992 BMW 318ic Euro
    Pulled seats and carpet doin a deep clean.
  16. #5291
    M_3_X's Avatar
    M_3_X is offline Breaking Stereotypes BMW CCA Member
    N. Miss - Memphis TN Area
    '02 M3, '05 X3, '91 E30
    Replaced the front outer weather strips, originals were long overdue! Cheap and easy to do without even removing the moldings. And it looks much better.
    "If everything seems under control, you're just not going fast enough"
    -Mario Andretti.
    _____________________
    River City Bimmers Chapter
    2002///M3 Coupe, Steel Gray Metallic on black leather, three pedals.
    2005 X3 3.0i ZPP, Black Sapphire on Terracotta.
    1991 E30 325ic, AW, Black leather, Black top, three pedals.
  17. #5292
    Athol, MA
    87 M6, 90 325iC, 89 iX
    Installed a Husco armrest in my 90 vert. This came in a parts car I bought for the plastic bumpers. I had the pad recovered and I repainted the metal pieces. This really make driving a lot more comfortable. I will definitely be installing one in my 89 ix eventually.
  18. #5293
    Regina, Sask, Canada
    82 320i 89 325i
    love me a husco ! thought mine was broken until i discovered the wire was so covered in crap and sticky that it was stuck on the underside lol. cleaned it up and it was great.
    put my spare diff parts together today into an open 4.10. mostly to get them out of the way. darn thing wound up in spec, and now i dunno what to do with it lol.
  19. #5294
    Dec 2008
    Las Vegas NV
    91 318i 04 325i
    Completed the blower motor and resistor replacement on the 91 318i. Somehow I dislodged the male spade ground terminal when I installed the black plastic cover the first attempt -- didn't make that mistake this time.
    For those of us with M42s, this thread was a big help:
    http://www.m42club.com/forum/index.p...77663#msg77663
  20. #5295
    Sep 2016
    Texas
    '92 BMW 318i Convertible
    Quote Originally Posted by M_3_X View Post
    Nice work. You run across any rear weather strips for the cabrio in your purchase of front ones? My inner and outer on both sides are shot, and I can't find replacements anywhere.
    '92 318i Cabrio- Alpine White
  21. #5296
    Apr 2017
    Wethersfield CT
    1987 BMW 325i Convertibl
    Broke 2 bleeder valves flush onto the caliper yesterday and today I used a torch and got them out so I don't have to buy new ones! and there was one wheel lock lug and i used a bigger socket and put two pins in there and got the lug out. Also found why my tach wasn't working. great day
  22. #5297
    Aug 2016
    New Brunswick,Canada
    1988 325iC Convertible
    Quote Originally Posted by 1SGDHORN View Post
    Nice little option any links to were i can find one.....
  23. #5298
    M_3_X's Avatar
    Quote Originally Posted by KangstaE30 View Post
    Sure, I actually ordered rear ones by mistake due to the wrong description on the ECS tuning website, these are indeed the rear ones:
    https://www.ecstuning.com/b-genuine-...t/51361933751/
    https://www.ecstuning.com/b-genuine-...t/51361933752/
    Part numbers for the front ones are:
    51321924753
    51321924754
    And for some reason they call the front ones "Coverings" not weather strips.
    Diagrams are confusing since both look like front doors, (I found out the hard way)
    But this shows the front inner and outer weather strips:
    http://www.realoem.com/bmw/enUS/show...diagId=41_0949
    This is for the rear:
    http://www.realoem.com/bmw/enUS/show...95#51361933751
    Hope this helps.
    -Mario Andretti.
  24. #5299
    Feb 2015
    Maryland
    325ix, 325ix, 540i
    Technically this was a few weeks ago. But I drove it! And then I broke it. I had to replace the tank and fuel pump. And now I'm bogged down in a mire of while-you're-in-theres.
  25. #5300
    Athol, MA
    The Husco armrests come up every so often on EBay as well as on the forums. They are not usually cheap for what they are but, not many out there so I guess that drives up the price. It's pretty cheap money to have the foam replaced and recovered so, if you find one in rough condition don't immediately discount it.
Page 212 of 237 FirstFirst ... 112162187202203204205206207208209210211212213214215216217218219220221222 ... LastLast
