My car has suddenly decided it is going to shake like a girl's ass in the club on Friday night. It starts at 57-58mph and gets progressively worse until 70mph, then it will start to even out and by 80 you can hardly feel it. The steering wheel itself hardly shakes, it is the actual car itself. The tire pressure on all four tires is correct and I can't think of anything I have done recently that might have messed up anything suspension wise. I wanted to see if anyone else has had this problem before sinking a crap load of money into it just to find out it's something simple.
Bent rear rims?
2001 E53 X5 - 5.3 Procharged, 4L80E RWD, Brembo, 20" alloy, EBC race, Forge, A2W intercooled, Alcantara interior, 3.62 LSD and more!
2005 E53 X5 - 6.0TT, 4L80E RWD, 20" alloy, EBC race, Forge, A2W intercooled, Alcantara interior, 3.62 LSD and more!
1996 E36 335ti - N54b30, A2W intercooled, ZF 6speed rwd, 4.10Lsd, Speedline magnesium rims, Brembo, S55 exhaust, 245/40/17-295/30/18, idrive, Forge, logic 7
1999 E36 360ti - 6.0, ls6 springs, ls6 cam, hardened pushrods, trunion, racing baffle, t56, ls7 clutch, m3 brakes, 4.10lsd
bent rims. off balance wheels (those little weights are only stuck with double sided tape. they fall off like bikini tops on spring break). bent drive shaft or axle (ugh). bad shocks or stuts.
or maybe your car has found its harmonic resonance and the car vibrates at the point of sonic harmony. jk.
driveshaft...been there done that. your U-joints are gone.
-ducky
How old are the tires? Over time they produce little bumps along inside/ outside of the wheel. When your driving it almost hops. Run your hand along inside outside of tires see what you feel. Mine shook like that too. Its actually doing it now too ( i need new tires) any who. Like they all said check balance and maybe need new tires. Mine was perfect after i had this done. It might be more then that just trying to put in my experience.
1996 Schwarz II 328is ,5 speed, Black on Black, Sport Package
Cosmos V2 CAI, M50 manifold swap + sharked, Bilstein Sports, CF strut brace, M3 control arms + 95 offsets, Tinted windows, 18 inch breyton rims, 6000k Hid with thin line angel eyes, clears all the way around
Up next - Cams and Clutch
Then hopefully LSD and SC, maybe even squeeze a whole tear down and rebuild in Yea That is what i want.
I'll check it out but I'm not convinved its my U-Joints just yet. If the rim swap this weekend doesn't work I'll take it to a shop and have them check out the U-Joints and suspension. My best guess is two bent rims as I hit a pothole going about 45mph about two weeks ago and this problem started not long after. We'll see though. If it comes down to U-Joints and/or suspension replacement I'm gonna have a 91 Chevy Suburban for sale reeaaallll cheap to cover the cost.
the U-Joints might cause the car to vibrate, not shake
shake/vibrate... they are the same. just tend to classify vibrate as a higher oscillation than shake.
I'm with the U joints/flexdisk issue.
My e24 has driveshaft issues.. it has a large Ujoint instead of flexdisk..
the shakes/vibrations dont show up until about 60 and get more intense the faster I go.. the vibrations surge about every 3 seconds, almost like clockwork.
I had the same problem it would shake allwas though. I put factory wheels on and its like a new car. The other rims are not bent but most likely off balanced cause they havent been in about 2 years and i know they need it.But after factory wheels where put on the problem went away.
My Car
17" Quantum Tek rims//30% tinted windows//Panasonic CQ-C5303U head//Orion 12" subs(2)//Audio Planet 350watt amps(2)//Costum exhuast//DIY CAI
To Do:
re-do tint 15% all around//M3 front bumper//new 18" rims//angle eyes//clear corners//clear sides//black kindnys
So it turns out that it was just one damn tire and rim that was causing the vibration. I went to have a couple of drinks and eat at a local sports bar I frequent and when I came out my front right was flat. So I change it and head home, guess what, no vibration AT ALL, not even the tiniest bit! I'm still gonna have to replace the rims as I know the right rear has a small crack in it. Anyone local wanna sell me a decent set of rims for under $400? I would love you forever!
ok ok i have the same prloblem, everytime i accelerate the car has an extreme shaking right in the middle and it seems like its something dealing with the driveshaft. i already replaced my center support bearing because it was badly damaged due to the shaking. you think it can be the flexdisk???
yes its your flex disc and/or tranny mounts
-ducky
