Windshield Washer Jet Replacement (Update)
For those of you reading one of my other threads, I have a passenger side washer jet out on my car. I bought the part from BMW for like $4 (the thing that sticks up out of the hood to actually spray). I also got the driver's side one because they are both in bad condition (spotted on the black part).
So my friend and I, Eric, pop open the hood. We undo most of the screws into the insulation on the interior of the hood, pulling it out of the way to get to the jets.
For those that don't know what squirting fluid onto your windshild requires, this is how it works.
Container with all your cleaning fluid in it
connects to
hose
connects to
hose splitter (so you have one hose becoming two - driver and passenger)
each hose connects to a seperate
'white thingy' in the shame of an L
connects to
black sprayer
So, we go to disconnect the driver's side sprayer (old) from the white thing. After hard pulling the sprayer disconnects, leaving part of it lodged in the hose (it is fatter on the end so it will stay in the white part tight). Great. So it takes us forever to lodge this one broken off piece out, using needle nose plyers, flat nose plyers, and a vise grip. The flat nose and a lot of hand strength eventually popped it out. Phew!
So we pop the new one in, test it, works fine (shoots over the car, fixed it later).
We do the passenger side one, same thing, pop the sprayer from the white thing (it didn't break off though). Replaced it really quick and reconnect it. We go to test it. Dribble dribble... it was doing the same as before! It just dribbles onto the hood! Gah!
So we disconnect the hose (there is a clamp around the hose) from the white piece and then the white piece from the sprayer. Connect the hose directly to the sprayer...
it works. Flies WAY over the hood and dribbles onto the hood, however, it does shoot. We have our culprit - the white 'thing' is the malfunctioning piece, not the sprayer as BMW told me. I'll be out of town most of the day tomorrow so my bud is running over there to get a replacement, hopefully this is all we need.
I took a couple of pictures on a roll of film (film sat in 90 degree car for 7 hours today though...) on the install. Hope they come out good and I'll post them so you people don't have to by 'white piece', etc :.
1.5 hours so far (good 30-45 minutes was getting the broken piece out, however). Hopefully 30 minutes tomorrow and I'll be done!
Note- I also have a list from the dealer of recalls I need done. I have the #s, is there any way to check what these are for?
"Open Campaign Information"
0017050100 - S.I.B. - 17 01 98 LABEL CODE 228
0032012000 - S.I.B. - 32 02 95 (4198) LABEL CODE 136
0035050100 - S.I.B. - 35 01 97 LABEL CODE 202
Kevin
2000 Toyota Land Cruiser [2020-Present]
2013 Honda Pilot EX [2018-2020]
2003 Audi A4 Avant [2012-2018]
2004 Accord: [2006-2012]
1978 Black 320i [2007-2017]
1995 Boston Green 318is: [2001-2006]
Knoxville, TN
