"Torque is like cowbell... you can never have too much." - Michael Cervi
Thank you. Yes the rear is stock 3.23.. i was having an issue getting consistant 60ft's even tho all of them where 1.8 or under i had issue's with the car bogging off the line.. so i had to launch at higher RPM's.. but then i ran across an issue with doing that.. My Clutch would slip higher up in the RPM's on launch and also shifting threw the gears..
I will be going back to the next rental with a new clutch, and a Drive shaft shop 1pc drive shaft
E30 Turbo 2.8L - 60ft - 1.70 :: 1/8th - 6.99 :: MPH - 105.47 :: 1/4 - 10.66 :: MPH - 132.53
Daily E36 M3 - 60ft - 1.790 :: 1/8th - 8.20 :: MPH - 84.68 :: 1/4 - 12.81 :: MPH - 107.05
*RIP* E36 M3 - 60ft - 1.944 :: 1/8th - 8.64 :: MPH - 80.00 :: 1/4 - 13.55 :: MPH - 99.95
Cool2seat's TTstg1 E36 M3 - 60ft - 2.123 :: 1/8th - 8.44 :: MPH - 87.71 :: 1/4 - 12.94 :: MPH - 107.95
UUC EVO III SSK | M50 Intake Manifold | Conforti 3.5" CAI | AA Software | 3.5" HFM (unplugged)
Fan Delete | Strömung Exhaust | UUC Stg2 Ltw Flywheel | X-Brace | AA Track Pipe | 3.46 Differential
1/4 mile: 13.3@104.2mph; 8.6 in 1/8; 2.04 60' | Best 1/8 mile: 8.3@83mph; 1.81 60'
Dyno: 242rwhp/232rwtq SOLD
I dont have my 1/4 mile yet, but I do have my 1/8 mile specs.
8.5580 - 1/8 ET
1.8692 - 60 ft
84.28 - mph
mods-
M50 Manifold
Big Bore Throttle body (Ireland Engineering)
ASC Delete (BimmerWorld Elbow)
3.5 Intake
540i MAF
Underdrive pulleys (ADR- power steering and water pump)
Active Autowerke Tune
Fan Delete
SS reps into single 3" with high flow cat
Riot Racing Regrind Camshafts
3.46 diff
(OEM clutch and flywheel)
Street Tires (Hankook V12) 26 psi
Video
http://www.youtube.com/watch?v=UMi4G...ature=youtu.be
Time Slip
Hey man nice car you have there, did you dyno the car before you add the cams, if so what was your gain with the cams and the band like...
If possible I'd like my car added to the list.
14.220 @97mph
95 325is: m52b28 swap, fx 14.5lb flywheel, s50 cams, weight reduction
#501
95 328is: Obd1 M52B28, M50 Manifold, 21.5# Injectors, TMS Shorty Headers, S50 Cams, Obd2 m3 Mid Pipe, SS Rep Catback, Afe Magnum Force Intake, Spal Fan Conversion, TRM Chip, Full A/C Delete, ASC Delete, Cruise Delete, 3.15LSD, 16x7 Kosei K1, 225/50/16 Potenza Re760, 10mm Spacers up front, Billstein HD, Eibach Pro, F1 14.5# flywheel, F1 Stage 2 Clutch, Sick Speed Fixed buckets, Gutted, Miata Battery, CSL Trunk Lip, Dodge Viper Red. Car Weighed 2935# With me in it.
1/4 Mile 14.220 @ 97.45MPH!!!!
Ran twice last night. Last time I ran best I could do was a 15.6 and this time I pulled off a 15.35 so I was pleased considering I'm near stock on mismatched tires and stock 2.93 diff.
2002 BMW Titanium Silver 540i/6-speed Sport - ZHP Shift Knob - M5 Clutch/TTV Racing 15.6lb Flywheel - M60 Intake Manifold - N62 84mm TB - Dinan Intake Tube - 4" MAF Tube - DUDMD Tune - Magnaflow Resonator - Eibach 18mm Rear Sway Bar - Powerflex Front Sway Bar Bushings - CDV Delete - UUC SS Brake Lines - Koni Yellow Shocks/Struts - Eibach Springs - Zionsville Radiator & FDM Jim Blanton/Performance Gearing 3.46 LSD
1999 m3 na s52 with ; m50 manifold, bw race exhaust w/ Y pipe, afe cai, fan delete, samco asc delete boot, bren flash tune, stock 3.23diff, 8" rear tires, 3000lbs w/ radio and full interior/no driver. 70 degrees F at 300ft elevation
1/4 mile: 13.475 sec
trap: 100.65
60' : 1.929
