which transmission shifts faster?
2 are autos...does it matter?
It's not speed that kills, it's the speed difference that does. Obviously you aren't going fast enough.
Turning Benjamins into noise since 1997
I read a list of the 100 things you MUST do before you die. Funny, "Yelling 'HELP'" didn't make the list!
double clutch > AMG speedshift > lexus auto
Its a battle between the IS-F and the m3's DCT, the m3's shift speed should be at .2 or so while the IS-F claims .1,(which is very believable if you actually hear that thing shift), who knows but either way the m3 is faster in an actual race, so the shift time is really no factor in this case.
MODS
1JZ, BC 264 cams, BC TI Springs and Retainers, Ferra Keepers, Arp Head Studs, Arp Main studs, Arp rod bolts, Custom Emerald Performance Dual Plenum intake, 70 mm TB, SC6169 T3 Turbo, full 3 inch SS exhaust, Ar5 Transmission, 60lb injectors, Walbro 400 fuel pump, GTR intercooler. Porsche Turbo Calipers, Gutted Tein SS coilovers with Koni Race shock inserts , Tein Pillowball Camber Plates, UUC Swaybarbarian bars....needs more mods and a tune!!!!
lexus auto is just a traditional automatic, it does shift fast, but response are very slow.
there is no manual for C63 and IS-F, so hard to say which is better
BUT, as a matter of fact, we know that Mdct is 0.2sec faster in 0-60mph than it's manual. Where C63 we dont know it's 0-60mph comparsion, but we know its shifting speed is 35% faster than NON-AMG benz automatic transmission. and the other non-amg benz automatic that we can compare to it's manual are basically match in 0-60mph time.
so we can conclude that AMG speedshift are 35% faster than it's manual, but dont know 0-60mpg diff. i say around 0.1-0.2 sec. Therefore AMG speedshift are likely same shifting speed as Mdct, maybe a lilbit slower. But forsure faster than lexus auto
i think i can help him out with that, the response can be the initiation time (the time between you pressing the paddle to the computer registering it) and the shift time could be the time it takes to change gear ratios, take the IS-F into effect, .2 intiation time and .1 shift time (according to Edmunds inside line) think of it this way, your computer takes a certain time to load a software vs how fast the computer runs the sofware
MODS
The Lexus IS-F automatic is anything but traditional with a torque converter that can be disengaged as necessary and with 8 speeds it offers supremely close gear ratios to keep the car moving.
The M3 DCT is a new monster and promises great things from what I've been told from people who have driven it.
Mercedes automatic tramissions are some of the best in the world and often can live up to their manual transmission counterparts quite easily.
Let me get this straight... You are swapping out parts designed by hundreds of engineers that get paid thousands of dollars for something you bought at Pep Boys because your buddy who doesn't have a job told you it was 'better'?!?
-Peter
Current toy: none
Past cars: 88 M3, 99 M3 x2, 04 M3, 91 NSX, 06 S2000, 01 911TT, 06 Exige, 00 NSX, 04 GT3
Somehow I think the difference between 100 miliseconds and 8 miliseconds is not going to make a difference, even if you guys were actually racing professionally, which I seriously doubt anybody here is because professional racers know this issue is not important.
People who don't own these cars do.
Clearly you haven't driven on a race track or down a 1/4 mile, or maybe even done the simple math. Say on a given lap you shift 15 times. The 8 millisecond shifting car will be 1.38 seconds a lap faster with everything else being equal. That adds up to minutes over a given race. Find me one race driver that wouldn't take that kind of advantage basically for free.
-Peter
Current toy: none
If the torque converter is locked, the shifting of the automatic could actually be faster at times. The clutch packs inside the auto are basically the same design as the clutch packs outside the DCT. So clutch engagement/disengagement should be the same. At times the DCT has to wait until the correct gears are selected on the gearshaft, while the auto never has to because the planetary gearsets always have all the gears meshed, the ratio just depends on which clutch pack is activated.
Current Car (delivered 20/10/21): 2021 G80 M3; 6MT; DravitGrau/Kyalami Orange/Black Extended Merino; Permium Pkg (ZPP); 826M bicolor wheels; Black M Compound brakes; Sunroof (yes no CF roof)
(more pictures here)
Previous Cars: 2018 F30 340ix 6MT Msport(Dec 2017 - Sep 2021); 2013 F30 335ix 6MT Msport (Nov 2013-17); 2011 e90 328i 6MT ZSP (Aug 10-Nov 13); 07 e90-323i ZSP (May 07 - Aug 10); 97-318ti ZSP (Feb 97 - May 07)
"Mit der Dummheit kämpfen Götter selbst vergebens", Friedrich von Schiller -- "Life is simple, people make it complicated", Me (About me)
As long as you aren't going to a gear located on the same shaft you are on now it shouldn't be a big problem. If you are going to a gear on the same shaft it just jumps back to a regular clutch like action. Clutch out, gear change, clutch in.
http://auto.howstuffworks.com/dual-c...ansmission.htm
Not having driven the car... I'm willing to bet though that by the time you hit the paddle the second time to downshift and to the second gear, it will have already engaged the first.
Whether you think you can, or whether you think you can't, you're right!
The 1.38 seconds is the difference between a car that shifts in .1 seconds and .008 seconds in 15 shifts. All else being equal (gearing, power, aero etc.), the DCT will spend 1.38 seconds a lap accelerating while the other car is decelerating between shifts, and will be 1.38 seconds faster per 15 shifts.
That is purely the math, so if you have real world data that says differently then surely you know it could be due to 10 trillion variables out of your control. If you want to get into the physics of gearing and the power/torque production of the engine and integrate them for a theoretical laptime using accelerations, by all means write the code for a sim, and maybe I can check it against the one written for our FSAE team.
-Peter
Current toy: none
Jamdun17 is right
the shifting time is fast, when u put it in "D". like the time between when "it" starts to shift from 1st to 2nd gear.
But when u put it in manual mode, it does not respond fast as u want it to be. like when u press the paddles upshit or downshit, it takes about 2.0-3.0sec to respond or to "think", (not 0.2-0.3sec, but 2.0-3.0sec).
But in SMGIII, MDCT, or F1 tranny, these, are REALLY talking about millionseconds, when u press the paddle.
two complete different levels of transmissions
