Results 1 to 3 of 3
Thread: Transmission Keep leaking
    Dec 2007
    Grand Rapids, MI
    528i
    So I did a fluid and filter change on my car. But the filter I had was the wrong one so was the seal. So I put the pan back up and add new fuild with the same old seal and add new bolts thinking i will be fine. So when I look under my car the next day there big puddles of fuild that I am losing so I get under the car and check where I am leaking from and dam it. its my transmission pan so i can see where the leak is coming from I tried to tight that one bolt some more and it striped so I put another bolt in and that one striped. So now I am worried beacuse i dont know how thoese bolts could of striped When i could remove them by hand. Should i just drop the pan down again try to get the right seal and put some gasket sealant and put the pan back up. I dont know what to do and need ur guys help.
    Dec 2004
    Huntsville, AL
    87 325is
    It sounds like you stripped the threads in the transmission from over tightening the bolts in a mis-guided attempt to correct the failure to use a new gasket. It that turns out to be the case, the fix will be a new (correct) filter and seal and Helicoil/Timesert inserts for the damaged threads. And of course the correct torque on the fasteners when re-assembling.
    Jim Levie, Huntsville, AL
    Dec 2007
    Grand Rapids, MI
    528i
    What is Helicoil/Timesert I never herd of it i think i am going to order the filter and seal but please explain more on this so i can get it and fix my car its just sits in the drive way
