Results 1 to 15 of 15
Thread: Damm! I blew something in my m20 Turbo!
    Nov 2003
    LIMA-PERU/South America
    BMW 325is Turbocharged - Jeep Cherokee 4.6L Stroke
    Angry Damm! I blew something in my m20 Turbo!
    WHile I was runing or doing some race with my friend's VW golf 1.8T light tuned(20.6 PSI) I decided to turn up the boost from 5-6 PSI to 8-9 PSI, but when I hit these numbers 8-9 PSI start the pinging or knock, so this time I didn't want loose, and I won!
    WHen I arrived at the stop light, I noticed it was smoking like vapor train....soonely started to fail my engine like if it were a missfire or unpluged the spark cable... it was smoking a white densed smoke smelling a lot of oil, not color blue, just white.
    So I drove carefully to my home then to my shopp, I did a light checked with my mechanic and we think it can be some things,
    -Blew the Head gasket , and the water and most probably the oil is incoming in the cylinders
    -I did a hole in any Piston( but the engine it quite, is not reproducing any kind of noise )
    -Or the aluminum head is dead!
    other thing that I noticed was the water coming out or making some bubbles from the exhaust compressor ...
    We will see what I will find there
    PD: Yes I know I have to put a bigger injectors, this time I will do that!
    Euro M3'87 NogaroSilver/Euro E34 M5 '93/Porsche 993 TT 97' Euro/Porsche 993 Carrera 95' Euro/Skyline R33 GT-R
    Sep 2003
    Brew City, WI
    Boosted BMWs
    Damn Diego,
    Learning the hard way! You knew better and did it anyway.
    Sorry,
    Todd
    Todd DeHate - Turbo Charging Dynamics
    1985 535i euro LSX Turbo
    503rwhp/485rwtq
    Dec 2003
    Columbia, SC
    '71 & '74 VW Karmann Ghia, '87 325
    damn, i hope it was just the head gasket. that's what it sounds like to me, but there could be other problems.
    i win.
    for sale: es front spoiler with mounting stuff. pm for details
    Jul 2002
    Covington, Ga
    08 535i, 95 540 MSport
    Re: Damm! I blew something in my m20 Turbo!
    I bet 100 points you blew the head gasket......
    I got a copper M20 head gasket 3mm thick want it?
    Nov 2003
    Re: Re: Damm! I blew something in my m20 Turbo!
    Godd hear you !!!
    Thanks for that, I have already the biggest OEM BMW head gasket. not sure how thick it's.....2.05mm I think it is... I will shave my pistons maybe who knows
    Also if I would go with your gasket it would be a bit difficult, since I live out side of US
    Feb 2002
    Turkey/Istanbul
    E36M3 Turbo 1100hp, E46M3 Turbo under surgery
    I guess you blew either the head gasket or in worst case the block or one of the pistons may be damaged.
    Do you hear any piston skirt noise?
    If you have checked the engine coolant after racing and water spilled out of the reservoir, h gasket is the point to check.
    S50B32 + GT4XX = 1100 hp
    www.da-motorsport.com
    E46 M3 SMG under turbo surgery
    techno550 is offline Senior Member Supporting Vendor
    Nov 2003
    Atlanta, GA
    E36's + 300D
    you definately blew the head gasket. you will need to make sure you havn't broken a ring or the ring lands too though.
    were you lean at all? 8-9 psi isn't that much on the stock motor. I didn't have any timing issues at that point, and would only ping if I didn't have enough fuel.
    (blown a few head gaskets in the past.)
    -Michael McCoy
    Michael McCoy TRM
    Nov 2003
    -Michael McCoy
    Well I didn't watch the A/R meter, but the other times I checked it when I was in 8-9PSI and it was showing me rich like when I run in 6 PSI...but at 8-9 PSI still shows rich but start to pinging, I'm using 97 octane gas, wich is not exactly 97, it should be less, here are layers!
    Nov 2003
    nope, I didn't hear any metal noise or that kind, we checked the water reservoir and was spilling or whatever is called a bit... again, when it happened to me, it was smoking a white and ensed smoke, smelling a lot, alot of oil, it happened near my home, my oil level it's ok, and the water too, since I didn't drive it much time....
    Jun 2001
    Markham, Ontario,Canada
    Bmw E36 330i , Mazda 3
    If you are running 8-9 psi and 97 octane I guess its because of too much timing under boost.
    Hopefully it's just head gasket.
    As you said you are rich like at 6 psi.
    Are you running a intercooler if not then that could be your reason. You better invest in a intercooler or water injection.
    AA Stage 1 Gen III, BMP head gasket, Bored Throttle Body, 3.0"DnPipe & Custom exhaust with AA Gen 2, Aquamist 1s water/methanol injection,
    Last dynojet Aug 02 248c SAE 369whp/354ft-lbs at 10.5psi, 1/4mile 12.6@116mph
    New Sept 02 Head work and exhaust porting, April 04:UUC Pulleys, Turbo to intercooler pipe 2.5" Aug 04 3.5"HFM,11.5psi
    Nov 2003
    Yes I have a IC
    Nov 2003
    Atlanta, GA
    E36's + 300D
    Timing was just too advanced then. (or heatsoaked IC causing problems)
    -Michael McCoy
    Michael McCoy TRM
    Dec 2003
    Columbia, SC
    put it back together with STRONG head bolts- i read that the stock ones are kinda weak. check http://jim.nafsinger.com/
    i win.
    Nov 2003
    Yeah hotghias, I know that page is from BimmerJim, thanks anyway, helped me alot when I started my project.
    Thanks nore for the email and the pic.
    Just runing my stock ECu and soonely will be switched with the SMT6
    Where can I look for Bell FMU, how much cost it?
    Anyway, I know that sells reapir kits for the Voretch FMu in some models, I mean 8:1, 10:1, 12:1, etc, what ratio should I look to run safaly or not over fuel press with 15 PSI in the near future?
    Jun 2002
    Bulgaria
    BMW338is
    You do not use SMT6 yet ????????
    Killander the man with E30 S38 turbo 800+++hp is making now more powerful M5 turbo engine with SMT6 - in other forum people with 600+ hp turbo BMW says that SMT is cool - they do know how to turbocharge
    A4 TDI
    E36 powered by M5 3.8 S38B38 340hp engine
    E30 M20 2.8 drag project
