Results 1 to 25 of 39
Thread: Car and Driver S2 review
    Mar 2002
    Newington, Ct
    '99 Alpine White M3
    Anybody see the latest Car and Driver review of Dinan's S2 upgrade to the E46 M3?
    Salient points:
    Cost: $18,000 on top of the M3 price.
    Results:
    0-60:
    before: 4.5 to 4.8
    after: 4.6
    1/4 mile:
    before: 13.1 to 13.6
    after: 13.2
    hp rating:
    before: 333
    after: 361 (mfg claimed)
    Would someone explain to me how an increase of 28 hp results in virtually no acceleration change? Someone could say that if you take the slowest 'before' times, there is a slight improvement. But, Id prefer to use the concensus of 'before' times as reported by most of the mags, and those 0-60 times are usually around 4.6 to 4.7 seconds, so there is no difference here. Same with the 1/4 mile measurement.
    I dont know bout you, but I wouldnt be real happy paying 18 grand and winding up with virtually no improvement in acceleration. Who would be ?!
    Now, handling/suspension mods at least make a measureable improvement, boosting skidpad numbers from a stock .86g approx to .96g afterwards.
    But, hey for $18 grand, thats one hellofa suspension upgrade!!!!!!
    ___________________
    Paul E
    '11 AW 135i ; Sold: '99 White M3 81k mi; Dinan SC kit, 6"/3.48" sc pulleys, Aftercooler: 10.5 psi-367 SAE rwhp/304 rwftlbs @80 degrees ambient (still with OBDII manifold & stock cats); DynoTuning by Nick G (techniquetuning.com); Speed Shop: Imported Cars of Stamford; AA-Aquamist Water Injection, exhaust, clutch; Fikse FM-10s; Koni Suspension; Stealthboxes
    http://s11.photobucket.com/albums/a173/boostm3/
    Mar 2003
    Bay Area, CA
    That car probably started out as one of the slower times before the mods.
    It also depends where the extra hp is made after the mods. If Dinan only increased the peak hp and the rest of the powerband stayed pretty close to the same, then yeah you would not see too much improvement in acceleration. I guess if somehow they were able to make 28hp throughout the whole powerband, then you would expect a very nice improvement.
    If I had an E46 M3, I probably wouldn't think much about mods for acceleration (geeeezzz... low 13's in the 1/4). 0.96g sounds like something I would like to have.
    May 2003
    SMG
    I love the Dinan parts on my E36 but after reading the test and review in Bimmer mag, I think the S2 is ridiculous. like Paul mentioned, 18K for nothing really. Bimmer did claim S2 4.4 and stock 4.8 (it was a 2001 6-speed) and the 1/4 and 13.2@108mph..
    also Dinan S2 9.3 lbs per HP and STOCK 10.2 lbs per HP...
    They did quote Steve Dinan to say he's following ol' Herbert Hartge and putting a M5 V8 in the M3, and also a Supercharged S54 soon enough... I say meh to Dinan, I used to be all about it but now, meh...
    Milltek pipes. Ground control coilovers. Conforti Tuned. V1 & iPod hardwired
    May 2003
    SMG
    oh, oh! and 7K of that 18 was for the wheels, which score points for rarity, but you could get alotta wheel for 7K...
    For shame
    Dec 2002
    San Jose, CA / Davis, CA
    '01 M5,'95 325is,'82 320
    Yeah, Dinan really doesn't impress me with their bolt on stuff... I imagine no other manufacturers junk produces much more power... but Dinan always seems to think its allright to claim a hell of a lot more increase.
    As for the skidpad increase... from .87 to .96 is a HUGE increase... that's astronomical!
    I'd have to skip on the engine upgrades and just grab the suspension package... .96 is nothing to frown at. That's supercar territory.
    Steve
    Feb 2001
    Fort Lauderdale, FL.
    2023 X3M Competition
    hell yeah... .96g, that's awesome especially on street tires.
    Let me get this straight... You are swapping out parts designed by hundreds of engineers that get paid thousands of dollars for something you bought at Pep Boys because your buddy who doesn't have a job told you it was 'better'?!?
    Mar 2002
    Newington, Ct
    '99 Alpine White M3
    Yup.. I agree. Perhaps as an ala carte package alone, without the exhorbitant wheels and the not too effective engine mods, it might make more sense.
    Yea, there it is...Stage II suspension on its own is 'only' $1600. Thats alot better, and seems very effective. Ill vouch for Dinan suspensions. Ive got their Stage I on my e36 m3, and its a huge improvement over stock, beside the fact that the stock struts wear out by 35k miles! I trust this one will last an awful lot longer.
    ___________________
    Paul E
    May 2003
    SMG
    "when Koni's were adjudged deficient in that respect, we (Dinan) turned to JRZ for help" - Bimmer Magzine
    these tests were on 19x9 (f) 19x10 (r) and 275-30 and 285-30-19's on the rear...
    Mar 2002
    Newington, Ct
    '99 Alpine White M3
    And how much larger a contact patch do these deliver than stock? Id hate to think that of that .1g increase on the pad, 60% of it was due to more rubber
    ___________________
    Paul E
    Feb 2001
    Originally posted by paul e
    [BAnd how much larger a contact patch do these deliver than stock? Id hate to think that of that .1g increase on the pad, 60% of it was due to more rubber [/B]
    Stock uses a 225/40/19 f and 255/35/19 r tire. The DINAN pkg uses a 275/30/19 f and 285/30/19 r tire.
    May 2003
    SMG
    I think that a 'good' part of the increase was due to rubber. 'Bimmer' seemed to think the some of it was the tires as well.
    Dinan says "the 50mm increase at each front corner really dials out the understeer that is typical of the M3. There's also less understeer because we've narrowed the size difference between the front and rear tires of the stock car"
    Factory is 30mm wider and Dinan's setup is only a 10mm difference...
    A side note: these Dinan wheels weigh only 20lbs each
    Mar 2002
    Newington, Ct
    '99 Alpine White M3
    >>A side note: these Dinan wheels weigh only 20lbs each<<
    Yea, thats nice for 19" rims. But one thing still gets me. The listing for the S2M3 on the Dinan site is for around $10K. Even if the wheels are added, I dont think they come to $8 grand. So, where does the difference come from between the dinan site for the s2, and Caranddriver?
    ___________________
    Paul E
    May 2003
    SMG
    For shame
    The wheels and tires are 7K by themselves according to Bimmer and they list the whole package as $17,498 (inc wheels)
    Jan 2003
    Still in Seattle
    95 M3, 05 F-150 STX
    Yup, I read it in Bimmer also. over $7k for wheels and tires. I was not all that impressed with the car, I thought that I could do a better job with 18k on top of a new M3.
    Aug 2003
    Miami
    330i PP
    Not so long ago, I saw a guy put an S2 M3 vert on a Mustang Dyno and he actually produced less power than stock. Go figure. Needless to say, he was not a happy camper. $18K is a lot of money for a new suspension and a fancy Dinan badge.
    Feb 2001
    The same thing happened to a bunch of M5s : ... it's not the first time I've seen a DINAN package come up short in the power department.
    Mar 2003
    Portland, OR
    2003 Sterling Gray M3 SMG
    A friend in Portland (we dynoed at 2 facilities, both on a Mustang and a Dynojet) installed the Dinan CAI for his '03 E46 M3 and he lost 2 HP on average from his peak.
    I was going to do the CAI, TB, and Diff. Now I'm thinking I might do the Diff only.
    PB_M3 is offline Open cockpit ///M3 pilot
    Monterey Bay
    '04 ED 330i ZHP
    I was thinking about getting the wheels until i read the price. Did anyone ever find out the manufacturer of the wheels (i know dinan dosen't make them) and contact them directly? Do you think the manufacturer would sell them directly or possibly by a different name? I like the fact that they weigh so little and that they help to reduce the understeer.
    "If I were flying my plane, I'd be there already"
    Monterey Bay
    '04 ED 330i ZHP
    does anybody know the offset of these wheels?
    maybe they could even be custom made cheaper.
    May 2003
    SMG
    I would bet all I own that there is no way to get some except thru Dinan (legal reasons). "they" dont help reduce understeer, it was the change in contact patch (size) that made the changes. 20lbs per wheel is good, but there are lots of wheels that dont weigh much more than that for less $... (hamann magnesium?)
    Feb 2001
    They wheels are made by a company called Rota... Vapor over in Japan was supposed to try and track the company down (I tried calling their US offices but never got an answer). If you could get the offset information, you could take that information to HRE, Fikse or Kinesis and have them custom make a wheel for you (all HREs are custom made but specifications).
    Supposedly tho, DINAN has Rota in their back pocket so they can charge an arm and a leg fo a single piece wheel that costs more than a 3piece wheel.
    Mar 2002
    Newington, Ct
    '99 Alpine White M3
    >> I like the fact that they weigh so little and that they help to reduce the understeer....If you could get the offset information, you could take that information to HRE, Fikse or Kinesis and have them custom make a wheel for you (all HREs are custom made but specifications).<<
    What am I missing here. Dinan charges $7K for their 19" wheels and rubber. I bought a set of Fikse 17" rims that are gorgeous. My price was under $3 grand complete. So even if 19s are $200 more per wheel, which I dont know if they are, then the set would be like $4 grand, or just over half what Dinan charges. Besides, you dont need 19s. YOu can get 18s, because its not the diameter which helps the handling, its the closer front to back cross section, and the size of the contact patch.
    Theres no magic in these dinan rims, and theres no need to spend that kind of money on wheels which are that weight, and accomplish the same thing. And the offset is no secret either. Anybody can get the stock wheel offset, and calculate from there depending on size and cross section. NO more or less calculating than any of us who have bought aftermarket wheels had to do, and I doubt any of us payed anything near $7 grand!
    ___________________
    Paul E
    May 2003
    SMG
    [Theres no magic in these dinan rims [/B]
    Well Said. Im sure its not the wheels. But we can thank Dinan for turning us onto the most effective wheel & tire size...
    Feb 2001
    Yes we just need to find somebody who can tell us the offset... Nobody I know has figured it out yet. And the biggest question is, can I maintain my 13" ride height with a 275/30/19 tire up front.
    Mar 2002
    Newington, Ct
    '99 Alpine White M3
    Kevlar, do we know the offset of the stock wheels? well, maybe not the stock wheels, but the bmw option upgrade on the e46 m3 to the 19" wheels? Wont that tell us what is needed on, say, a set of Fikse 19s?
    Or, why not just go with a set of 18s? So, whats the stock offset on the stock size ?
    ___________________
    Paul E
