Update: This is an old thread and it appears this sub is discontinued. The newer version is the Kicker CompRT 6.75. Also another member mentioned that it may be easier to use a heat gun make the box a tad deeper...Heat it up the area and then push it out.
I was considering getting Beyma Power W6 sub but its depth seemed a tad too deep. The kicker CVT65 didn't require as much depth but the overall diameter was too wide for our enclosure. I grinded the edge of the speaker to make it fit. I also remove the cosmetic rubber piece that goes around the magnet for extra clearence.
Kicker CVT65
Peak watt 300
RMS 150
Frequency 25-350 Hz
The bulges on the enclosure get in the way.
I grinded out the plastic then went into metal little bit
My dremel broke so I used a knife to remove some of the plastic for extra clearance. I did this before I realized that you could remove the rubber base around the sub magnet. You might not need to cut as much if you just remove the rubber base.
-Phil
I connected the sub to the stock amp and it provided a nice deep bass. Eventually it will be powered by an alpine getting 200w. I'm not sure when I'll get around to installing this but in the meantime I'll continue testing it out using the stock amp. I'll keep you posted when I get the new amp in.
-Phil
Cool nice job I need 2 replace mine.
SKIKEMCOUPE
With the JL 6W0s getting scarce, the Kickers may be a good substitute for the Coupe's sub box. And looks like a spacer won't be needed.
i was lookin at the 10 inch of that sub for my enclosure until i found that i had more depth than i thought.... so went with something a TAD more powerful
either way nice job, hope you dont rattle too much back there though
~Ken~ '99 M coupe THE "original" TT Stage 3 - HTA3586R; 701 whp 672 wtq @ 26.5 psi ; NeverSell - CoupeCartel
What was your stock sub? Was it an H-K? My 97 has the generic (Nokia?) sub and I haven't gotten around to taking it apart to see how it differs from the H-K enclosure
97... you might have the dual 4" subs (if one can call 4" a sub)
Nice job on the sub Z-Thrizzle. Let us know how that sounds with the PDX once you get it installed.
If you have the stock Nokia then it's not even a dual 4". It's basically a 4" speaker playing into a bandpass enclosure. There's basically nothing you can do with the stock enclosure. If you can find the HK enclosure and mounts somewhere it will fit, however.
1997 Z3 2.8L Montreal Blue/Beige Ext. Leather.Hybrid Legatia L6 - Arc Audio 4150 XXK,Hybrid Legatia L1 Pro - Arc Audio KS300.4Image Dynamics ID8 - Arc Audio KS300.4Eclipse CD7100
Nice set of pictures, thanks!
Where does your rear woofer/sub mount? Mine is different.
Could you snap a picture of the final mounted enclosure?
What are the ohms and the diameter?
Where did you get it and how much?
Not sure about the depth of the coup box but you should be good. The mounting depth is 2-13/16".
It mounts in the same place as yours but the woofer faces the front of the car. I'll take some pics this weekend
The sub is available in 4ohms or 8ohms
I got the sub from sonicelectronix.com for $100 (I purchases my other stereo components from them and they were really helpful)
-Phil
The sub is a SVC and I connected it only using the red and black wires. The other two wires for DVC is tucked and tapped away in the sub enclosure.
I have maintenance issues to deal so I haven't had the time to run new wires and install the amp. I hope to get to it soon because the sub is not that loud being run off the stock amp.
-Phil
Nice job and thanks for sharing. My sub is "toast"; when I crank up the base it smells like an electrical fire was started inside the car...
Great write up, thanks! This is prob my next project!
I just got a video camera so I'll try and take some footage of the sub. I'm not sure of the quality of the camcorder's mic, but I think it'll give you guys a good idea of the bass this thing produces.
-Phil
4ohm sub?
-Phil
I found a replacement that maintains most of the stock look for roadster sound. com. This is the same unit bavarian sound sells at their site but a little cheaper.its still kinda high but has good reviews
From your link provided ("roadstersound.com")
This one is discontinued and was ridiculously priced and the price shown is for the enclosure only.
http://www.integralaudio.com/index.p...model-68s.html
And this one is ridiculously priced
http://www.integralaudio.com/index.p...model-80s.html
The Kicker 65 still wins out
I know the price is insane but its the only pro manufactured enclosure i have found anywhere.my z3 has the h/k sub w/ 2 speakers & I'm not sure a 6.5 in. will fit.I wish you could get just the lid & make the rest myself.I have seen a home made lid out of mdf online somewhere.
