This is the first real change I've made to my car. I had the usual squeaking behind the seats and decided to do the swap to new RSMs. I settled on the RE mounts and did the swap on Saturday. It was as easy as everyone says it is. Still, plenty of people out there seem to be intimidated by it, so I took pictures of the steps and wrote it up because neither the directions that come with them nor the Bentley manual covered the whole procedure. All you experienced people feel free to critique it and I'll update it. If you're reading this and are nervous about doing the swap, don't be. It's easy and only takes a few common tools.
Installing Rogue Engineering Rear Shock Mounts
This link can only take about 350 hits per month, so please don't repost it on another forum without checking with me first. I'll put it somewhere more robust. Thanks.
I think the link may be broken, but it sounds like a great write up!
Thanks for the heads up. I don't know how it got like that, but it should be fixed now.
Nice write up.
I like the "leftover parts" section.
I could post it to my webspace...they dont limit me...
Here is a link: <a href="http://www94.homepage.villanova.edu/...s_Roadster.pdf">Roady RE Shock Mount Install</a>
I posted it to my webspace...they dont limit me...
Nice write up.."The greatest satisfaction of aquiring knowledge is not just having it, but sharing it".![]()
Great write up! Many thanks. Pictures are a great help!
Very cool! Thanks so much for the write-up!! Changing them out most likely this weekend!
You document will be very helpful!![]()
SOLD MAY '14
Mods: 6psi Supercharger kit; Rogue RSM's; DINAN strut brace; Magnaflow exhaust; Stewart waterpump; Stoneguards, Glove box fix, M Shift knob; Aux input adapter; Mesh bumper grill; Projector Z II headlights (35W Xenon), IE alu radiator, ARD wheel studs, H&R coilovers, Work VS-XX wheels/Hankook V12 tires, VANOS fix
Thanks for the write-up! It looks like a pretty straightforward job, but it's very nice to have an illustrated walkthrough to let you know what to expect.
What does this mod do for you? Is it simply to replace a worn part or does it enhance the ride?
In replaces a really inferior stock component of our cars. The stock shock mounts have been known to actually allow the end of the shock to pierce your soft top upon failure. Can't say anything about ride enhancement other than eliminating squeaks and rattles associated with worn out stock mounts. I have to think that the improved design would also reduce the stress on the flimsy metal at the mounting points.
So this is different than the urethane bushings?
Good thing I put off doing this for a while. What a fantastic write-up with pictures.
Fellow noob digging up a 12 year old thread through google search. Links are all dead and the OP hasn't logged in since 2013. By any chance, does any one have this or can anyone point me to a new thread of the same info?
http://www.ex-parrot.com/pdw/mcoupe/rsm.html
I used this write up as a guide and it was spot on.
-John
Thanks but I have a roadster so it'll be slightly different. I read a few other guides and rogue sent me the directions before purchase. I was mostly interested in understanding how they install with the studs into the wheel well but now it makes sense after seeing the directions they sent me (uploaded below). In their for sale photos, it shows the RSM's completely together so it threw me off. The top reinforcement bracket goes up into the car and the threads down into the wheel well and then the other half is mounted to the shock. Should be a fairly straight forward install next week.
