Results 1 to 25 of 30
Thread: DIY: Z3 Fog Light Glare Gaurd Removal
    Los Angeles, CA
    Z3M Coupe, Z4M, E90 M3
    I removed the glare gaurds from my fog lights and it was surprisingly easy. On the easy a dremel was involved, on this it's just a clip.
    Left one done and right one stock (sorry, it's daytime and not that easy to tell in pics, but left is a lot brighter):
    To start, simply pop off the black cover next to the fogs with a flat head and remove the 2 screws.
    Pull back fog a bit and disconnect the connector
    Pop back the metal clip and open the fog light
    Squeeze the metal clip and remove bulb w/ rear cover
    Pop open the white clip from both sides w/ a flathead and remove it
    Carefully remove the inside part, it will come right out
    Remove the metal clip carefully. I used my hands, you can put a screw driver inside and pop it out
    Slide the gaurd out
    Insert the inside back in w/ the white clip
    How it looks on:
    Gaurds:
    Well, I was a bit bored. Hope this helps someone. The fogs are MUCH brighter. I have mine aimed really low so no negative effects.
    -Gary
    Columbia, SC
    2010 BMW 135i Coupé
    Nice, I always wondered why they were soo dull, just never investigated.
    -Dustin
    los angeles
    '01 Z3 Coupe, '91 318i
    Good right up. Now if there was a DIY way to keep the fogs and add brake cooling ducts back there
    SC
    M3 M3 M3 M3 M3
    Quote Originally Posted by Sound Of Speed
    Adding this to my hand fetish collection.
    |dirty | bav |
    Los Angeles, CA
    Quote Originally Posted by Bavarian_6shot
    I can PM you more. Feet too.
    Los Angeles, CA
    1997 Alpine White M3
    Jun 2005
    MI
    M Coupe
    You know, they call it a "glare guard" for a reason - it's so you don't blind oncoming traffic.
    - Ian
    2000 M Coupe, stripped and DE prepped
    46mm wheel bearing socket for rent - $30 deposit + $10 fee. PM for details.
    Los Angeles, CA
    Quote Originally Posted by osborni
    Read the first post.
    I aimed them really low since I don't want the yellow to blend, so it's not blinding anyone.
    The only way they would blind anyone is if I pointed them at an upward sloping angel, which I don't think you can on these.
    Jun 2005
    MI
    M Coupe
    And the fogs on Chevy pickups are aimed down too - but still blind me.
    - Ian
    Los Angeles, CA
    Uhhhh.... ok
    You do realize mine are a few inches off the ground compared to the Chevy's behind higher than your windows.
    Jan 2002
    Québec City
    '21 X3 M40i, '13 Abarth
    So why did you do this again?
    2021 Phytonic Blue/Cognac BMW X3 ///M40i
    1999 Cosmos Black/Dove Grey BMW ///M3 convertible - 5 speed - SOLD
    2005 Atlantic Blue Pearl/Taupe Leather Subaru Legacy 2.5 GT Wagon - 5 speed
    - SOLD
    2014 Tenorite Grey/Black Mercedes-Benz GLK 250 - bone stock.
    2013 Bianco/Rosso Abarth 500c - 5 speed
    2016 Oxford White/Grey Ford Transit 250 Powerstroke 148 MR (DIY RV conversion)
    Jul 2003
    NC
    00 MCoupe - 04 Lexus RX330 - 90 325i
    Quote Originally Posted by Hugo
    To cut that nasty SoCal fog......
    Los Angeles, CA
    The same reason anyone does any mods. To satisfy the need to change something on the car.
    Looks like it turned out well, and I for one can appreciate lighting work. The cutoff line is also very low which should minimalize any glare problems. The only time I can imagine it causing trouble is if you're cresting a hill or something and that'd be for a split second. Good job Gary
    Los Angeles, CA
    E36 owner, what are you doing here?
    The fogs are really dim stock. More light is always better.
    Los Angeles, CA
    Jul 2003
    NC
    I saw your glare in NC last night. Damn.
    Nov 2005
    Raleigh, NC
    2000 2.3 z3
    Doing mine now... Passenger side is done, driver's side almost. My fogs didn't come with that nice white clip to remove the inner reflective housing. So I resorted to a hair dryer to soften up the plastic, and using my fingers to pry the side of the inner housing that has only one knob on it from the black clamping posts that were holding it in. Afterwards, I just slipped the black glare guard out from the opening this created, I never took the inner housing 100% out.
    Hurts the fingers, but it worked And it's not like I'll be redo'ing the mod.
    As a side note, maybe I'm the first one to realize it, but I think the middle screw on the side of the fog light is for aiming. I tried for about 5min to unscrew it, thinking it would help me disassemble the light To no avail... heh And now that I put it back, I think it helps aim the light, haven't tested that for sure yet though.
    Mississippi
    2000 BMW Z3 2.8 Roadster
    I know on Lincoln LS's if you do this, the lenses get blistered right in front of the bulb after a while.....
    Just an FYI....
    Feb 2004
    Chula Vista, CA
    Z3 3.0i Roadster, E39 530i, Toyota Previa S/C
    Quote Originally Posted by mharrison View Post
    Just an FYI....
    the front lense is glass; so it would take some pretty hot temperatures to cause damage to the lense.
    also, that middle screw is for adjustment; leave it alone if you're happy with the aim.
    Mississippi
    Quote Originally Posted by bimmerZ5 View Post
    Cool. I can't imagine the glass would blister!
    The Lincoln LS has a plastic lense, yet another reason I want a 5-series instead of the Lincoln LS!
    Mar 2006
    In the sun
    Z3, 323i
    Quote Originally Posted by osborni View Post
    True, but then you need a step ladder to get into the Chevy PU.
    "Racing is life. Anything that happens before or after is just...waiting."
    Oct 2005
    Just south of Canada
    1999 z3 coupe - black
    Quote Originally Posted by jac389psu View Post
    Does anyone know if this is true? I was going to post a question about how to aim my fog lights, I tried Bentley and it doesn't say anything about it.
    Los Angeles, CA
    Yes, middle screw aims the fogs.
    Try it, takes 30 seconds.
    Dec 2005
    Cleveland, Ohio
    M Coupe, etc......
    I don't know about you guys, but, on my E36, I have had nothing but trouble with fog lights.
    1st the factory lights cracked, then I went with Depo's ,and they had so much condensation inside, that they would burn out the bulbs, then I bought ZKW, yellow fog lights, and those also suck the water in and mess up the bulbs.
    Is that just an E36 thing or have you guys experienced the same thing with the Coupes and Rodies???
    BMW E36, the new Honda Civic of tuning.
    Nov 2005
    Raleigh, NC
    2000 2.3 z3
    No problems at all here
