Hi,
I'm currently in the process of retrofitting the BMW E38 Hydraulic trunk boot. On the 15 pin HKM connector I cannot figure out where PIN 12 goes to. I looked at the WSD and It says that it goes to pin number 2 on a 3 pin yellow connector for the trunk lid locking switch but the connector is simply not there. Any help will be greatly appreciated. Thanks
Leo
Towed to E38 forum.
Look on Utube - Edwin did a video on this several years ago.
http://i293.photobucket.com/albums/mm71/krallopian/darthSigTest2_zpsn6zkw5id.jpg[/URL][URL="http://www.facebook.com/pages/DFW7-Dallas-Fort-Worth-BMW-7-Series-Club/300942239566"]DFW7 on Facebook/URL]
"The Last Great e38" 2001 i Sport - Born'd on date 1/01 Cosmos/Grey - 32.8K miles - 2 1/2 " Custom Exhaust, Center “X”over , Modified OEM rear bumper, M5 style trunk spoiler, M6 OEM wheels, M3 Steering wheel with working paddle shift & CF trim, Bi-Xenon upgrade, 13mm Rear sway bar added, SS brake lines and bronze bushings, Cross drilled rotors and painted calipers, Akebono pads, Zionsville aluminum radiator & exp. tank with electric fan, Sprint Booster, BluTooth conversion, MKIV Nav., Custom wood cupholder, DUDMD Tune, Orien V2.5 LED Angel Eyes, Evans waterless. Recently added grey faced //M5 Cluster - all gauges functioning. Changed the grey carpet to black and topped off with GG Bailey front/rear mats[/SIZE]
Thanks!!
0-02-05-8e72c297d4d01a8f84d43c1fde2ae31d21d77b11b3cf7cc16f37dc8e83a21933_full.jpg 16667976_1530020960360566_1770016407_o.jpg
Hi,guys . I have these parts for retrofit of hydraulic trunk . Probably this is not everything . What else do i need ? Can you tell me part number of relay ?
Thanks .
Number per kit Description
Part number Price Ea. Notes 1Pump bracket nut 07 14 9 156 628
$0.47Likely a common nut can get from parts car 3Plastic nut for module and pump 16 13 1 176 747 $0.26Probably have plenty - common nut 1Left hinge 41 62 8 398 953 $62.14
1Push rod for lock 51 24 8 235 749 $27.64
1Pump + bracket 51 24 8 236 505 $1,012.86
1Hydraulic piston 51 24 8 236 506 $412.27
1Trunk close button bezel 51 49 8 221 022
1HKM module socket 61 13 1 382 567 $4.50
1Plug for tilt switch 61 13 8 377 072 $1.08
1Plug for trunk button 61 13 8 380 696 $1.48
0Dual microswitch for lock button 61 31 8 360 292 $28.97Don't know if this is necessary or different from normal cars, pretty sure not different 1Trunk close button 61 31 8 375 580 $55.54
1HKM Module 61 35 6 909 664 $177.17
1Hose grommet/sheath
Can't find part # for this, says "4 211 112" on the part 1HKM module bracket
Can't find part # 7Small ELO female pins: 3 tilt, 3 trunk switch, 1 GM 12 52 7 502 039 $0.50
1Lock grommet for push rod 51 24 8 149 619 $1.49Probably already on the lock 1Banjo bolts for Pump 51 24 8 236 504 $49.30
2Buffer stop 51 24 8 254 063 $7.54
2Pins for 40A fuse holder 61 13 0 007 271 $5.46
5Relay pins 61 13 1 370 691 $0.47
9Small 2.5mm AMP connector pins (HKM + Pump) 61 13 1 376 202 $0.50
6Large 2.5mm AMP connector pins (HKM connector) 61 13 1 376 206 $0.56
1Valve socket (natural) 61 13 1 378 109 $0.89
8Small spade connectors for splices 61 13 1 387 140 $1.27
1Large spade connectors for splices 61 13 1 387 146 $0.36
1Mini relay socket 61 13 1 387 199 $2.27May already be present - check your car 1Ring terminal to power distribution center F101 61 13 1 388 865 $0.98
1Pump power socket (blue) 61 13 8 352 330 $1.55
140A fuse 61 13 8 367 132 $1.42
140A fuse holder 61 13 8 367 144 $1.78
1Tilt sensor 61 31 8 373 951 $27.11
1Grey mini relay 61 36 1 393 415 $10.93
2Screws for tilt sensor 65 75 8 235 255 $0.28
1Lock actuator 67 11 8 360 225 $80.98
Sorry to hijack but it's still relevant. Where is the best place exactly to mount the tilt sensor on the underside of the trunk lid?
