Results 1 to 14 of 14
Thread: Doing a clutch and shift pins, do I have everything covered I'll need/should replace?
    Oct 2007
    VA
    00 Mshoe
    Some of you might have seen my first post "It finally happened. pulled the trigger on an E36/8." Well the first thing that needs to get done is the clutch. I looked through the manifesto and figure I might as well do the shift pins even though it hasnt exibited the signs of needing them since I already will have the transmission pulled. I am also replacing other wear items that would be good to replace now with everything broken down:
    Shopping list as of now:
    Clutch items:
    From bimmerworld:
    Sach's S52 OEM replacement clutch kit (clutch, PP, throwout bearing)
    Pivot pin for clutch release lever (for Z3's)
    RE tranny mounts
    RE carrier bushings (oval)
    From Pelican:
    Guibo nuts (x6) 07-12-9-900-047
    Guide sleeve for throw out bearing 23-11-1-224-845
    Pilot bearing 11-21-1-720-310
    Flywheel bolts (x8) 11-22-2-243-051
    Pressue plate bolts (x6) 07-11-9-906-045
    Selector rod seal 23-12-1-282-394
    Tranny Input shaft seal 23-21-1-224-820
    Clutch line (OEM) 21-52-1-159-714
    Spring clip for clutch assembly 21-51-7-570-284
    Exhaust gasket (x2) 18-30-1-716-888
    Rear main seal 11-14-2-245-364
    Shift Pin items:
    From Pelican:
    Pin kit (x3) 23117525048
    Sealing cap (x3) 07119937227
    Pin bushing kit (x2) 23117542726
    Reverse gear pin 23311224849
    5th gear pin 23317502165
    Drift pins I will be making on a buddy's lathe
    Anything I'm missing? Anything else I should be doing while I'm there?
    SS kit- is not in the budget now, I have other things $200 should be spent on right now.
    Guibo- I dont have to pull the transmission to replace it, so I'll inspect it when I do this before purchasing one to find I don't need it.
    Flywheel- Inspecting and resurfacing as required, I'd rather not drop the money on a new one now with other items needing attention.
    Thanks for any advice
    Jul 2004
    Houston, TX
    36 Cylinders
    You should probably clean replace and re-lube the shifter ball cup, replace the shifter arm bushing, and the shift coupler bushing that the selector rod attaches to.
    See this for rebuilding the shifter, it will be extremely crisp after all that. http://www.pelicanparts.com/bmw/tech...t_Bushings.htm
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Oct 2007
    VA
    00 Mshoe
    Thanks for the suggestions, I'll look into them.
    I also just added Amsoil 5w30 Manual Synchromesh Transmission fluid to the list of items I will be getting to do when doing this.
    San Antonio
    Z3M Coupe & Roadster
    You can get the shift pin as a kit from a fellow enthusiast and destroyer of driveshafts McoupeMindy.
    http://www.bimmerdiffs.com/collectio...vice-parts-kit
    http://www.bimmerdiffs.com/collectio...drift-kit-used
    Nashua/Boston/S.E Mass
    Audi R8 V10 Plus [GATED]
    were the subframe bushings already replaced?
    Santa Cruz, California
    1999 Z3 MC, 2000 540it
    Forget the OEM clutch line and go with Stainless Steel Braided to avoid future headaches.
    Oct 2007
    VA
    00 Mshoe
    Quote Originally Posted by jajou318 View Post
    I came across this in my parts list travels and wasn't sure if I should go with his (her?) site. From your recommendation and more looking about I will be going though his site, and saving a few bucks. Ordering the shift pins, ultimate seat fix, and tranny oil.
    Quote Originally Posted by RickySixx6 View Post
    I am guessing you're talking rear diff/subframe? I doubt they have been, and the car is only at 94k. I am not looking at dropping the diff at the moment and pressing all that stuff out at this time either, but the clutch NEEDS to be replaced.
    Quote Originally Posted by dcrothers View Post
    After looking more into these an RE is only $10 more... I will be going that route.
    Columbia, Worst Carolina
    2000 M-Coupe, 1994 SE-R
    I think Ricky is talking about the front subframe?
    San Antonio
    Mcoupemindy.. Mindy being his car's name. His is Jonathan.
    Oct 2007
    VA
    00 Mshoe
    Got it
    Feb 2013
    East TN
    1999 BMW Z3 M Roadster
    I've got a set of BimmerDiffs shift pin punches (very lightly used) for $40 shipped.
    SOLD! Thank You.
    Last edited by Z3MRacer; 07-01-2013 at 12:49 PM. Reason: Update status of item for sale.
    Z3M Racer '99 M Roadster
    Oct 2007
    VA
    00 Mshoe
    Placed all my orders this morning... boy does my CC hate me. Thanks for the suggestions guys. Looking forward to a smooth shifting, great feeling trans.
    Springfield, Ohio, USA
    1998 Z3 Roadster
    I couldn't find a shop that would re-surface the dual-mass flywheel since they flex too much. I just lightly sanded mine. There are a few YouTube videos on what a bad one looks like, and they often fail. You should inspect yours while in there.
    Oct 2007
    VA
    00 Mshoe
    Update:
    Did the work this weekend:
    Things I had and really didnt need:
    Transmission seals were tight and good, I did not see the need to mess with them and my patience was thin by this time, but its good to have in case you remove yours and they are leaking.
    Reverse gear pin
    23311224849
    Pin bushing kit (x1) 23117542726
    It was a biotch of a time getting 5th's replaced, I didn't have the patience to mess with Reverse, I'll deal with it being a bit tough.
    I bought the selector rod cup, and it came with the internal bushing, pin retainer ring, and an updated bushing that does not require the yellow washers. Also, the RE delrin carrier bushing comes with a new clip that is not stated as included so I got one just in case.
    Things I didnt have I wish I did:
    ALL EXHAUST HARDWARE....
    4x bolts for rear flanges
    4x nuts for rear flanges
    6x nuts for manifold studs
    I don't know what I was thinking or how this was missed, but hot DAM these were a pain. Also, I might try using a standard socket in the future on the manifold nuts, a 13mm was too small and a 14 was a little big yet its a 10MM (1.00 pitch, I found out) nut per realoem
  1. Clutch job, shift pins, and other questions
    By Kyle Anderson in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 04-25-2012, 01:49 PM
  2. 540i6 Clutch and flywheel. What do you recommend?
    By toyotahachiroku in forum 1988 - 1996 (E34)
    Last Post: 08-10-2010, 02:55 AM
  3. Replies: 45
    Last Post: 02-10-2008, 10:21 PM
  4. How do upgraded clutches and flywheels make the car perform better?
    By S50SFIFTY in forum 1992 - 1999 M3 (E36)
    Last Post: 08-07-2007, 01:24 AM
  5. Replies: 7
    Last Post: 12-31-2002, 01:19 PM
