Results 1 to 21 of 21
Thread: Seat height mod kits: Does anyone have any?
    Chicago
    Yellow Pants
    Does anyone have any seat height modification kits sitting around? Would love to buy one asap.
    With putting ~600 miles on the coupe every week my back is in need of some help.
    Sep 2004
    SoCal
    Chariot
    I bought mine, HERE
    Chicago
    Yellow Pants
    Quote Originally Posted by Eurospec View Post
    I bought mine, HERE
    bravo.
    Thanks so much.
    Sep 2004
    SoCal
    Chariot
    Quote Originally Posted by hexagone View Post
    bravo.
    Thanks so much.
    You got it!
    Good call. One of my favorite mods to date.
    San Antonio, TX
    2000 Z3 M Coupe
    I just bought the required hardware at my local fastenal. Didn't have to wait for shipping and cost about $3.
    Apr 2002
    Florida
    Coupes...
    Make sure they are hardened so the seat doesn't come off the base when you hit something head on.
    White is Right, Steel Grey is OK, but Estoril is the only color that truly matters.
    I like Coupes.
    San Antonio, TX
    2000 Z3 M Coupe
    Quote Originally Posted by mpire View Post
    Agreed. I should have said that in my original post. Grade 8 hardware should do the job nicely.
    Thanks Mpire.
    Northwest NV
    Audi B8.5 S4
    I still have the tilt mod kit that mcoupemindy sold me sitting in a drawer. Frankly, I'm not sure if I'll ever install it, unless only to experiment. I've done 14 hour and 19 hour drives, plus multiple 6, 8, and 10 hour drives, and to be honest, the seats in this car are the most comfortable seats I've ever had. Hands down better than the 'vaders' in my 99 M3, and light years better than the WRX seats.
    I'm 6-ft, and weight varies from 185-200, for the sake of reference.
    Feb 2010
    Sherbrooke, Qc, Canada
    73 Datsun Z & 01 Mcoupe
    Can you please draft a short list of the parts/sizes you bought? I was looking into doing this also... It would save me some experimenting and back and forth trips the the hardware store...
    Mar 2013
    Minnesota
    2000 M Roadster
    I bought mine, HERE
    I just purchased a seat height mod yesterday from there.
    San Antonio, TX
    2000 Z3 M Coupe
    Quote Originally Posted by Chuck Norris View Post
    This link gives you all the info you need.
    http://forums.bimmerforums.com/forum....php?t=1508549
    mcoupemindy's Avatar
    mcoupemindy is offline Senior Member BMW CCA Member
    Supporting Vendor
    Jan 2005
    Haymarket, VA
    '99 M Coupe
    Quote Originally Posted by ingalls89 View Post
    Check the grade of materials. For that price, I'm betting they are low grade. I can't even buy the couplers for close to that!
    Thanks Mpire.
    Grade 8 is not sufficient in a seat application.
    Shipping to Canada is cheap Send me an email if you want - it's in my sig.
    Mar 2012
    Chicago, Illinois
    2000 BMW Z3 COUPE 2.8
    I bought mine, HERE
    I bought the kit last year and barely installed it yesterday. The seats are comfortable but the kit adds to the comfort. At 6'2, it feels great. Highly recommend this inexpensive mod.
    Andover, MN
    Z3 Coupe, ZHP, E46 M3
    If you have long legs (like me 6'2" 185) this is a must, I'm going to be doing it to my E46 too.
    Jun 2008
    Philadelphia, PA
    1979 320i Golf
    Must do!
    1979 320i Golf
    2008 328i White on Black
    2000 M Coupe Imola on Imola/Black.....Retired
    1998 BMW 540i Auto Black on Black......Retired
    Feb 2013
    Queensland Australia
    1998 2.8l z3 RED
    Just did it, cost $9... found $3.50 under the drivers seat! Passenger side was a pain cause the is a sub amp behind the seat made life a little tight while fitting. Seats much better for my height 6'.
    ʎɐqǝ uo pɹɐoqʎǝʞ ɐ ʎnq ı ǝɯıʇ ʇsɐl ǝɥʇ sı sıɥʇ
    Dec 2007
    Great Dismal Swamp
    E36/7 E36/8x2 E46 F25
    A frontal impact is not the concern here. As long as the rear fasteners hold, the new hardware will be loaded in compression. This is not a concern as long as the bearing area is the same or greater than before. My concern is a side impact. The seat rails will be loaded in torsion rather than tension, so the rear anchors will not be helping the front. The risers introduce two hinge points at the joints. A little bit of give in the sheet metal base and rail can result in a pretty large seat movement. How much, and how critical it would be to seatbelt operation... I have no idea. So I'm still on the fence with my car... I could certainly use the added height.
    Jonathan is spot on on the grade 8. Grade 8 can not be used anyplace that is subjected to a bending load.
    /.randy
    Columbia, Worst Carolina
    2000 M-Coupe, 1994 SE-R
    Just got back from a 4-hour drive (each way) and paid close attention to leg fatigue. At 5' 7" I didn't think I'd suffer, but I do. I'm going to order some of these. Jonathan, do you prefer I order on the website, or e-mail, or how?
    Supporting Vendor
    Jan 2005
    Haymarket, VA
    '99 M Coupe
    Quote Originally Posted by BenFenner View Post
    Website please! Shoot me an email (see signature) if you need help.
    I've place order #1223 via the web site. Thank you Jonathan.
    Oct 2012
    Louisville, KY
    1997 BMW Z3 1.9L 5MT
    Quote Originally Posted by rf900rkw View Post
    A frontal impact is not the concern here... My concern is a side impact... The risers introduce two hinge points at the joints. A little bit of give in the sheet metal base and rail can result in a pretty large seat movement. How much, and how critical it would be to seatbelt operation... I have no idea... Grade 8 can not be used anyplace that is subjected to a bending load.
    So the longer front seat riser bolts no longer bolt the rails directly to the floor, but create a hinge point at the floor and at the rail. In a side impact, the seat moves sideways on the hinge points, bending the bolts, which are strong in tension but not in torsion. So the front riser bolts might break and the seat would be left with the rear bolts only.
  1. Does anyone have any extra Leatherique for black interior
    By outkastaliens in forum Car Detailing and Show & Shine Prep sponsored by Autogeek.net
    Last Post: 10-05-2003, 10:46 PM
  2. Does anyone have any extra Leatherique for black interior
    By outkastaliens in forum Southeastern - US
  3. Replies: 3
    Last Post: 08-07-2003, 10:04 AM
  4. Does anyone have any cheats for NFS6?
    By Pepe240sx in forum Off-Topic
    Last Post: 12-24-2002, 03:33 AM
  5. Does anyone have any experience on this?
    By moonluv810 in forum 1992 - 1999 M3 (E36)
    Last Post: 08-29-2002, 03:28 PM
