Results 1 to 8 of 8
Thread: Finally installed my factory windscreen
    Tigard, OR
    1997 BMW Z3 roadster
    Well, almost 2 years after purchasing it from a member I finally got around to installing a factory windscreen in my hoopless '97.
    Pretty easy but my only kunundrum was that the brackets seemed to be labeled backwards. The one with the white "L" went on the passenger side and the one with the white "R" went on the drivers side. It was the only way I could see to make them fit, and matched what I saw in another thread. I might have messed it up, but they fit and work properly sooo.....
    Also as a side note, don't break the little tabs covering the screws behind the oddments box. I broke two of them and thay are about $10 each.
    Passenger side:
    Driver side:
    Finished:
    I guess I like blue....Focus ST & 1997 2.8i
    Oct 2012
    Louisville, KY
    1997 BMW Z3 1.9L 5MT
    [QUOTE=gbirkemeier;25971185... finally got around to installing a factory windscreen in my hoopless '97... only kunundrum was that the brackets seemed to be labeled backwards. The one with the white "L" went on the passenger side and the one with the white "R" went on the drivers side...[/QUOTE] They were labelled from the installer's viewpoint looking toward the rear of the car. To do otherwise would have been more confusing.
    Tigard, OR
    Quote Originally Posted by Vintage42 View Post
    I wondered about that. I guess that makes sense. Thanks.
    McLean, VA
    02 MC, 01 MR, 99 Z3C
    Total déjà vu for me as I performed the reverse procedure a few years ago when I uninstalled the Type II screen from my 97 Montreal Blue in order to retrofit roll hoops. For some reason my mounting posts were labeled the opposite as yours.
    Those little screw covers are now $10? That must be the most appropriate name ever as they were about $5-6 when I did it.
    Kelvin
    Tigard, OR
    Quote Originally Posted by KBH22102 View Post
    Your thread is what I referenced to figure out why L&R were backwards. I finally just decided to match the positioning on your picture and figured someone had labeled my posts wrong.
    The funny thing was, I broke the left and center screw covers, so when I went to order them I had to stop and think do I order the left (passenger) or right (to match the posts) screw cover. It was $8 for the left and $10 for the center.
    Nov 2011
    West Chester, Pa
    1997 BMW Z3, 2009 550i
    Geez... I would love to get one of those screens! where can they be had?
    Tigard, OR
    I got mine from a forum member a while ago, but as I was ordering the replacement screw caps that I broke, I found this on ECS Tuning:
    http://www.ecstuning.com/BMW-Z3-2.8-...ible/ES196334/
    So it looks like you can still get them new.
    Nov 2010
    Vancouver, BC, Canada
    2002 Z3 3.0i
    I've got one that I have been wanting to part with. Brand new, never used. PM me if you're interested.
    _____
    5
