Results 1 to 6 of 6
Thread: E46 M3 6-speed swap into an M Coupe
    Mar 2011
    South Carolina
    E36 M3, E36/8 M Coupe
    http://www.eatsleeptinker.com/2013/0...-e368-m-coupe/
    Let me know what details I might have left out, or what question you may have. I want to make this helpful to others, since I wasn't able to find much in the way of a consolidated how to.
    Bear in mind that my car is undergoing quite a few other modifications, so I haven't had the opportunity to drive it yet. Fingers crossed.
    Greenville, SC
    Several
    Thanks for doing a write up. It's one of those things I'd consider doing in the future.
    "If the Corvette is a rebellious child of the extended automotive family, the M coupe is the blackest of sheep." - via Car & Driver
    Salem, Nh
    01 Z3M Coupe
    great write
    next on my project list
    where did you get your drivshaft work done and was it shortened by 4"
    thnkd
    Mar 2011
    South Carolina
    http://www.driveshaftspecialist.com/
    I actually took measurements after installing the transmission. The shop wanted specific measurements before they would do the work. That said, everywhere I've read, it says 4". The driveshaft has a slip joint, so you can have some wiggle room.
    Kent, Ohio
    1998 M Roadster
    Nice write up--makes it look simple. So, what was your total out of pocket for this job, and a detailed cost breakdown?
    Mar 2011
    South Carolina
    Quote Originally Posted by Mr Bingley View Post
    Really the hardest part is removing and reinstalling the transmission, so the difficulty level is really no different than a clutch job.
    I used http://car-part.com to find a low mileage transmission. Expect to pay $2-2.5k plus freight.
    The other parts were from Bimmerzone.com. Just email Vincent and he'll give you the prices. I don't want to say exactly the cost, because his prices might have changed.
    Somethings I did aren't absolute requirements (RE SSK, Delrin bushings, RE transmission mounts, clutch lines, flex coupling) but nice to take care of while at it.
