Can a 'knowledgeable" (of course every one here is) person tell me the difference between plugs
ie: what is the difference between NGK BKR6E and BRK6EK and BRK6EQP?
I HAVE 4 BRK6E 's can I use them in my 96 1.9/5 133,000 miles?
tnx daniel
BMWCCA # 12660 (got my 35 year pin in the mail)
PCA 30 Years..........
X5 06 3.0 Saphire Black/Tan-- Ours
Z 3 01 2.5/5 Topaz/Tan (was 96 Silver)-- Mine
911 (997S) 06 Cab/Tip Guards/Black -- Hers/Ours?
Use NGK BKR 6EQUP.
The BRK6E has a 1-ground electrode, and the BKR6EQUP has a 4-ground electrode. NGK lists them for the 6-cylinder engines but not the 1.9.
http://www.ngk.com/ngk-aut-c1411.aspx
The only plug that NGK lists and recommends for the 1.9 is BRK6EK
http://www.ngk.com/product.aspx?zpid=9332
This is not because plugs like the 4-ground BKR6EQUP or 1-ground BKR6EIX Iridium will not work in the 1.9. They work but do not have the correct resistance which can cause misfires and is also hard on the coil.
The 2-ground BRK6EK is the only plug that NGK itself recommends for the 1.9 engine. NGK emailed me that the BKR6EK is specifically made for the 1.9 -- with a 6.0mm firing position, two ground electrodes and a 1K ohm internal resistor to be compatible with the output of the 1.9's coil pack.
The other plugs that NGK lists for the 6-cylinder engines have 5K ohm resistors, compatible with the individual plug-mounted coils of those engines.
NGK said the 5K-resistor 6-cylinder plugs may cause random misfires in the 1.9.
Had E3's Miss fired and had a harsh studder aroud 2k and over 5k....switched to BKR6EK as NGK Reccomended, No more miss fires no more studders and hickups...Put in the BKR6EK and You will Be happy
