Results 1 to 6 of 6
Thread: Glove box "quick and dirty fix ?
    Jul 2012
    Ft Lauderdale FL
    06 X5, 06 911, 01 Z3
    I was looking at the glove box 'droop" and thinking...hmmm..why cant I drill a hole thru the plastic into the steel metal behind the top (alongside the latch) and put a sheet metal screw through there to hold the top of the frame up and that looks like it would keep the door up closer ?
    BMWCCA # 12660 (got my 35 year pin in the mail)
    PCA 30 Years..........
    X5 06 3.0 Saphire Black/Tan-- Ours
    Z 3 01 2.5/5 Topaz/Tan (was 96 Silver)-- Mine
    911 (997S) 06 Cab/Tip Guards/Black -- Hers/Ours?
    Dec 2008
    California
    Z3 2002 3.0 Roadster
    Quote Originally Posted by dak911 View Post
    Really not sure what you are suggesting but one fix is to remove the heavy factory metal bracing in the door, that goes a long ways into fixing the
    sagging and rattling, many here including me have removed the factory bracing and installed the glove box fix (support). There are threads and post
    about removing factory bracing.
    Rochester, NY
    99 M Coupe, 02 Z3 2.5
    When I got the roadster, someone had done exactly what you describe to it. It worked I guess but I knew it wasn't right. I pulled everything apart (had to do it anyway to adjust the blend door) and fixed it the right way with a steel reinforcement bar. I also removed the bracing at the same time. Once I had it apart and looked at what the screw was in to, I don't think it would have been a long term solution. I believe it would have failed. I made my own bar. It cost me about $3 from Lowes.
    1999 M Coupe Boston Green, Beige, H&R/Bilsteins, Underdrive Pulleys, Euro 6 speed, UUC SSK and Randy Forbes in the back
    2002 2.5 Z3 roadster Oxford Green, auto, all stock
    2013 Ram 3500 Crew Cab Dually 385 HP, 850 ft lbs torque at 1600 rpm, all stock and staying that way
    2004 Mini Cooper Chili Red, daily driver, modified almost daily
    Jul 2012
    putnam, ct
    Z3lda-Crash/burned RIP
    Quote Originally Posted by Wertles View Post
    Have any kind of sketch as to what the bar needs to look like (before I pull mine apart to do the same thing) Thanks
    Z3lda - R.I.P. 7/6/13 crashed and burned, total loss.
    May 2012
    New Bern, North Carolina
    2001 BMW Z3
    Try here: www.schneebergerdesigns.com/help He has the instructions and the parts already made up.
    Rochester, NY
    There is a pic in post 112. This bar was aluminum, get steel. Cut off to length, mark with a marker where the 4 bolts come through, make slots large enough for the bolts to slide through, make a cut out for the latching mechanism and you are ready to go. I made all the cuts with a jig saw. It becomes perfectly clear what to do once you have pulled the glove box out. It took $4 from Home Depot or Lowes for the bar and 15 minutes with a marker and jig saw to do the whole thing. In that thread, I posted before and after pictures on how mine turned out (page 2).
    http://forums.bimmerforums.com/forum...1752210&page=5
