My '01 Z3 roadster is wonderful, EXCEPT:
The dial controlling the temperature breaks every time I move it! My mechanic has torn down the console twice, with no success, and the dealer had a shot at it, with similar results. I Have been told by both that the offending unit is on back order throughout the country. My mechanic, in whom I have great trust, is going back in for one more time.
I'm not surprised, so much, by the heater problem, it was a well known weakness with the 318ti, which uses the same setup; but I am amazed by the difficulty in repairing it and the unavailability of a replacement part. I searched the forum, but found no thread on this. Am I the only one who can't drive my Z in this gorgeous Autumn weather because I have no heat?
Try searching on HVAC. Lots of threads. http://forums.bimmerforums.com/forum....php?t=1790865 is a good link.
Here is the true fix for the problem. Plan on about an hour unless you want to fix a sagging glove box then add a little more. I've done it to both cars and they move smooth as warm butter.
http://www.bimmerfest.com/forums/sho...r+cable+adjust
1999 M Coupe Boston Green, Beige, H&R/Bilsteins, Underdrive Pulleys, Euro 6 speed, UUC SSK and Randy Forbes in the back
2002 2.5 Z3 roadster Oxford Green, auto, all stock
2013 Ram 3500 Crew Cab Dually 385 HP, 850 ft lbs torque at 1600 rpm, all stock and staying that way
2004 Mini Cooper Chili Red, daily driver, modified almost daily
Thanks to you both for pointing me in the right direction.
Mine broke a couple times. Fixed it twice. Now I really have to ease my way over to red. Sometimes going back and forth, very fluidly and slowly until I get there. No problems now that I'm super careful with it.
I'm working on this right now. The Z is apart and I have found the blend door lever. I have managed to move the cable about 1/4" in the connector. I'm thinking about putting zip tie on the end of the cable so that it doesn't get moved back in.
2005 M3 Convertible -Silver Grey/Black
2022 740i -Tanzanite Blue/Cognac
2022 i4 eDrive40 -Portimao Blue/Black
2022 i4 eDrive40 -Dravit Grey/Cognac
I thought about that too but didn't end up doing it. When you see how much force is required to move it, you will probably come to the same conclusion as I did. It would be a waste of a zip tie. Best advice I can give is after you have adjusted it, leave it on cold overnight before putting everything back together. Check to see that it is still smooth in coming off cold in the morning. I am glad I did because I needed to move the cable a little further then all has been fine since. I even have a little more heat than before I adjusted it.
Chris, it only takes 2-3 mins for my blend door to stick on full cold. I did end up buttoning it up, with the zip tie. However, if I moved the cable any further, it would probably start blowing hot when the knob is in the blue position!
Here's some pics of where I left it at:
with zip tie:
and my little trick to eliminate glove box squeaks:
Al.
Mine ended up in the same position
Ben, no it's not easy to access the door. it's inside the heater box and the whole dash must be removed to access it. It's a serious design flaw if you ask me.
