Results 1 to 25 of 64
Thread: Someone make us this:
    Mar 2011
    Earth/Side 7
    RX-78-2, RX-93v
    Cleaner PA knows exactly what I'm talking about
    http://forum.miata.net/vb/showthread.php?t=214062
    Little Rock, AR
    98 Roadster 2.8L
    YES!!!! My Roadie needs this!
    Mar 2011
    Earth/Side 7
    RX-78-2, RX-93v
    Quote Originally Posted by kojohns View Post
    No need for a SS rear or side brace with this, as it would directly address the weakest part of the chassis (transmission tunnel area). Dane Kane said he had something like this, I'm waiting for him to get back to me...
    Kansas City, Missouri
    89 750iL | 06 M5
    I would buy that in a heart beat
    Superior, CO
    M Coupe, M3/4/5, E30
    Me too! It would need to bolt into something sturdier then the little studs that hold the heat shielding on though.
    Cloudbase aka Alex
    Life on the Lee-Side BLOG, Hang Gliding YouTube Channel
    Little Rock, AR
    98 Roadster 2.8L
    To me... would need to be a through floor or through frame rail installation to be effective.
    Mar 2011
    Earth/Side 7
    RX-78-2, RX-93v
    http://www.flyinmiata.com/index.php?...umber=13-69920
    Looks like the real deal, and it would bolt to custom frame rails (included in the kit) and not the control arm itself. Apparently a VERY popular upgrade for the Miata, and so successful that Mazda made a similar OEM piece for the NB chassis.
    San Antonio
    Z3M Coupe & Roadster
    Maybe Vorshlag, can take up this task if they still have that Z3 LS1 Roadster in their shop..
    Little Rock, AR
    98 Roadster 2.8L
    Yeh - this definitely needs to be a 'through the floor' bolt on installation. From Flyinmiata site... "28 holes need to be drilled for installation."
    Austin, TX
    2001 M Roadster
    I would buy that in heartbeat.
    Edit - I'm less inclined to be drilling holes through the car, though...
    Little Rock, AR
    98 Roadster 2.8L
    I love the fact that the central section can be adjusted and removed for easy clearance and access to the tunnel.
    SF Bay Area
    '98 M Roadster
    A buddy of mine has the FM setup on his miata and it seems to work. He found the biggest improvement in the frame rail caps, apparently the cross brace didn't make enough difference to warrant the loss in ground clearance (his car is at stock height fwiw). I've wanted a setup like this for my z since I bought it.
    The District
    S54 e36/8, X3 M40i
    Yes, lets add weight to our cars!
    Dane Kane's stuff was a joke.
    Austin, TX
    2001 M Roadster
    Quote Originally Posted by fmcfad01 View Post
    Quiet, roof jockey!
    Little Rock, AR
    98 Roadster 2.8L
    Say's the coupe owner... take a spin in a roadster some day... they need some help!
    San Antonio
    I e-mailed Matt@Vorshlag, if I get a reply I'll keep y'all posted. Or maybe they'll chime in here.
    Little Rock, AR
    98 Roadster 2.8L
    Maybe MotionMotorsport as well? Definitely needs to be stainless steel though like this one for the Miata.
    Mar 2011
    Earth/Side 7
    RX-78-2, RX-93v
    Except roadsters are lighter than coupes, and this weight is placed as low down on the chassis as possible. As for it's effectiveness, apparently Mazda thought it was effective enough to make it an OEM piece. Speaks volumes for me.
    Quote Originally Posted by JWin View Post
    Quiet, roof jockey!
    What he said!!!
    Jun 2004
    Youngsville, Louisiana
    2001 M Coupe
    A full 4' x 8' sheet of 1/4" plate iron will still flex and twist if welded to the bottom of your car. A proper roll cage is a far better idea. Look at a bridge or any race car for that matter.
    -Ed Hands
    MaxPSI Stg2 Turbo
    R.Forbes magic F&R
    100K Original owner miles.
    Proud member of the BF.c FI - Big Torque Club (>500wtq Dyno Results)
    The District
    S54 e36/8, X3 M40i
    Quote Originally Posted by E.Hands View Post
    This.
    Fine, then I edit my first statement: Get a coupe.
    100lbs difference as far as I can google...nbd.
    atlanta
    Dinan BMW M ROADSTER, FERRARI 355/ E46 M3
    $399 for the Miata. It'll be $1299 for the M roadster.
    drive it like you stole it
    Mar 2011
    Earth/Side 7
    RX-78-2, RX-93v
    Quote Originally Posted by madturk View Post
    This.
    Who said for them to use iron?
    Little Rock, AR
    98 Roadster 2.8L
    You are exactly right... bridges are not made of flat stock, they are made of extruded I-Beams and Angles.
    A key part of the design is that it's not completely flat... it's made from bent sheet metal and welded T's... that's where the strength resides. Check out this picture showing the top side: http://www.flyinmiata.com/images/mis...s/IMG_0046.jpg
    Now - those spot welds may not hold forever - could have better welding.
    Yes - probably right - and at that price - I'll take the flex
    Mar 2011
    Detroit, MI
    1999 M roadster
    Pretty sure I could have these built..... Let me check.
    Stainless steel I assume?
    -Andy
    Bay Area Cupertino/pdx
    2001 z3 coupe
    I have a friend with the FM brace and it does make a huge difference for torsional rigidity. A lot of these cars are daily driven and something like this makes a whole lot more sense for practicality over a full cage, granted a cage will give you more stiffness. I have the whole roof thing going for me, but I could see this as a pretty good upgrade for roadies at the right price.
    Brad C.
