Results 1 to 8 of 8
Thread: Center Support Bearing
    Aug 2011
    Florida
    1997 M3/4/5
    I'm having some trouble finding a CSB for my 1998 2.8 (non-tu) manual Z3 roadster. Pelican seems to have CSB's for all models except mine. Does anyone know if any of these CSB's are interchangeable with mine?
    http://www.pelicanparts.com/BMW/cata...SUSaxl_pg2.htm
    Aug 2003
    Dallas, TX
    Z3M, X5M
    If you find out that they're interchangeable, I believe I have a new M on in my box of parts.
    -Phil
    Sep 2009
    Murphy, NC
    '01 Z3 3.0i Roadster
    Have you run the part number on RealOEM yet to see what applications it is used for?
    Part 26121229089 (Center Mount) was found on the following Z3 vehicles:
    Z3 Z3 1.9 Roadster, M44 (CH73) : DRIVE SHAFT-CENT.BEARING-UNIVERSAL JOINT
    Z3 Z3 2.5 Roadster, M52 (CH93) : DRIVE SHAFT-CENT.BEARING-UNIVERSAL JOINT
    Z3 Z3 2.5i Roadster, M54 (CN33) : DRIVE SHAFT-CENT.BEARING-UNIVERSAL JOINT
    Z3 Z3 2.8 Coupe, M52 (CK53) : DRIVE SHAFT-CENT.BEARING-UNIVERSAL JOINT
    Z3 Z3 2.8 Roadster, M52 (CJ33) : DRIVE SHAFT-CENT.BEARING-UNIVERSAL JOINT
    Z3 Z3 2.8 Roadster, M52 (CH33) : DRIVE SHAFT-CENT.BEARING-UNIVERSAL JOINT
    Z3 Z3 3.0i Coupe, M54 (CK73) : DRIVE SHAFT-CENT.BEARING-UNIVERSAL JOINT
    Z3 Z3 3.0i Roadster, M54 (CN53) : DRIVE SHAFT-CENT.BEARING-UNIVERSAL JOINT
    Last edited by dkindig; 08-30-2012 at 12:41 AM. Reason: ETA; RealOEM part # application search
    SF Bay Area, CA
    BMWs: 1; MINIs: 1
    I like the unicorns.
    '99 Z3 Coupe - Jet Black/Black (1-of-114)
    '99 M Coupe - Estoril Blue/Black (1-of-82)
    '03 540iT - Sterling Gray/Black (1-of-24)
    '16 Z4 sDrive35i - Estoril Blue/Walnut (1-of-8)
    Wichita, KS
    1997 BMW Z3 2.8L Roa
    Use this link for the part number:
    http://bmwfans.info/parts/catalog/Z3/
    Then use this link for the OEM part:
    http://www.trademotion.com/partlocat...?siteid=214760
    The prices on that website are pretty good.
    I would normally say email vincent at info@bimmerzone.com but I haven't been able to get him to respond to my emails for the last 3 weeks. He can usually get good prices on any OEM part but I tried to get break pads and a cam position sensor from him and never got him to respond.
    1997 Z3 2.8L Montreal Blue/Beige Ext. Leather.
    Hybrid Legatia L6 - Arc Audio 4150 XXK,
    Hybrid Legatia L1 Pro - Arc Audio KS300.4
    Image Dynamics ID8 - Arc Audio KS300.4
    Eclipse CD7100
    The District
    S54 e36/8, X3 M40i
    That's weird, he replies to me almost instantly. Just bought 2 front wheel bearings for the m5 yesterday. Give him a shout, he almost always has the lowest price when I shop around.
    Kolob
    Horse drawn chariot
    I encountered the same problem when I did mine last month .
    "My man did you simply get carried away with your dramatic gesture or were you pointing your water gun at me with lethal intentions ?"
    Jul 2012
    Lansing mi
    Z3coupe
    Quote Originally Posted by JoshS View Post
    So it looks like the M and non-M versions of the center support bearing are different?
