Results 1 to 7 of 7
Thread: Roadster Trunk leak?
    Apr 2002
    Florida
    Coupes...
    So I got some massive water intrusion from washing the car in the trunk.
    I had several inches of water in the battery hole.
    So I pulled a couple plugs and the water doesn't appear to have returned.
    However, the tire iron seems to show some signs of corrosion so this may not be a new occurrence.
    How the hell do I get the spare tire connector and stuff out of the trunk on the roadster? I mean to completely remove all the crap so I can see the trunk floor?
    Randy? Got some step by step instructions?
    White is Right, Steel Grey is OK, but Estoril is the only color that truly matters.
    I like Coupes.
    Mar 2012
    Blackwood, NJ
    96 Z3/ 04 325/ 11 X328
    remove the carpet in the trunk
    remove your tools
    remove the plastic tool holder
    use the spark plug tool to loosen the nut on the black dome holding the tire
    remove the black dome
    push the two spring clips in
    the tire will fall from the bottom along with the metal holder
    Watch your FEET! lol
    this is how mine was, i'm not sure if your is the same.
    I'll make a video if you need.
    By the way, I believe mine started leaking where the third brake light is. I'll have to track it down.
    Little Rock, AR
    98 Roadster 2.8L
    Quote Originally Posted by KillerSE7EN
    +1 This is where mine leaks... there is a large o-ring-like seal that goes around the 3rd brake light.
    SW Florida
    99-01 M Cpe & Rdts, X5M
    To completely remove the carrier, you have to remove the steel cable (handle) you use to lower the assembly.
    At the base of the cable, you'll see a "hex" you can put a small wrench on to remove the cable from the "stud" or whatever you want to call it.
    Apr 2002
    Florida
    Coupes...
    Quote Originally Posted by Randy Forbes View Post
    Is it a permanent thing or can I re-assemble it later?
    I like Coupes.
    SW Florida
    Quote Originally Posted by mpire View Post
    If you don't break anything taking it apart, you can put it all back just like it was.
    Apr 2006
    IL - 60499
    99 M Rdstr, 92 325ic,
    I am looking for a thread how to remove the rear carpet and came across this thread. When I took out the spare tire it looked like it was never taken out. The mud was level with the top of the tire. Poor Z3 had to haul around 15lbs of dirt everywhere it went.
    And thanks for the tip Randy. It took me a while to figure out how to removed that small little hex. I was a few minutes away from cutting the damn cable. While i saw this post after the fact, i am sure it will help someone.
