Results 1 to 3 of 3
Thread: S54 Oil filter housing/ oil cooler/ sensors
    Aug 2012
    Atlanta, Ga
    98 MZ3
    I picked up one of Turner Motorsports oil cooler kits with the modified S54 housing.
    The two front ports are modified to run to an oil cooler, the back port that was once an M12 x 1.5 was modified for the vanos oil line leaving one M12 x 1.5 port for both oil temp and pressure sensors.
    I'd like to run one of the sensors with a -10 fitting in oil line, but all I can find is a -10 with a 1/8" NPT fitting (Russell 670360), and can't seem to find a 1/8 NPT (male) to M12 x 1.5 (female) adapter.
    For those running the Turner kit how are you mounting both sensors?
    I may end up returning the filter housing, getting the un-modified version and buying Randy's adapter block, but I'm trying to avoid returning anything.
    This is probably the solution:
    http://store.bimmerworld.com/oil-dis...ock-p1250.aspx
    Feb 2002
    Houston, Tehas
    99 Mcoupe
    Quote Originally Posted by carnut169 View Post
    That's how I'm running.
    Nov 2005
    SOCAL
    e36 325i 5MT, e36 M3 5MT
    Is that a really good solution for oil temp?
    You would think that there wouldn't be any cross flow to get accurate oil temp, so the oil temp would read static heat instead of actual heat.
    www.mr5racing.com
    2001 BMW 330ci 5MT (Sold) -- 2003.5 BMW M3 6MT (Sold) -- 2007 BMW 335i 6MT [441 whp 483 wtq (not stock)] (Sold) -- 1994 BMW 325i 5MT [202 whp 178 wtq (not stock)] -- 1999 BMW M3 5MT [263 whp 233 wtq) (not stock)]
