Driving along and all of a sudden the oil temp gauge is reading 120 (car was warm and previously sitting under 200) By the time I was home it was back under 200 as normal.
Im guessing it might be a loose ground or something? Just wondering where it is tapped in to so I can look around and make sure everything is OK.
Also how long does the oil level light normally stay on for? I used to never remember seeing it and now it seems like it stays on for a second or two past the normal startup lights. It does not stay on. Oil level is fine.
Thanks,
Sam
Having similar issues now. Did you resolve this?
The oil level sensor and oil temp sensor are one and the same. It's going bad and time to replace. You have to drop the x-brace and drain all your oil to access it as it is on the bottom of the oil pan.
Mine is doing the same, but my oil is new, so i'll change it out next oil change.
Current:
2001 S54 M-Coupe
2011 Mini Cooper Countryman S
94 Grand Cherokee Laredo 4.0L/242 TC (Daily)
Past:
95 325i Convertible/Boston Green
01 330Ci Convertible/Steel Grey/Stick
05 Infiniti G35 Premium/Tech
