Results 1 to 25 of 25
Thread: Rims!?
    May 2012
    Fayetteville,Arkansas
    00 roadster
    Rims!?
    is it possible to fit 17×9 tires:205/40/17 at the front of a 2000 roadster without doing any modifications ?
    Aug 2008
    Sunny SoCal
    E368x2 / F15
    1. Yes depending on offset. Even the stock rear roadstars at et8 will fit up front with 205 tires.
    2. What in the world makes you want 9" wheels with 205s up front? How about a 9" wheel with a nice meaty 255. Yep. That sounds better.
    May 2012
    00 roadster
    i want to put my m roadster wheels in the front as well as the back. I want a meaty tire but also as low pro as i can.
    i want rims like these front wheels in this picture, they've taken the factory rear wheels and placed them on the front. And taken the factory front wheels and widend them to 17x11. I dont want to widen anything on my car. I just want four 17x9 rimes all the way around.
    Arkansas, USA
    95 240SX|98 Z3M|05 Elise
    I understand where you're coming from but I think Msilvia is right, too.
    Go with the same size tire all around, and get more tire up front. With 205s you are leaving lots of empty rubber room.
    Stock fronts on an M roadster are 225. Why fit something more narrow than that?
    I think a 245 would probably fit, and that's what the stock 9" rear from an M has on it.
    So why not just go 245 all around if you want to put rear roadstars on the front anyway?
    Aug 2008
    Sunny SoCal
    E368x2 / F15
    Due to the offset, you can't fit anything over a 205/215 if fitting roadstars to the front of the vehicle.
    To answer your question kmcc...yes they will fit up front with a 205. Don't do it though, stretched tires ride like crap. First hand experience; in the end it is your car so do whatever you please
    kalamazoo, michigan
    99 M Coupe, 99 528iT
    Quote Originally Posted by kmcc View Post
    you're wanting to run the factory rears on the front, with no modifications?
    Im assuming from the fact those fender liners arent banged to bits, that this car is rarely (read: never) actually driven. Does it actually LOOK to anyone like this... fits? Without modification?
    Good luck
    Mar 2011
    Israel
    2000 s50b32 M Coupe
    Don't forget that in order to at least look right, like in the photo, you must lower the car. A lot.
    kalamazoo, michigan
    lowered a lot, tons of negative camber, trimmed fender liners
    ^ and expect to have similar tire marks on the inside of your hood like that as well
    Looks cool, just be prepared for the modifications/consequences!
    (I've been planning on doing a rears-up-front setup for a while as well; going to try rears widened 1" on the outside edge for the rear setup. Definitely going to be a secondary set of wheels, i wouldn't DD that front setup)
    PDX
    Millenium Falcon
    Quote Originally Posted by 2000mkoop View Post
    I would be inclined to get the fronts widened a bit, as long as you're already going that route on the rears. Rears in the front just fit so bad.
    kalamazoo, michigan
    Quote Originally Posted by Kyle Anderson
    Unfortunately the fronts can only be widened on the backside, so no added visual, and you'd have to use a big spacer.
    You could potentially cut 1/2" out of the outside lip of a rear, haven't looked into that yet. You'd end up with 8.5 et14ish, pretty doable with camber plates.
    Maybe ill try throwing a rear on the front this week with camber plates at max negative , see how it looks in person
    Chicago
    Yellow Pants
    jesus, not this again.
    kalamazoo, michigan
    Quote Originally Posted by hexagone View Post
    lol
    Wilmington, NC
    2000 Mcoupe estoril blue
    To the OP, don't forget that guy is probably on air ride, so he can raise it to actually drive it and then let out all the air when parked to "show off". If he is not on air ride and is static, then he's got some balls
    If you do run the 17x9 et8 all around, running a spacer in the back might make it look a little more proper. Otherwise, you'll have a ton of poke out front and little to none in the rear.
    - bill -
    Nov 2010
    Just make sure that you don't end up looking like this douche: http://forums.bimmerforums.com/forum....php?t=1734180
    Quote Originally Posted by kobayashi View Post
    I remember those from back in my E39 days.... those were Jason's wheels. Not sure who the E36 guy is who has them now though.
    Kolob
    Horse drawn chariot
    Gotta love that "aggressive set up" smdh.
    Pardon my grammar and lack of smileys Sent from my iPhone using BF.com
    "My man did you simply get carried away with your dramatic gesture or were you pointing your water gun at me with lethal intentions ?"
    May 2012
    00 roadster
    those rims looked awful on that sedan. but on the m roadster they look completly different. His wheels dont look even. the look cock eyed. but on the m roadster they look amazing?
    so what would it take to achieve the look of the m roadster wheel setup of 17x9 all the way around?
    Mar 2011
    Earth/Side 7
    RX-78-2, RX-93v
    Running M roadster wheels F+R with pulled fenders and stretched tire. It's a lot of work to be slower.
    Quote Originally Posted by Amuro Ray View Post
    Shouldnt matter if its slower, since Z3s are already the slowest cars ever produced by any manufacturer ever, correct?
    Mar 2011
    Earth/Side 7
    RX-78-2, RX-93v
    Quote Originally Posted by blackxs View Post
    Probably.
    You and another member on here are really trying to get under my skin. Grow up and realize it's just a car, and stop taking it personal.
    kalamazoo, michigan
    i'm sorry, did you think this was for a track setup? lol
    Mar 2011
    Earth/Side 7
    RX-78-2, RX-93v
    I would never purposely make my car perform worse, it's a hard concept for me to grasp that others might want to.
    Mar 2011
    Earth/Side 7
    RX-78-2, RX-93v
    USA
    Lotsa ///M's
    I think it looks good. But its hard to believe those fronts on that M roadster are 205s. Granted I understand different tires and what not but off one of the tire stretch sites. This is a 205 on a 9.
    And this is a 215 on a 9
    I know I am reviving a old thread but I actually thought of doing this, so if anyone has some more info let me know.
    Current:
    15' F82 M4 (soulless beast)
    12' e92 M3 (clean daily)
    09' e92 M3 (track whore 3.0)
    06' E46 M3 (ZCP YUM)
    02' e36/8 M coupe
    01' e36/8 M coupe (the chosen)
    99' e36 M3 (spoiled)
    99' e36 M3 (track whore)
    99' e36/5 (chump 2.0)
    95' e36/5 (chump car)
    90' e30 M3 (track whore 2.0)
    88' e30 M3 (Diamondschwartz eurospec)
    88' e30 M3 (broke my wallet)
    And a few P-cars nobody on here cars about lol
