I found a set of used wheels and tires, but the shipping is proving very expensive. We've inquired through UPS and Greyhound. The cheaper of the two is Greyhound, but they're still pretty pricey. How have you guys done it, and who was the cheapest way to go. We can just wrap them in plastic or something, right? I'm hoping there's no need to box them up. Thanks.
I just got back from fedex and they wanted $240 from California to New York for 4 wheels and tires. I brought one front wheel to them and it was 19x8.5 with a 235-35-19 tire and the weight was about 49lbs. So with that estimate the informed me it would be about $240.00. I hope this helps.
2001 BMW 330 CI
2006 Merc C230
i shipped a set via forward air terminal to terminal for < $200
Have you thought about letting the air out of the wheels to cheapen shipping cost.
I am sorry, I was unable to help myself, just the thought of someone doing that at the fedx counter.
Before the BAN HAMMER comes down on me I do have a serious suggestion. Try going to a tire store and ask them how to ship wheels and tires on the cheap. They might know.
Just like Tirerack ships;
Stick a label on it. Make sure you use 2-3 layers of hard cardboard to cover the front (face) of the rim so that it doesn't get scratched etc.
UPS Ground, each wheel should be like $25.
I use that method all the time plus use clear box take and just wrap the crap out of it. Cross country for my usually around $160 for a full set. Take some but not all the air out. to reduce some cost
I did the tire rack wrap and added some clear wrapping that I got in a roll from u-haul. FedEx Home was the cheapest method.
99 facelift E38 gone but not forgotten | 2001 Topaz Blue Z3 3.0 (9/00): ASA AR1's, Kicker sub, stone guards & more
RIP SMW (5.23.04) - We miss you sweetheart!
Did you think of http://www.uship.com/ ? It is a network of independent shippers that bid for loads. There is a TV show about some of them which I hope is not the cream of the crop. You are in Houston so depending on where your tires are it would probably be an easy and cheap add on for them. You might want to check it out. You might get lucky if it does not have to be on a tight schedule and find someone that is delivering something in your neighborhood.
What is the name of that tv show?
Shipping Wars![]()
+1 on Forward Air.
OEM coupe wheels with tires from Chicago to Nashville were $125. You have to take to their shipping location and delivery is to their shipping location not your front door but saved $100 so it was worth the slight inconvenience.
When I google'd best way to ship wheels I found http://howtoshipwheels.com
grayhound, srs I'm a wheel whore
When I shipped a set of tyres, I took them to a UPS package store. Staff v. knowledgeable & helpful. Game is to watch size & weight thus the best price for what I was shipping was to package them in pairs to get the cheapest rate. By the way you want to add air not take it out!
There is a link at the top of Wheels and tire for sale on this forum.
Shipnex rocks.... it's half the price of others.
Yeah, it was right around $150 for a set of 4 wheels. They were 19" with tires, and each box weighed about 50lbs each. UPS Ground is the way to go, although I used my company's UPS WorldShip Account, so there was a bit of a discount compared to just dropping it off at a UPS Store.
One wheel / tire face up, padding/cardboard, another wheel / tire face down on top. Tie together with industrial zip ties and ship with UPS. You'll get nailed with an oversize charge, but it's not a big deal as you'll only be shipping two packages instead of four.
What if you swapped air for helium?
BMW M3 - Ferrari 348 - Chevrolet Chevelle
A greyhound bus/freight is also pretty inexpensive if a terminal is convenient.
+1 on the cardboard and shrink wrap. As a caution, label the inside of the wheel if the outer 'wrap' gets lost. I've had one come up missing before and the inside label is the ONLY reason it was found.
