Results 1 to 25 of 60
Thread: Uh-oh.
    San Antonio
    Z3M Coupe & Roadster
    Uh-oh.
    Haven't checked any of the spot welds but I'll use my imagination (sound deadening is still in place).
    May 2010
    Orange, California
    01 BMW 330ci convertible
    Ouch.
    2001 BMW 330 CI
    2006 Merc C230
    Chicago
    Yellow Pants
    Time to sell it to me
    San Antonio
    Quote Originally Posted by hexagone View Post
    I should. I put the carpet back so I can ignore it a little bit longer. I sent Randy a PM to see what the cost is going to be and when he's ready in his FL house/shop :P
    I was just about to let the mechanic have it to replace the HG, install ARP studs, Euro oil filter housing, Driven Innovations Intake Mani, and finally RMS headers. After that I was going to install my smaller pulley and get it remote tuned by Technica Motorsports in GA. I'm afraid this is all going to have to wait just a little bit longer...(it's been long enough I've had the intake mani for over a year now..)
    So this came at a great time
    Ouch At least you caught it before your car was held on by the exhaust... still, very unfortunate.
    I get the feeling I am not the only one who scurried out to his car to double check their rear subframe after this thread
    Austin, TX
    2001 M Roadster
    That sucks dude. Good luck getting it sorted.
    Cincinnati, OH
    02 Mroady,2007 Z4 coupe
    Rechecked mine and everything is still pristine for now.
    Kansas City, Missouri
    89 750iL | 06 M5
    I see what is wrong, the underside of your car is filthy!
    Don't mind that crack...
    Z3speed4me's Avatar
    Z3speed4me is offline Coupe Cartel Forever! BMW CCA Member
    Apr 2002
    Westfield, NJ
    MCoupe, Q3, Tiguan
    All I have paid attention to thus far is DI manifold
    Sorry to see the subframe pain, I know that feeling, twice will you....
    ~Ken~ '99 M coupe THE "original" TT Stage 3 - HTA3586R; 701 whp 672 wtq @ 26.5 psi ; NeverSell - CoupeCartel
    Kent, Ohio
    1998 M Roadster
    Bummer, but we all face it sooner or later. I had Randy do mine about a month ago--he does such beautiful work--incredible attention to detail. Yesterday I went to instal a battery tender (trickle/float) and I noticed that my battery terminals and posts looked like new. Randy had cleaned them and wire brushed them--not just the mounting points, but each terminal and post completely. It sucks to have the problem, but it is so nice to know he is out there. What a pleasure to remove the carpet to get to the battery tray and see the reinforcement--just a little reminder that my car is perfect--better than new. This is what inspired me to jump on the VAC supercharger group buy--now my car can handle it. Whatever he charges, it is so worth it.
    Where did you buy the euro filter housing and cooler set up, and how much? I am in the market for one (to go with the SC), and want to be sure to get the best deal/set up.
    San Antonio
    I posted in the VAC S/C thread about the oil filter housing. As for the cooler I've had one in place, I'm getting rid of my Victory Product Design oil cooler cap (it won't fit because of my new manifold).
    I may be taking it to Vorshlag to get repaired. Check out the E30 they did:
    http://vorshlag.smugmug.com/Projects...Twi3&lb=1&s=XL
    modernbeat's Avatar
    modernbeat is offline Senior Member Supporting Vendor
    Dallas, TX
    Caged
    Quote Originally Posted by jajou318 View Post
    http://vorshlag.smugmug.com/Projects/E30-V8/9984510_6HwM6c#!i=903641985&k=jTwi3&lb=1&s=XL
    Ignore all the dirty bits. That was on the GRM $2010 Challenge car. That brace and diff held up to our healthy mix-and-match mongrel LSx engine. Too bad the budget driven V6-T5 didn't. Note that the trunk floor was also removed on that car. For most cars we'd leave the trunk floor alone.
    Since then that car got a flat trunk floor, rear camber-caster-toe adjusters welded to the subframe and a five lug conversion.
    If jajou318 goes ahead with the reinforcements we'll expose his dirty underside by taking lots of Vorshlag style pics for you guys.
    Jason McDaniel at Vorshlag
    Dec 2004
    Boston, MA
    M3, MZ3, 348TS, Chevelle
    Wow, that is quite robust looking! Specs on the material/stock used?
    BMW M3 - Ferrari 348 - Chevrolet Chevelle
    San Antonio
    Haha, well when I said I'd be up there to pick up some studs in the future I didn't think I'd be getting a subframe touch up!
    Aug 2011
    Florida
    1997 M3/4/5
    Quote Originally Posted by Itsablurr View Post
    yes i'm quite interested as well
    Dec 2011
    Santa Fe, NM.
    2002 BMW z3
    Were and what are we looking at.
    modernbeat's Avatar
    Dallas, TX
    Caged
    The Vorshlag subframe is made up from square tube except the heavy gauge landing pads on the frame rails. We're getting a price worked up for Jajou318. I think there are a lot of in-progress shots in the E30-V8 build.
    Yep, just looked it up. In the GRM E30 V8 gallery starting on page 46.
    http://vorshlag.smugmug.com/Projects/E30-V8/9984510_6HwM6c#!i=900926867&k=h5kUp
    Quote Originally Posted by lucky1963 View Post
    No need to quote the image
    Its in the rear, its the rear subframe trunkfloor. Peel up the carpet to take a look yourself. Look around the outside edge to check for popped welds or similar damage as pictured. Also a good idea to climb under the car and check where the shocks mount from the bottom of the car, these can also be problematic.
    San Antonio
    I will be taking my car to Vorshlag next Saturday!
    Aug 2011
    Florida
    1997 M3/4/5
    let us know pricing after it's done
    Dec 2004
    Boston, MA
    And pics!
    San Antonio
    Well I've already got an estimate. If you are curious you can PM me and I can discuss what I was quoted.
    I wish I lived closer to their shop. I will be dropping my car off on the 28th, flying back down and then flying up when it's ready. Tickets already purchased. I'm glad I'm finally taking care of this problem.
    Jul 2011
    New York
    E368 / E30 M3 / 997 GT2
    Dang. Good luck..subscribing for pics
    Fair's Avatar
    Fair is offline Senior Member Supporting Vendor
    Oct 2003
    Dallas, Texas
    E36 M3, E36 LS1, E30 318
    I will post up pics to this thread during the progress of the work. See you on Saturday!
    Again, the structure we're adding to his Z3 is going to be the same style we used on this V8 powered E30:
    More soon,
    Terry Fair @ Vorshlag Motorsports
    Corte Madera, CA
    2006 Porsche C2S Cab
    Terry anyway to view the thread photos as a gallery rather than clicking through all 400+ photos one at a time?
