Results 1 to 9 of 9
Thread: Washer pump issues
    Daytona Beach, FL
    2.5I Z3
    Washer pump issues
    About a week ago I discovered that my windshield wiper fluids ceased, I checked the lines and realized it was the pump that had quit working.. after replacing it today, no fluids continue to come out. I ran it for a few min thinking that there was just air in the lines and still nothing. Any suggestions??
    thanks
    Aug 2011
    Westfield, NJ
    '01 3.0L Z3, CT200h
    This happened to me and I found my line was pinched when the hood was closed. I put the line back into it's track and voila, everything started to work again.
    Daytona Beach, FL
    2.5I Z3
    thanks for the advice, i had everything still in the tracks.. just tightened them up and it worked!!
    Bethesda Maryland
    99 M Roadster/07 M Coupe
    I found the wires feeding power to the washer fluid motor were chaffed under the tank and shorted to chassis ground...
    Aug 2011
    Westfield, NJ
    '01 3.0L Z3, CT200h
    Quote Originally Posted by justentx76 View Post
    Awesome, Glad I was able to help. Guess that's a common problem!
    I took apart my whole system before finally realizing it was working when the hood was open and only failing when closed.
    Bunn, NC
    Z3 2.5i
    Windshild pump voltage?
    Does the pump run off 12v?
    SF Bay Area, CA
    BMWs: 1; MINIs: 1
    Quote Originally Posted by barroj View Post
    As opposed to what, belt-drive? :-)
    I like the unicorns.
    '99 Z3 Coupe - Jet Black/Black (1-of-114)
    '99 M Coupe - Estoril Blue/Black (1-of-82)
    '03 540iT - Sterling Gray/Black (1-of-24)
    '16 Z4 sDrive35i - Estoril Blue/Walnut (1-of-8)
    Spring Green, WI
    01 2.5i, 98 1.9 DASC & M
    Quote Originally Posted by JoshS View Post
    Transmission PTO or mid-ship transfer case?
    Yes 12v powers the pump. Sorry, I couldn't help myself.
    Jul 2010
    fayetteville NC
    !997 BMW Z3
    I have a problem that is unusual. The holder for the fuse that energizes the windshield washer has dropped into the bottom of the fusebox. Is there a way to fix this by wiring around the fusebox?
