Results 1 to 15 of 15
Thread: CDV Woes...2001 Z3 2.5i Confusion...
    Hendersonville, TN & UTK
    (OO=[][]=OO)
    I have been looking at all of the DIY threads regarding the deletion of the clutch delay valve on the Z3, specifically this one.
    I went out and picked up all of the necessary hardware and gathered all of the tools. When my brother and I went under the car to check for the CDV, we came up empty handed. We were surprised at this because while driving we encounter the symptoms of a car with a CDV. The first to second shift causes bucking along with the other symptoms, including delayed engagement of the clutch.
    We have a 2001 Z3 2.5i with the Getrag 5 speed transmission. I have included pictures I recently took below.
    From what I have read people say that the 2001 Z3 2.5i definitely has a CDV and not a restrictive clutch line. I find it hard to believe that the previous owner would have deleted it considering how they took care of the car, but it is possible.
    Any ideas? Learn to drive better? Flush the whole brake system? Take out the slave and flush it?
    We were planning on flushing the whole system anyway if we had taken out the CDV that we thought was there.
    '84 325e 32k miles | '98 328i 68k miles | '01 Z3 74K miles | '99 F150 64k miles
    PSN ID: Trevor-TC2
    We retrofit headlights, code BMWs, rekey locks and thoroughly detail cars. Interested or curious? PM us.
    Jun 2010
    Greensboro NC
    1999 BMW Z3 2.8L
    i think the stock rubber line has some swelling/ flex to it not giving accurate clutch response.
    i would put the SS line on anyway and see how it goes.
    Frank
    (OO=[][]=OO)
    Quote Originally Posted by Racerman27410 View Post
    Frank
    I don't have a stainless steel line to put on.
    I didn't state that I was going to swap lines, I was just going to delete the CDV.
    Anyone else have any input?
    I know underneath that the coupes and convertibles look alike, so someone here should be able to help.
    PSN ID: Trevor-TC2
    (OO=[][]=OO)
    Bump.
    Still looking for some insight.
    PSN ID: Trevor-TC2
    Jan 2012
    San diego
    1999 M Roadster
    For what its worth...and I realize this thread is ancient...my 2001 Z3 2.5 has the exact same line as yours. I was equaly perplexed when I climbed under mine to do the delay valve delete only to find that there didnt seem to be one...curiouser and curious-er
    Redding Calif
    1999 Z3 2.5L 5sp
    I have a 2.5, but a '99, have already bought the non-delay replacement... and given how it shifts, have always assumed that it had a CDV... will be embarressing to get under there to find just the hose. It would be interesting to have others chime in in terms of what they have (model, year) and if they found a CDV or not.
    Jul 2012
    Ft Lauderdale FL
    06 X5, 06 911, 01 Z3
    So, in general did the 01 2.5's (03/01 build date) have a CDV from the factory
    BMWCCA # 12660 (got my 35 year pin in the mail)
    PCA 30 Years..........
    X5 06 3.0 Saphire Black/Tan-- Ours
    Z 3 01 2.5/5 Topaz/Tan (was 96 Silver)-- Mine
    911 (997S) 06 Cab/Tip Guards/Black -- Hers/Ours?
    Feb 2012
    Orlando, FL
    2001 Z3 Roadie
    My 2001 2.5 Roady did not have a CDV.
    Redding Calif
    1999 Z3 2.5L 5sp
    Following up from previous post: embarrassingly, when I looked, no CDV at the slave cylinder found :-( but given the symptoms, either there is something intentionally built into the stock rubber hose btwn the master and slave cylinders, or just a swelling hose - sure feels like a CDV... when life get's out of the way and some time frees up, will simply replace the line down from the master cyl and the slave cylinder and see if the clutch action doesn't improve.
    Sep 2008
    Havertown, PA
    02 e367, 08 Acura TL-S
    Quote Originally Posted by gmushial View Post
    It may be that the line itself is restrictive. Only way to tell is to remove the line and compare the ID of each end. My stock line was obviously narrower at the top of the line in comparison with the slave side.
    -Todd
    Dec 2007
    Great Dismal Swamp
    E36/7 E36/8x2 E46 F25
    The CDV is nothing but a flow limiting valve in the release direction. It is NOT a delay valve. It's only job is to put a cap on the rate at which the clutch can apply. If your complaint is the tires don't lit up when you sidestep the clutch, the CDV is the culprit. For any other complaints, look elsewhere.
    /.randy
    Redding Calif
    1999 Z3 2.5L 5sp
    Where I notice the problem is: not being able to modulate the clutch upon release... but I'm going to replace the dated pieces with fresh hardware, and then if there is still a problem, go looking for it... but from what others have posted, suspect there is a 90%+ chance that doing such will resolve the matter.
    May 2013
    Boston, MA
    2001 M Roadster
    Quote Originally Posted by rf900rkw View Post
    English translation requested in layman driving terms ........
    Jul 2012
    Ft Lauderdale FL
    +1
    I think I am going to do the same, with a s/s line....easy enough...(and another bled to the DOT4 can't hurt)
    Minnetonka, MN
    02 996 cab, 08 E350
    Not being able to modulate the clutch release is a prime symptom of the CDV, and what drove me to replace my clutch line. The clutch now works perfectly, with a good feel to it.
