Here you go, hope this helps...
Low beam headlamp
Part number = 9006
High beam headlamp
Part number = 9005
Parking light
Part number = 5007 (1156 compatible)
Front turn signal
Part number = 7506 (1156 compatible)
Rear turn signal
Tail light
Stop light
High mount stop light
Part number = 2825 (194 compatible)
Fog/Driving light
Part number = H1-55W
License plate
Back up light
Front sidemarker
Rear sidemarker
Dome light
Part number = 6411 (41mm)
Trunk/Cargo area
Part number = 6418
Instrument-general
Part number = 2721
97 1.9 triple black...
Mods:
2K+ Clear corner headlamps...Clear bumper and blinker lights...Clear 3rd Brake light...Intrax 1.5" lowering spring...Superwhite LED all over...Brushed Aluminum Dash Trim...Short Throw Shifter...
2000 z3 roadster... I see the high mount stop light shows a 2825 bulb. My roadster doesn't appear to have a replaceable bulb. It appears the light unit needs to be replaced is this correct?
Now someone can correct me if I'm wrong but I believe the third brake light bulbs have to be soldered in place.
Yea.. Roadster 3rd brake light is just a bunch of 194 peanut bulbs... a lot of them!
Did you get this guide fromm Sylvania?
I have to check again, but I'll risk making an ass of my self and say the front turn signal is wrong. I believe stock should be a 1157 amber (double filament)... NOT 1156 single filament. That's why the corner lamp lights up dim when you turn on the parking light, and flashes brighter when you signal for turn.
If the Z3 is setup for city lights (europe/asia?) then the parking lights will turn on high a small bulb in the high beam reflector, and the corner ONLY has turn signal duties... in this case the 1156 would be appropriate.
Anyway, my point... is I believe US market Z3's use 1157 double filament bulbs for the front corner. (I'm shopping for some "stealth bulbs" for the front/rear turns, so I've been checking)
what about if you wanna change all bulbs to led?
Sent from my SAMSUNG-SGH-I747 using Tapatalk 4 Beta
Not EXACTLY a threat stealer but
One more ?, how to add foot well lighting in Roadster...the dome light is a waste
BMWCCA # 12660 (got my 35 year pin in the mail)
PCA 30 Years..........
X5 06 3.0 Saphire Black/Tan-- Ours
Z 3 01 2.5/5 Topaz/Tan (was 96 Silver)-- Mine
911 (997S) 06 Cab/Tip Guards/Black -- Hers/Ours?
The interior lights for Coupe is incorrect--there are two 43mm in the cargo area. These are the same as in the front interior light.
However, for LED conversion there is a ton of width available in both housings, so anything about 43mm long works--my OEM lights seem to be 2mm longer than listed above. They can be any width within reason--the length is the bottleneck. Based on that, I like these https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
They have an aluminum heatsink on the back, not like the other cheaper LEDs which are just soldered to an FR-4 PCB, so they should last longer. They have similar brightness to these loose-fitting ones without heatsinks: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I know this is an old thread, but I found it while looking for the correct trunk light in my 2001 Z3 Roadster 2.5i, so I figured it was worth updating.
My trunk light bulb was a 6411 (41mm), so make sure you check what you have before you order (unlike me). It's super easy to pull the light out.
Is there a generic 2 watt bulb replacement for the 3 VDO gauges?
Anyone know of a complete LED kit for Coupe interior?
Rear sidemarker lights are 5 watt wedge bulbs--194 compatible.
Wayne
1998 M Roadster
1994 Honda ST1100--sold
2017 Yamaha FJR1300ES
I just upgraded all my bulbs in a 2000 Z3M Roadster. Everything was 1156, 194 peanut bulbs, and the front turn signals were 1157. The single interior dome light was 36mm and the trunk was 41mm.
Well this is kind of a useless guide it doesn’t say how many bulbs are needed.
My 96' calls for h7 fog light bulb , P# 63216926911 or 63217160781, 63217160780
