Page 1 of 11 12345678910 ... LastLast
Results 1 to 25 of 264
Thread: Shift Pin Service - Tools for sale
    Batavia, IL
    00 M Coupe, 08 335xi
    UPDATE 2/17/2010
    Machine shop got the order this week. Expecting 4-6weeks for delivery.
    Cost has gone up - now $70 a set shipped.
    Taking names for now and will take payment when I have a firm delivery date.
    This spring, I complete the shift pin service on the transmision and have been very happy with the improvement in ease of shifting.
    I had the set of drifts made at a local machine shop and since then a couple of other people have enquired about the tools.
    The actual pins/sleaves/caps are approx $50 and you of course need to drop the trans.
    The two types of service are detailed here.
    SIB 23 01 02 (881)
    http://www.rfdm.com/Daniel/Transmission/transpinssib.pdf
    SIB 23 01 04 (063)
    http://www.rfdm.com/Daniel/Transmission/trans5thsib.pdf
    The 5 drifts are...
    5th Gear drift
    Reverse Gear drift
    5th/Reverse Cap drift
    Catch pin drift
    Catch pin Cap drift
    Dec 2005
    Sarasota, FL
    98 M Roadster
    If you can get single-sided drifts made for $60, I'll take a set. I had my father mocking some up in SolidWorks some time back, but he doesn't have much free time to spend in the machine shop at work lately. What material would the drifts me made from?
    Batavia, IL
    The drifts are just mild steel. I was able to use the double ended drifts with a plastic malet with no problem.
    The single ended drifts should be even better.
    Dec 2005
    Sarasota, FL
    98 M Roadster
    Are there any other choices for materials? Mild steel is probably fine for as much action as these would see, but I am curious.
    Batavia, IL
    Chicago, IL
    00 M Coupe
    I'd be interested in a set for that cost. I have been noticing more notches in my shifter lately and would like to be prepared in the future. Keep us updated, thanks!
    Minnetonka, MN
    02 996 cab, 08 E350
    Me too.
    Dec 2003
    Northern Va
    E36/8, K12R, E91
    Ditto
    2002 Alpine White w/ Black 368 (<OO \(||][||)/ OO>)
    Power: Custom Exhaust w/ High Flow cats, CSL headers, built, low-compression Supercharged and aftercooled S-54, ViPEC standalone ECU, Vortech V2 Si trim
    Driveline: Euro 6 speed, 3.64 diff w/ 40% Lockup, Rogue Octane SSK, UUC Red TME kit, UUC Stage 3 LTW Flywheel/M5 Clutch, SS Shift Knob
    Suspension & Brakes: TC Kline True Match Coilovers 500f/500r w/ adjustable camber plates, Racing Dynamics sways, Custom front sway endlinks, ATE fluid, UUC/Willwood BBK 6 piston f - 4 piston r , Slotted E46M3 Rotors, Stainless Lines, Strong Strut, IE Subframe & adjustable rear trailing arm bushings
    ICE & Misc: Projector Z's w/DDE & 5k HID, 19'' Gold HRE C20's, Custom Aux pwr outlet, footwell lighting, ACS Splitters, Areo Sideskirts, Custom gauge pods, Z8 Start, Pioneer AVIC Z3, Clarus Components, 10" RE Sub in a Mister-X Enclosure, Alpine PDX 4X150 + 1X600 Amps
    Coming soon: and a visit to Randy Forbes
    Mar 2006
    Pittsburgh Pa
    99 ///M Coupe / 95 Del sol / 95 Jeep XJ
    I'd probly be down for a set aswell...
    Feb 2008
    Palmdale, CA USA
    '00 ///M Roadster
    $60 shipped? I don't think that I could have a set made here (with my current contacts) for much less... plus it would save me the trouble...
    I'm down for that.
    I'm doing science and I'm still alive...
    Batavia, IL
    2002 Smurf Hearse
    Put me down as a maybe.
    jeremy [AT] coupecartel [DOT] com
    1 of 1 | 2002 Laguna Seca Blue/Black M Coupe | LK61201
    "I don't know the key to success, but the key to failure is trying to please everybody.."
    Jun 2008
    St. Louis, MO
    2009 e90 328i 6MT
    Quote Originally Posted by SunzOut View Post
    Ok so that's 6 names so far.
    I'll check with the shop and confirm pricing.
    I am interested as well. I am having the 2nd problem to which you linked; the "shifter not returning to neutral position from the 5th gate" problem.
    I am bound to need a clutch soon, and I was planing on fixing this problem when I pulled the transmission for the clutch replacement. How hard is it to do this fix with the transmission out (with your tools?)
    Tim
    2009 e90 328i 6MT
    Batavia, IL
    It's pretty much impossible to replace the pins without at least some of the drifts.
    You can get the caps back on with almost any "blunt object" of a suitable size, but the problem is the "sleeves" that you are installing need to be installed to a particular depth and take quite a bit of force to insert into the case. The 5th and reverse sleeves in particular are very thin but also a tight fit, the drifts have to very precise, the shoulder that the sleeve rests on is < 8 hundredths of an inch.
    Jun 2008
    St. Louis, MO
    2009 e90 328i 6MT
    I really have no idea how to do this fix. Does anyone have a link to a good how to on this particular repair? It would be greatly appreciated.
    Tim
    2009 e90 328i 6MT
    Batavia, IL
    Nov 2003
    MA
    98 Z3 2.8
    Put me down for a set. I need to do this repair soon.
    Joe
    Dec 2007
    hsv, al
    99 z3c
    Also interested in a set depending on final specs.
    Sep 2003
    Athens, GA
    2K M Roady, '86 944T
    I'll take a set as well.
    Rob - 2000 BMW Z3 M Roadster | 1986 Porsche 944 5.3L LM4
    nova scotia Canada
    02s54couperoadie04m316t
    I'll take a set too. Shipping will be more to Canada.
    NJ
    Care
    Interested!
    here & there
    01 LSB 367M
    Another set here.
    2001 S54 LSB/NAPA. 1 of 7.
    Boise, ID
    00 M Roadster
    Please put me down as a maybe also. Harder steel would be my preference.
    Batavia, IL
    looks good so far. I'll confirm pricing and see if there are any upgraded from mild steel.
    1 Vinci
    2 RoccinStrybs
    3 Brm
    4 Clintjg
    5 Coupe Monkey
    6 Petra
    7 Z3couper
    8 Wannaberockstar
    9 Jmai
    10 Greyish
    11 Robstah
    12 David runnalls
    13 Gnarlycreature
    14 Felonious monk
    Bay Area, Killa Kali
    2002 M Coupe, 2019 F31
    Definitely interested in a set.
    -2023 Honda Odyssey Elite
    -2019 F31 Individual (M-Sport, Prem, Exec, Track)
    -2004 Honda CRV
    -2002 S54 M Coupé
