Not alot was done today. My goal was to have the new engine and transmission bolted up together and sitting on the table. I'm about a couple of hours from that. I had to work on two other BMWs this morning before I started working on the engine.
I got new flywheel bolts, new intake and exhaust manifold gaskets from the parts dept. this morning.
Started bolting on the exhaust manifold/cats and route the wiring harness for the O2 sensors and EGT to their respective locations.
bolted up the intake throttle assembly.
Kinda hard to see but I installed the fuel injector rail and fuel injector harness (black)
Here's a shot of the pilot bearing which will be transfered. Its the one with the blue circle.
I forgot to take a picture of the bearing being removed with the special tool. Here's a picture of the BMW special tool thats to be used to press in the bearing.
Flywheel has been cleaned off and is ready to be torqued down. Notice the special tool being used to hold the flywheel in place.
Torquing down the flywheel at 105Nm
Installing clutch and pressure plate with BMW special tools. This is whats needed with these SAC units (Self-Adjusting Clutch)
Ok so I had everything ready for the engine to be on the front subframe.. but apprently I wasnt thinking and I noticed I couldnt lift the engine out of the wood crate with the throttle assembly in the way. This has to be removed so the chains wont get caught and break them.
So I removed the fuel rail, harness, and throttle assembly then placed the hooks on the holes.
Another view of the engine.
Covered up the intake ports. You can see the fuel injectors/rail on the upper right hand side.
Picture of the intake ports
Close up shot of intake ports/valves.
The new engine had silver color valves and the old one had like a gold color to them.
Picture of my work area.
Another View
whats being done to the engine?
Thanks jon. Looking forward on having you replace my engine when it blows.
nice job jon, now while the exhaust is out, u might as well put in an AA exhaust :
Damn right I will!
My e46 has about 40k on the clock...My clutch has started to chatter a bit. This really only happens when pulling away from a stop and not giving it quite enough gas. Anything I should worry about?
That looks like a very nice shop! So clean!
Thanks!
Colin
-Colin-
2002 M3
Imola red
I have the exact same problem at 47,000 miles. It's VERY annoying and I would also like to know if there's anything I can do and if it's covered by the warranty.Originally posted by cbloysM3
Thanks!
Colin
BTW: nice work!
cbloysM3 and srcstc-
I cant give you an accurate diagnosis of your complaints online if I cant hear the noise. However, this will be my guess but have a professional tech take a look at it.
Your guibo flex disc is going out - (warranty)
Your clutch is starting to go out as well. (I think if you have full maintenance its covered)
If you have a short shifter, you may want to remove it since they can always blame the noise complaint on that. It may also be the cause of th chatter/vibration.
Awesome Write-ups Jon!
That's a kick ass Torque Wrench, Do I have to graduate to get one?
Any thoughts on the Valves? I know that Ti Valves will have a characteristic Gold Tone to them, any other ideas?
thanks for the help Jon!
Colin
-Colin-
2002 M3
Imola red
