Page 14 of 14 FirstFirst ... 4567891011121314
Results 326 to 338 of 338
Thread: SMG tranny to manual?
  1. #326
    Dec 2012
    Belgium
    1993 325 conv
    Indeed, thank you for your answer. So if I want to use this pressure switch, I need to install a motor wiring loon from a manual car.
    What about the DME ? Is it possible to reflash it with the manual software and we are good to go ? Because I don't know if the MSS50 (manual version) and MSS50.1(smg version) use the inputs/outputs pins in the same way ..
    Or the only possibility is to use an other DME from manual car ?
    Thank you for the help !
  2. #327
    The Netherlands
    DE-spec E36 328i/M3 cab
    Wait, why are you converting?
    IG:
  3. #328
    Dec 2012
    Belgium
    1993 325 conv
    My SMG works fine but I would like to go back to the old driving style with a manual gearbox, feel more connected with the car.
  4. #329
    The Netherlands
    Zonde man! Zottekes amai!
    na seriously, it's a shame. I love shifting as well, but when I got my SMG, I was afraid I would miss clutching. Truth is, I didn't at all. Even surprised me. I think it's a very cool and unique system and when it works, it's a joy to drive.
    I don't know much about converting SMG's and if you can use the DME and stuff.
    IG:
  5. #330
    Mar 2010
    Australia
    E34 540i
    Guys, I have a question. My conversion is now complete and am totally in love with my car again, but since the conversion my climate control unit has been playing up. Meaning that sometimes i have control then some times i dont. Could my mechanic have shorted something or pulled on a wire that he shouldn't have?
  6. #331
    Feb 2016
    Southampton
    2002 BMW M3
    Just read this entire thread... wow, great job guys! Before starting a thread in the e46 section I thought I was bump this thread as the answer is most likely quite obvious. I have a 3.2 SMG from my RHD e46 M3 and I was wondering if it is essentially the same gearbox as the e36 SMG 6 speed? The conversion is identical with all the components matching. I am not too concerned about the electrics at this point as the gearbox is going into my other car which isn't a Bimmer.
  7. #332
    Jul 2013
    Norway
    2001 Bmw 520d
    Hi, I am currently converting my e36 m3 98 mod. from SMG to manual. But im not sure what to do with the Cruise control? The car was originally delivered with it. But how do i get it to work when i stop using the SMG system?
    There is no set up on the original wiring for the clutch switch..
    Regards
  8. #333
    The Netherlands
    Quote Originally Posted by Skulebollen View Post
    Regards
    Answered it yesterday on the other forum. Same answer applies to this forum.
    IG:
  9. #334
    Miami Beach,FL
    1989 325is,1998 M3
    Hi;Can you please post the link to the "other forum" ? Many thanks.
  10. #335
    KSA
    M3(S50B32)&(S54B32)
    Hi all
    Can someone please confirm what is in that shaft ?!
    Whan I removed the bell housings i foun 2 pin and 2 little bearing!
    '?? E92 ///M3 cooming soon
    '03 E46 ///M3 TiAg/ Black
    '99 E36 ///M3 Estoril Blue/ black
    '94 E36 318i RED/Black(history)
    Got my Gopro Camera www.halfany.com Vbox on the way...
  11. #336
    The Netherlands
    Bigger picture (more context) would help, but that looks like the selector shaft that is operated by the SMG gearbox actuator.
    IG:
  12. #337
    KSA
    M3(S50B32)&(S54B32)
    Quote Originally Posted by MParallel View Post
    Yes.
    I what come inside the 2 holes?
    I found 2 little bearing and 2 pins, is it right?!
  13. #338
    Nov 2022
    Szczecin, Poland
    1998 BMW M3 Cabrio
    Hey, I read all the threads, but I didn't find two answers. I have a bmw converted from smg to manual. Ever since I got it, I have a problem with slightly waving revolutions, I can't see it on the indicators, I just feel it. I have no power loss, the result on the dyno is perfect. I have no problem with the car turning off, I also don't have a gear and clutch indicator (PIN 19 and 80). Electric harness SMG, DME also SMG, DME SMG thrown. Instruments changed to manual. First question: what can cause the rev wave when changing to manual? The second is whether the lack of gear and clutch sensors can cause this. I changed soft DME to manual and nothing changed. And the last question, are pins 19 and 80 in DME SMG and Manual the same? Can I try to bridge these two pins?
