What determines how much torque to use on your lug nuts?
I'm getting new wheels and autox'n this year and want to make sure I use the correct force when checking them.
There is a standard guide depending on the size of the bolt. I torque mine no more than 90.
+1 on the 88ft/lbs
2008 Lexus LS460
2016 Lexus NX200t
PUREVIP
Island Elites - West Coast Elites
Team Airrex
ClubLexusHawaii
2002 540iA Sport (SOLD)
1998 M3/4 (SOLD)
Thanks...sounds like a plan.
FYI - today was taking off wheels to apply wheel wax on my sisters new 328ci. The security bolts were on so tight I almost could not get them off with a 1.5 foot bar. I would estimate I needed 140 ft-lbs to get them off. Some of the other bolts were so loose that it seemed 20 ft-lbs got them off. So I would check any new cars and asm. with some light coating of never sieze and 88 ft-lbs. I guess you can't trust the dealers.
Wheel bolt torque is actually 100 Nm or about 74 ft lbs. Wheel bolts should be clean and free of any type of lubricants including never seize.
I need a wheel http://forums.bimmerforums.com/forum...d.php?t=995867
Not 74, its 88. BMW changed their spec years ago.
Do your own research on anti-seize. I prefer it.
HPDE Instructor: BMWCCA / PCA / Apex
my tire installer confirmed the 88lb-ft setting when installing my wheels, not that I doubted the knowledgeable people there.
Current Car (delivered 20/10/21): 2021 G80 M3; 6MT; DravitGrau/Kyalami Orange/Black Extended Merino; Permium Pkg (ZPP); 826M bicolor wheels; Black M Compound brakes; Sunroof (yes no CF roof)
(more pictures here)
Previous Cars: 2018 F30 340ix 6MT Msport(Dec 2017 - Sep 2021); 2013 F30 335ix 6MT Msport (Nov 2013-17); 2011 e90 328i 6MT ZSP (Aug 10-Nov 13); 07 e90-323i ZSP (May 07 - Aug 10); 97-318ti ZSP (Feb 97 - May 07)
"Mit der Dummheit kämpfen Götter selbst vergebens", Friedrich von Schiller -- "Life is simple, people make it complicated", Me (About me)
Ditto on the 88ft/lbs, every manual i've read for my bmw said 88. I'll use anti-seize on bolts if they have a habit of corroding and sticking really bad, otherwise not. We did the same on customer's car/trucks when i used to work in a tire shop years ago.
2008 BMW 335I | Sport | Premium | Cold Weather | Logic7 | Black/Black
I use a blue torque stick for 17mm lugbolts and a gray one for E65s and X5s.
It's actually 88.5
I went back for re-torquing after driving around 50-60 miles, was that overkill? It was recommended by the wheel manufacturer.
Yeah I though it was a good idea to do that, but the tire installer mentioned that although they recommend it to their customers (they work on Porsche, Lexus, BMW and other high end cars) rarely does anyone ever come back. It only took 2 minutes and I could have done it myself if I had a torque wrench.
