It should work fine. I have twin 50 trims (larger turbo's) on my 2.4l Mitsu 4 banger and I get 30psi by 5500rpm in 3rd gear. Considering flow potential vs a similarly sized single, thats plenty fast.
My old whip did not see full boost till 6k, so this is a step up!
Project looks great-way to step out of the box.
93 Dodge Colt. 708whp
10.4@150mph Wrecked @ 200mph
90 Rx7. 860whp Stock Ls+boost
10.2@147 on mid boost pump gas
08 535ix. 12's@115mph
Thanks, appreciate it!
It is a bit goofy, but functionality is great. It does everything I need
M52 block/S52 Head (Cams)
On the way!
I know, the tires on them won't last long
It was not by choice, it just happened. I can't imagine the pulses being so far apart that it makes a pulsation in the rotation of the turbos.
Thanks, I like doing something different. Its much more fun figuring it out by yourself, rather than reading install directions from AA or something like that
Good to see another E30 M3 turbo project. Good luck with it all.
Not long now.......
The guy on the passenger side of the car needs a hair cut.
Sick project man! Lucas sent me the link and said i may like this...He was right!
he still hasn't got another job? Tell him to finish that corrado or get a real smart and get a real car.
I want a tv in my garage
I'd settle for 3 bimmers in my garage instead.
Spool time may suffer a tad, but thats still 1.4-1.6L per turbo (assuming a 2.8-3.2L), and they are small turbos too. The benifit is during boost, you don't have exhaust starting to vent on one cylinder while another is experiencing overlap, causing reversion. Turbo engines usually see 2-3x the pressure in the exhaust manifold as the intake, so during overlap you want to minimize any added backpressure if possible. This is why a larger AR divided housing makes more power and spools sooner than smaller undivided housing turbo.
Any updates?
Hey, just noticed this thread. Props on a very cool project.
I thought I saw a loud E30 driving the other day out of the corner of my eye
E
Oh noz it's for sale as of the middle of February! How come?! Did you ever finish this project?
I apologize for bringing this thread back from the dead but, what did you do in regards to the wastegates? I am doing a similar build on my e36 but I can't find info on the wastegate pressure or getting a second wastegate for the second turbo.
Sent from my SM-N920P using Tapatalk
