...is the difference between the two simply in the compressor housing? Which one would be best for ~7psi? And yes, I've searched, and read and read. So much so, I think my head is going to explode.
T3/T04E
COMPRESSOR SPECS:
flow: 53 lbs/min 678cfm
.60 A/R HOUSING
60 TRIM WHEEL
TURBINE SPECS:
.63 A/R HOUSING
STAGE 3 WHEEL
oil lubricated centersection.
supportable of 475whp!
T3/60-1
COMPRESSOR SPECS:T04S housing
flow: 61 lbs/min 781cfm
.70 A/R housing
60 TRIM wheel
TURBINE SPECS:T3
.63 A/R housing
HIGH FLOW 76 TRIM stg 3 wheel
for use with external wastegate.
COMES STANDARD WITH 360 DEGREE THRUST BEARING!!!
supportable of 575whp!
It always "depends" on what you want to do. Considering you chose to go with a .63 turbine you're probably looking for pretty good spoolup and moderate top end. I'd go with the E. I actually have a brand new one laying around in the box... I think it has the specs you want, but I'll have to check.
Boris
'96 Cosmos Black M3 422rwhp/407rwtq SAE @ 13psi / 444rwhp/444rwtq SAE @ 14.5psi
Engine/Drivetrain: Technique Tuning Stage 2 Turbo TT Turbo Exhaust, M50 Manifold, TMS Oil Baffles, SSR Comps, SPEC Stage II Clutch, UUC SSK, Titanium Cavallino Ti-130R Shift Knob, UUC TME, EMC Diff Bolt, RCCA's. Suspension: GC Coil-overs, GC RSMs, GC RTABs, GC Trans Mount; H&R SB. Instrumentation: VDO Boost, VDO Oil Press, VDO Oil Temp, VDO Water Temp, BMW Traffic Pro Navigation, Valentine One TODO: W/A Injection
Thanks for the reply Boris. Do both of these turbos fall into the category t3/t4 hybrid? It's the t3-60-1 that TT chose to use isn't it?
T4-60-1
Yes, but it's almost overkill for 7psi on a 3.0 with a .63 a/r housing. TT doesn't use a straight T3/60-1, it's a HiFi.Originally Posted by Capital
By the way, I just checked and what I have is a Garrett T3/T04E 60-Trim Turbo w/water housing. It has a 4-bolt .63 A/R garrett turbine housing w/Stage 3 wheel.
In all honesty it's perfect for your application. Plot 7-10psi w/your 3.0 on its compressor map and you'll see.
Boris
