that is a lot of usefull info there peeps. my 93 318is is doing the same thing....i thought it was normal....i just recently got the car like a month ago. well i guess i will have to see if i can fix this prob. when i got the car i tuned it up a little bit....spark plugs, oil, filters, a coule of breather hoses that were all messed up, the wires still look good so i didn't mess with those. i have a question though. do you have to run unleaded plus...or can you just run regular?
Question - if your sensor was bad, did your gauge show an incorrect reading? If it's my temp sensor...Originally Posted by zeit00
Dan
Any progress with this?
a32guy?
Also, is there a way to test if this could be the temperature sensor? Would disconnecting this sensor produce different results?
Dan
i have a few of these symptoms with my 95 325i w/ Sport Package. my idle gets a litlle weird every once in a while and im pretty sure my vanos is knocking. so if theres an easy fix out there please let me know lol.
1995 325i Sport. Stainless Steel brake lines. K&N drop in air filter. Racing Dynamics Front Strut Brace. Rear Strut Brace. Fan Delete. Interior Weight Reduction. Looking for springs/struts/sways.
1986 Toyota Corolla GT-S. Lots o Grip mods
1991 Kawasaki ZX600D. In about 800 pieces, complete rebuld.
Auto Tech in training.
so im one of the lucky ones to be having fun hunting down this problem....its driving my crazy...and to top it off more things pop up...at first the car only hessitated and missfired under load at low rpms same as everyone else around 2or 3k....also i have the wierd crusing idle problem but when i stop its gone...but now after changing plugs...coils....fuel filter...and other misc things my car seems to be smoking alot today...never noticed it before....but noticed it tonight since it was dark and rainy...so now this also has me worried...what u guys think???...also something that has me thinking is someones post about the temp sensor..and that fixing the problem...reason it has me thinking is cuz i recently changed water pump, hoses, thermostat, and the other day my car starting reading it was hot...so i am wondering is this could be the culprit of all my problems...i dont need to worry about the vanos due to my 325 being a 92....but this is driving me nuts!!!!..
No progess yet. Car is sitting outside, I'm at schoolOriginally Posted by dmurray14
My vanos did arrive. I will be going home this weekend. I will be replacing the o2 sensor first. If that doesn't work, coolant temp sensors. If that doesn't work and my buddy can come through with the cam tools, I'll swap the vanos units.
Keep your fingers crossed.
-Chris
Hmm im having this hesitation problem too. I'll be changing the O2 sensor here shortly since I have a check engine light for it. Hope this helps.
-Pang
06 Yamaha R1 SE
09 Nissan Armada
07 Acura RDX
00 S2000 605whp 419tq GT35R
*Wanted 335xi, White, coupe, 6spd**
I have a 99 323i and I notice that in cooler weather, the car runs amazing. But when it seems to be driven for awhile and in the hot weather (I live in FLorida) it seems to hesitate at take-off. Sometimes it's so bad it looks and feels like I don't know how to drive a stick. The problem clears when I hit around 3k RPM and everything is smooth. Sometime I have to take-off at around 2k RPM just to make it NOT stutter and shake. There are tons of usefule information in this thread, but damn, where do I start. I have already replaced the fuel filter recently so I guess I can just go down the list.
"My fellow Americans, I have not been entirely truthful with you. I did gagoogity that girl. I gaschmoigitied her gaflavidy with my googus, and I am sorry" -Quagmire
____________________________________________
ACS Shift Knob -+- ACS E-Brake Handle -+- ACS Floor Mat Kit -+- 18" CSL Wheels -+- Supersport 4-Way Adjustable Coilovers -+- Depos with: HID, Chromium Predator Angel Eyes, PNP and Stoneguard -+- Brembo slotted rotors -+- Hawk pads -+- Clear corners -+- Euro Tails -+- Alpine CDA-9827 -+- Boston Acoustic Pro 6.5 -+- Boston Acoustic RX-47 -+- Zapco 220 x 2 -+- JL Audio 500.1 -+- 2 x JL Audio 10" W6v2 -+- M3 Moldings w/ BMW Motorsport badges -+- More on the way...
damn am i happy guys...i now have no hesitation or detonation...no missfire!!!...now i dont know what did it but i did alot of stuff...so let me start...
new fuel filter
new plugs
2 new coils that seemed to be missifiring
o2 sensor
cleaned maff
cleaned icv
and crank sensor
i was able to do all that for about 150 bucks thanks to a friend working at a local parts shop specializing in bmw and mercedes...i spent all day wrenching but was it worth it...i never felt my 325 pull so nice...clean pull al trough rpm range...its lovely....now to fix my slipping clutch
cool! how did you know the coils were misfiring? and how did you clean the crank sensor and was the fuel filter hard? what plugs did you put in?
Thanks,
Dan
Dan
i didnt clean the crank sensor...i just got a new one...the plugs i used bosch 4's...and the fuel filter isnt horrible...your gonna spill a lil gas its impossible not to...best thing to do is take out the fuse for the fuel pump crank it a couple times and clear that last bit of gas...your gonna see it under your car on the drivers side....i pulled out the bottom hose first and pluged it...then the top and pulled it out the bottom...it actuallt only took about half an hour...not to bad at all...if u have a lil patiance youll get it...its just a tight spot...have fun if u get at it...thats what its about at the end...hope i could help...by the way the filters cheap too...about 10 bucks
wow, it's amazing how many people have the same problem. I have the same on my 93. I know that I have a head gasket leak, would that cause it? I was just given the car and haven't replaced much, or for that matter know what has been replaced in the past. Work in progress.
<a href="http://www.flickr.com/photos/chasemckenna333/65414748/" title="Photo Sharing"><img src="http://static.flickr.com/34/65414748_95391b2071_m.jpg" width="240" height="160" alt="Bmwinleaves" /></a>
chasemckenna333@yahoo.com
Well I've given up. Tomorrow the car goes into the dealership to be diagnosed. Hopefully they find it and its not a big waste of time and money.
Once they find it, I'll be replacing whatever is bad. I'll keep everone posted.
-Chris
I was having the same problem with hesistation between 2.5k and 3k on my 92 325is. After reading this thread, I changed the o2 sensor yesterday and the hesistation is gone. I highly recommend changing the sensor if it has not been changed in the last 30k.
BMW of Bridgeport took my car in, and after a morning of looking at it, they found out my first gear synchro is bad (no shit!) and they have figured it out that the plugs are wrong! Can you believe that?!
Me either. Dealerships suck. I took my car back, and have lost all hope in finding this problem. It seems my buddy's friend is never going to get these cam locks, so I'll probably never get this damn VANOS in. Sigh...
a32- Have you considered just switching the VANOS solenoids? That could also be the problem too - maybe the solenoid fails in a way that it hesitates when it should be opening quickly. Just a thought...
Dan
Dan
My problem is fixed!
It was a bad oxygen sensor. If you guys havent already, i would suggest switching out the oxygen sensor
Hope you guys solve your problems, i know how frustrating this whole thing was.
1992 BMW 325i
MODIFICATIONS
AA Chip
UUC System U v.2 exhaust
15'' Kicker Solobaric L7 running on 1200W JBL amp
Alpine CDA-9815
18x8.5 ADR M Sports
H&R Cup Kit
How old was your old O2? Did you have a check engine light?Originally Posted by YaYo325
Dan
i had the same exact problem with my car, and it turned out to be the gas cap.it wasn't allowing any air in, so it was straining the fuel pump, and actually ruined the fuel pump, but it runs perfect after a new cap..
my car was doing the same but has stopped now, thank god. i just reved the car over and over again, it began to back fire and then all of a sudden a huge bang, that was about 6 months ago no probelms since.
Problem solved!!!
Yes you heard right. Tonight I replaced my VANOS control unit, and the problem is GONE. It drives like a totally different car now. Throttle response is better, tons more torque right off idle, and pulls soo smooth right up to rev limit. It even sounds more aggressive under the bonnet.
The job wasn't bad at all. I ventured to do it without any specialty tools at all, and didn't have a single problem. I was extremely careful not to let anything turn, and kept my eye on the TDC marker and crank pulley.
Halfway there
Old vs. "New"
So next on my list is an o2 sensor. This should help milage some. Now that the car is healty, I can start modding
Now I just have to figure out why my non digital climate controls don't work
-Chris
How long did it take you? I am going to have mine apart all winter and am thinking about adding that to the list.Originally Posted by a32guy
WOW!! This is awesome! Is this an easy DIY? Any chance you could do a write up? What tools did you need? Did you follow the Pelican DIY, or something else? I'd LOVE to try this if it's not going to be too hard!
Thanks again for figuring this out!
Dan
Dan
Guys I was one of the first posts on this thread and suggested it's a vanos actuation problem.. and nobody considered it at all and now what happens... sheesh!
Actually it was your post that inspired me to buy a unit, and install it.Originally Posted by M52 POWER!
The install wasn't hard at all, just more intiminating (sp?) than anything else. I didn't use any special tools but I had to be very careful not to lose timing.
I have to run now but can make a quick writeup later. Hope this helps!
-Chris
