Page 13 of 103 FirstFirst ... 345678910111213141516171819202122233863 ... LastLast
Results 301 to 325 of 2555
Thread: The OFFICIAL bogging, hesitating, no acceleration from idle thread
  1. #301
    Mar 2005
    CT
    E36, WRX
    Quote Originally Posted by 318is4life
    im new to this so whats VANOS?
    Please search, theres about 5 million threads about what vanos is.
  2. #302
    Newbury park, Ca
    BMW 335d, MB gl 350cdi
    I just got the exhaust air pressure tester from pelican parts to test out the exhaust flow pressure through the cats. It was $30, and in fact the pressure is elevated, so a used set of OBD2 cats and O2 sensors are on the way. I definitely think your problem (and mine as well,) is the cats: our old ceramic matrix is simply not made to last more than 10yrs/100k miles. Do you notice how this problem almost never happens on the 328s?
    I'll post the results in a few days.
  3. #303
    Jun 2005
    St Paul, Minnesota
    '02 330i, '07 SV650N
    I'm still failing to understand how the cats could cause this...
  4. #304
    Jun 2004
    bmw
    325i
    Quote Originally Posted by Spood
    im with him i believe its something with fuel delivery
  5. #305
    Mar 2005
    CT
    E36, WRX
    I think it could be a combination of both, but am leaning towards cats. How elevated was the pressure? Great results, please keep us all posted! This is the only thread that keeps me coming back to bimmerforums.
  6. #306
    Jun 2005
    St Paul, Minnesota
    I'm not saying it couldn't be the cats, but I haven't heard and solid logic to explain the idea.
  7. #307
    Mar 2004
    South Jersey
    2013 M3, 1993 325is
    Quote Originally Posted by calves2997
    Very interesting. How "elevated" was it? Also, how do you plan on making the OBDII cats fit in with the OBDI headers?
    Dan
    Dan
  8. #308
    Nov 2005
    NYC
    sneakers
    what would happen with a test pipe in an obd1 car...even if you made new spots for the o2 sensors? I have a bogging problem, but have had cars with race cats aka straight nice replacement, that ran awesome. would the o2 sensor freak out and make things worse in our cars?
  9. #309
    Florida, Earth
    1993 325is
    I'm not sure that the cat being the culprit is making sense.. like sdotlalond said
    What exactly does the clamping of the return line do? just raise the pressure of the fuel supply? will this cause the motor to run rich or will the computer lower the fuel mix automatically? if it does run rich does that cause other problems?
    Do any of you have check engine lights?
    I have 1262 Idle Speed Control This shows up if the idle speed actuator shows a ground fault, or if the car stalls from an idle above 600 RPM.
    not sure if thats a related problem or not..
    similar to alot of your symptoms, mine idles fine when its cold and first starts. does so until it warms up (maybe like 1/4 of the temp gauge) from the left
    then it starts revving up and down anywhere from 600-1500 rpm. it seems to vary every time. It may even start at a small fluctuation then get larger as the engine gets warmer. I was thinking it was my ICV like the code said but now I'm thinking that may be a different problem altogether, or else the computer is just confused. Similar again I'm getting the bogging or hesitating thing at 3k rpm when accelerating quickly, as if I were taking my foot off the pedal then going back on really fast. Seems only to happen when the motor is warm again, and it does fine when its cold.. called the dealer today and its $100/hr for diagnostics, they dont know how long it takes to diagnose..
  10. #310
    Jan 2006
    dermott, arkansas
    1997 bmw 328i convert.
    like i said before, i'm not a career mechanic,
    but i do understand the logic of systems.
    reading all of this leads me to this conclusion; if it is a post combustion problem, then it must be a feedback issue with precombustion. in other words, something postcombustion is telling precombustion [or combustion] to fuck up somewhere.
    i say this because the known direct postcombustion problems have been addressed. thus, maybe there's a funky feedback loop in the pre-combustion area?
    i sure hope ya'll figure this shit out. i, for one, am not capable.
    oh yeah; i just took up golf too.
    cheers,
    sv-
    sidvicious
    97 BMW 328i Convertable [My first BMW]
    60k miles
    Automatic
    99 New Beetle TDI
    Blown engine [through negligence]
    Under self repair [oh hell!]
    2004 Toyota Sequoia
    2003 Buick Rendezvous
  11. #311
    Mar 2004
    South Jersey
    2013 M3, 1993 325is
    Honestly, no one knows for certain right now. No reason to go shooting down people's ideas if we haven't tried it first. The quickest answer would probably be to take our cars to the dealer, but that's not what we're doing, we're experimenting. So let's give each idea a thought and not cross it off right away...
    Sidvicious - I'm hesitant to think that the computer KNOWS about whatever is causing this issue, as I think it would cause a major CEL if it was something it could monitor. Instead, I think it's something the computer can't (or for some reason isn't able to) monitor.
    Prophecy - I think you need to clean your ICV. Sounds like that's it for you...
    Dan
    Dan
  12. #312
    Mar 2005
    CT
    E36, WRX
    I took video too dan, but I can't find my damn firewire cable!
  13. #313
    Dec 2004
    Perth, Australia
    96 323i, 94 318i
    Quote Originally Posted by dmurray14
    Nope- I think all of our problems are related to engine temperature, not ambient...
    Mine (and a few others on this thread) is strictly ambient temperature, or as I said earlier engine bay temperature not engine temperature.
    For example sit in traffic (in cool weather) engine bay heats up, it bogs down. Drive for a couple of minutes and (whatever it is) cools down and everything is fine again.
  14. #314
    Jan 2006
    dermott, arkansas
    dmurray
    i'm with you on the computer thing. what i mean is, from the totality of what i've read, the fault seems to be on the intake or combustion side.
    if it is a computer feedback loop problem, then the problem could be that the computer is sending the incorrect readings back into the intake/combustion system.
    the engine temperature variance seems to confirm this. when the engine is warmer the intake air is warmer, etc.
    it reminds me of the old "high" altitude days with carburators. if the intake jets weren't adjusted, when the car warmed you wouldn't move.
    i'm sortof like a parrot here, mostly repeating what i've heard. but i do listen well. too, i remember flipping the breather cover on many a colorado rental car to get more air into the system, and it did work.
    it seems to me that something is leading the system to conclude that too much 02 is in the front end of the system. thus, the sluggish and erratic burn.
    everyone seems to have done all the timing and spark plug stuff. this is hardware. software, however, is much more creepy and full of gremlins.
    on the other hand, something in the hardware could be forcing the software to an inappropriate conclusion.
    i know a couple of experts. i'll ask around and see what i can come up with.
    sidvicious
    60k miles
    Automatic
    99 New Beetle TDI
    2004 Toyota Sequoia
  15. #315
    Oklahoma City, Oklahoma
    98 M3 S52, 95 318i conv
    In relation to fuel pressure and injection requirements, I ordered a new fuel pressure regulator to see if maybe I am running lean in the rail. It came in today and when I went to install it the darndest thing happened........the original one is not there. There is not a place for it on the rail nor anywhere else. I have an exploded diagram and it just is not there. So, does anyone know why some would have one on the rail and some not? Also if not on the rail, where the h l is it? 95 E36 Auto
    Jerry
    95' 325i
  16. #316
    Brentwood, CA
    1992 325i e36 ~ 1985 318i ~ 1995 Audi A6 Quattro
    Very interesting...I know I have been an annoyance and maybe my lack of posts has led me to the 'Dunce' chair but I have heard three other people say the same thing...one guy I believe even on this thread made mention that he called a BMW recycler and they said all of them were "missing"...very peculiar. At the same time another gentleman on Pelican talked to different service techs and two said it didn't have one...BMW said it did but that it wasnt shown in the parts schematic of his service program....and somehow knowone is able to locate it??? Is this part of the technology to incorporate the check valve in the intake line to be pumped out on the return line? Not experinced with FI systems or anything for that matter related to this problem - all I know is I am buying a .99 cent for sale sign and buying an M3, hopefully I will not have the same problem with it
  17. #317
    Jun 2005
    St Paul, Minnesota
    Quote Originally Posted by jperry58
    According to the Bentley, on 92-95 6cyl cars, it should be on the fuel rail. On 96+ cars, it should be underneath the car. Dunno if that helps at all. Just a thought, but maybe it's either a misprint or yours was manufactured late in 95 and it is under the car. If it is under the car, it will be under a protective cover on the left side.
  18. #318
    Jan 2006
    Georgia
    The Bentley manual says it could be in two places. Either on the fuel rail or under the car. The picture looks like it is next to the fuel filter under the car, driver's side. There is supposed to be a cover over it, about under the driver's seat that contains the filter and regulator.
    1995 325I, tinted windows, K&N, debaffled airbox, Nighthawk low beams, BMW style #104 wheels, smoked corners, smoked sidemarkers, smoked taillights, M3 style heated mirrors, various interior bits, Bosal cat-back.
  19. #319
    Jun 2005
    St Paul, Minnesota
    Ha! Beat you to it! ^^
  20. #320
    Mar 2005
    CT
    E36, WRX
    this thread has crazy amounts of info in it. I'm just waiting for the person to cure their hesitation. I'll try clamping the return line when I get home this weekend.
  21. #321
    Jan 2006
    Dorset, UK
    BMW E36 320i
    murray14
    Ill be checking my CAt's at the weekend and if i suspect they are faulty ill be taking them out
    prophecy
    <!-- / message --> Your pronblem sounds very similar to what my engine does im going to try cleaning my ICV this weekend too and see if it makes much diffrence
    <!-- controls -->
  22. #322
    Jan 2006
    Georgia
    Yep, you win this round
  23. #323
    Florida, Earth
    1993 325is
    Dan
    its definitely not it. I cleaned it throughly when it was all apart during the HG job. I even reached under the intake and took it out the other day to inspect. still clean. so maybe the unit has somehow gone bad and is throwing the code.. i think i may have a combination of problems here, with the same symptoms you all seem to be having
    Oh and another thing I found out.. After doing a compression test lastnight I put it backtogether and started it up.. I then turned the headlights on for some more light. I noticed a small decrease in RPM. I thought that was strange, so I turned the headlights off. RPM's go back up. I mess around with this for a little while and the RPM's fluctuate with the headlights being on or off. It was cold out and the motor still hadn't heated up. It was still below 1/4 on the temp gauge. The idle was normal. Then I turned the lights on again (i'm pretty sure it was on, but could have been off) and it induced a premature surging idling (since the engine was still cold and it only ever happens after it warms up). Turned the lights off (or vise versa) and it went back to normal idle. I continued to do this for a few minutes until the motor warmed up and it was surging no matter what position the lightswitch was in.
    This seems very bizarre? an electrical problem ?
  24. #324
    Mar 2004
    South Jersey
    2013 M3, 1993 325is
    Quote Originally Posted by prophecy
    An alternator problem. I have the same thing. Know how I know? My PS pump squeels like a little shit sometimes, and when I turn on the headlights, the tone of the squeel really changes. Of course, you can see the change in RPMs too. Don't know if this would relate to our problems, though I guess it could if the alternator was seizing up? I woudl think the belts would be getting worn though, but who knows...
    Quote Originally Posted by Tim Poole
    murray14
    prophecy
    <!-- controls -->
    OK, great. Very interested to see what the cats do.
    Quote Originally Posted by sidvicious
    dmurray
    Yep. I don't know whether it's a sensor or what, but I'm convinced that the ECU doesn't think it's doing anything wrong, though it should be. Maybe we have a sensor that's on the verge of going, but not bad enough to trigger a warning...
    Quote Originally Posted by shortly99
    I can't be 100% certain, but I'm fairly sure mine is engine-temp related. When the needle just about hits 12 o'clock, that's about when it starts to run like crap. I guess it could be engine bay temp too (assuming the temperatures rise similarly), but I still have a gut feeling mine's engine-temp related. I also don't think mine recovers after driving down the freeway for example, but I'm not sure as I haven't been on it for a while.
    Just an idea, but maybe we could make a list of sensors/parts that we suspect, and have people each try one or two? This way we can all minimize our losses...
    Also proposing a "my car doesn't suck anymore" party when/if this is all figured out
    Dan
    Dan
  25. #325
    Santa Rosa , CA
    '92 BMW 325is Coupe
    There is a technical bullitin for the E36 but dont recall the exact years or models, but there is a issue with the DME programming and required a "patch" be installed to fix this issue. Ill try to look into it
