Page 5 of 5 FirstFirst 12345
Results 101 to 107 of 107
Thread: Window Regulator And Motor Replacement DIY.
  1. #101
    NJ
    1993 318is, 2000 323i wa
    Does anyone know if the Magnet repair works on a 1994 318is window motor? I see that the 1993 has a removable "door" that exposes the magnet on the shaft but the 1994 motor doesn't have this door and from all the pics i've seen including inspection of my window motor does not reveal where exactly this magnet is. Thanks for any insight.
  2. #102
    NJ
    Pic of drivers side 1994 318is window motor.
    Thanks for any help repairing the "inching" problem on this motor.
  3. #103
    Jul 2019
    The 9, ON, CA
    2008 BMW M3 Coupe
    Bumping this thread to save anyone doing this repair tons of time, effort and frustration when attempting to pop the regulator into the plastic sliders. Use a 6" C-clamp locking pliers. Job done.
  4. #104
    Sep 2004
    Texas
    E36 318iC 6mt vert
    Quote Originally Posted by TiAgM3 View Post
    Thanks for the tip! Will channel locks work as well?
  5. #105
    Sep 2004
    Texas
    E36 318iC 6mt vert
    Completed this task yesterday. It went well thanks to the OP and subsequent additional info. Thanks to all.
    I bought a new regulator and motor. I think my issue was probably a bound up window in the vertical window tracks because when I disconnected the regulator from the plastic slider clips, the window stayed up. It took a good bit of force to get the window to slide up and down so I sprayed the rear track with PB Blaster and that got things loosened up so it moved more freely.
    I ended up using the original regulator as it was of better quality than the new one and was functioning properly. I had to use the new motor as I had to turn in the original motor as a core. So I don't know if the original motor would have worked once everything was freed up.
    One thing I thought I would pass along from my experience:
    The only issue I had was when reinstalling the regulator assembly, I decided to test it out before clipping in the window sliders. When I did this it would go all the way down but not all the way up. After a couple of attempts, I decided to CLOSE THE DOOR before attempting to raise and lower the regulator. Voila...it worked perfectly!
    So make sure you close the door before operating the regulator.
    Thanks again to all!!!
  6. #106
    Apr 2019
    New Jersey
    1993 325 i
    widge behind bolt
    The bolt to adjust has widge behind it,losen it lightly move the bolt toward rear of car lighty,now raise the window all the up.make sure it postion correctly NOW bring the bolt toward the front of car make surr it postion in the slot not past it now tighten then set the memory .it should work fine .the problem usally is how the bolt is set,
  7. #107
    Mar 2012
    Philadelphia, PA
    1995 BMW 540i
    I'm rebuilding window motor on a E34 540i. does anyone know how to take of the end cap od the motor?
    2. what grease to use on bearing, never seen a bear like this before. and same grease for regulator? I was thinking Mobil Polyrex EM.
