Bimmerforums Upgrade Garage The Tire Rack
Page 3 of 156 FirstFirst 123456789101112132853103 ... LastLast
Results 51 to 75 of 3880
Thread: PLEASE READ BEFORE POST: The ultimate wheel/tire fitment thread.
  1. #51
    Apr 2003
    San Diego, CA
    1995 M3
    I am looking to buy a new set of track wheels for my 1995 M3, Kosei Racing K1 in 17x8.5 and was wondering if I can fit a 255/40 Toyo RA-1 on that rim and not have rubbing issues. It is a dedicated track car and I run about -2.8deg camber front and -2.4deg camber rear. Some fender rolling is not a problem to do if necessary or a spacer.
    255/40 possible? or should i go with the 235/40 Toyo RA-1 instead?
    - e
  2. #52
    Aug 2002
    South Bend, Indiana
    BMW 525I
    I think you can make it work. You would not be the first person to run the 255/40R17 all the way around on the E36.
    If I can help let me know.
    If ordering through the web site click through one of the banners and list "Jim" as a previous contact. The Tire Rack will direct a portion of the proceeds back to the the Bimmerforums.com site.
    Tire & Wheel Forum sponsored by The Tire Rack
  3. #53
    Nov 2003
    WA/YVR
    M CPE
    Hi I am glad I found this thread! I have asked a few local tire shops and gotten a different answer from each. This is my setup right now:
    Wheels: 17x8 Racing Dynamics
    Suspension: Koni Shocks with Eibach Springs
    Car: 1995 M3
    Now the other day I had a flat, no big deal except the thing is I don't want to buy a new tire to replace the flat one. I've been looking around for used tires and have picked up a couple tires that shops have just given me for free and they have about 50% tread on them!
    Currently on my car I have 225/45/zr17 Bridgestone Potenza S-02's. So I was thinking of running two of those on the back, and on the front run the two tires I picked up for free which were:
    2 Dunlop SP Sport FM 901's 215/25/r17
    Would this work out ok?
    To sum it up, on a 17x8 rim:
    Front: Dunlop SP Sport FM 901 215/45/r17
    Back: Bridgestone Potenza S-02 225/45/zr17
    Thanks!
  4. #54
    Maryland
    1991 318is x 2
    heres the setup im planning on running
    wheels:16x7.5 borbet type e +35mm offset 10mm spacers
    suspension:http://www.bmpdesign.com/product-exe...category_id/53
    car:1986 325e
    what is the widest tire size i can run without rolling the fenders or having rubbing problems. id like to have a 215/50/16
  5. #55
    Aug 2002
    South Bend, Indiana
    BMW 525I
    Jotti, I would not recommend the set up you are taliking about. You would have a shorter tire on the front and a lower performance tire on the front as well. Handling would not be the greatest.
  6. #56
    Nov 2003
    WA/YVR
    M CPE
    Quote Originally Posted by Jim@tirerack
    Uh-oh.
    Too late...
  7. #57
    Fairfax Station, VA
    10 335d
    17x8 & 17x9 on an e30 M3
    Just picked these up. Will these fit on the e30 m3?
    BBS RX's
    2 - 17x8 et38 w/ 215/40-17 Yokohama AV1-40i
    2 - 17x9 et32 w/ 235/40-17 Yokohama AVS
    They came w/ 2 10mm spacers and bolts
    Thanks,
    Ian
  8. #58
    Aug 2002
    South Bend, Indiana
    BMW 525I
    I would say you would need spacers front and rear with this set up. You also may have to roll the fender lips and run a little more negative camber.
  9. #59
    outer banks nc
    97 328is
    offset question for Jim
    Hi, I just received a set of type 42, 16x7s, et46. Currently I am running Milles, I believe et38. What problems, if any, will I run into. Car has eibach Pro Kit, Koni SAs, about to install Korman camber bolts. Many Thanks!
  10. #60
    Seattle
    94 540i
    I just picked up a e34 (94 540i). What's the widest tires I can get on a 18" wheel?
  11. #61
    Seattle
    94 540i
    Tirerack website is recommending:
    Front 235/40-18
    Rear 265/35-18
    Does that sound right?
  12. #62
    Aug 2002
    South Bend, Indiana
    BMW 525I
    Those are the widest that will fit and not rub. You can go to the 245/40R18 and 275/35R18 if you roll the fender lips and run more negative camber.
  13. #63
    Sep 2004
    va
    no more e36 m3; 98 Altima now
    1999 E39 540 w/M-sport lowered suspension
    Can I fit a 19x10 in the rear w/19 offset?
    What would be proper tire size, 265/30/19?
    98 Nissan Altima 14.3@94mph
  14. #64
    Aug 2002
    South Bend, Indiana
    BMW 525I
    I would say with that width and offset you are going to have to roll the fender lip to make it work. The tire size would be 275/30R19 for the rear.
  15. #65
    NY
    528 Sportwagon; Miata
    I have a 2000 528 Sportwagon with the OEM 17"BBS wheels.
    I am looking at a set of 18x9 ASA AR1's with P Zero Nero M+S in 245/40-18 front, as recommended on TR's site, but I wanted to go with 275/35-18 at the rear (currently out of stock). Right now, I'm just haven't decided if I'm going to wait for the 275's or go with 265/35-18 at the rear, which are a bit smaller in diameter. I have 2 questions
    1- is a 275/35 too much for the 9" wide wheels?
    2- how can I find out the depth of the lip on the AR1's for this application? (I dont' want to give up the "deep dish" look of the OEM wheels )
  16. #66
    Aug 2002
    South Bend, Indiana
    BMW 525I
    I would stay with the 235/40R18 and 265/35R18. The 275 on the rear does require a fender lip roll.
    IfI can help let me know.
  17. #67
    NY
    Why 235? Your site suggests 245/40-18 with those wheels.
    Also, how can I find out the depth of the lip on the 18x9 ASA AR1 wheels for this application? (as I said, I don't want to give up the "deep dish" look of the OEM 17" BBS wheels)
    Thank you.
  18. #68
    Aug 2002
    South Bend, Indiana
    BMW 525I
    If you want to stagger them I would do the 235/40R18 and the 265/35R18. These are the same height front and rear. If you run the same size all the way around the 245/40R18 works fine. You can also run the 245/40R18 with the 275/35R18 but you will need to roll the fender lips.
  19. #69
    Jun 2004
    Lafayette, California
    E36 325is Bmw
    ok i want 235/40/17 for my m contours. and i want to buy some Fuzions. i hear they run narrower. should i buy 245/40/17???
  20. #70
    Sep 2004
    va
    Can I fit a 275/30/19 on a 9" wide rim?
  21. #71
    Daouwn Saouwth
    POS
    What's the widest I can go in the front with 18x8 ET33 on a 97 328is? What about in the rear on the same 18x8 ET33?
    Sunny Skies
  22. #72
    Mar 2005
    Philly
    '97 528I
    I have a '97 528 with H&R springs and Bilstein shocks and struts. I'm thinking of getting some 18x8 wheels all around and was wondering what size tires would work best for my car. I'm considering going with staggered tires but I'm not sure what sizes to go with without loosing any handling. Or should I just go with the same tire all around? Any feedback would be greatly appreciated.
    Thanks.
    Angel
  23. #73
    Philadelphia, PA
    (3) 325i, 325xi, 330xi
    18"s
    Hello...I have a qustion on wheel and tire size. I have a 1993 325i sedan riding at stock height. I would like to get an 18" wheel. On tirerack.com i was looking at the mille miglia ev-R. This size only comes in 18x8 and 18x9R. I am wondering what all will be involved in getting the 18x8 all aroudn on my car...what tire size, and will anything rub. And which offset? I was suggested a 215/35/18...but that seems a little thin. Also, how much is involved to getting those 9" wide wheels on the back of my e36? Thanks a lot...and if there is a lot of work on 18"s, if i get a 17" with a low profile the same tire diam. as the stock 15"s? Thanks!
  24. #74
    Mar 2005
    Northern Virginia
    1988 325iX. 2001 325Xi SportWagon. 1987 Ford F-150
    Wheel Options for E30 325iX
    Hey Jim,
    I'm doing my homework before purchasing wheels and tires for my iX, it's nice to "know" someone inside Tirerack, thanks for doing this. I bought tires for the wife's car from you guys and it worked out great.
    My iX is slightly lowered, which really only makes it a tad lower than an E30 iS. I have 15" snow tires, so I'm looking for 16" wheels/tires that will be for good weather only. I hope to do some Autox and driving schools with it.
    I love the E36 M-Contour wheel, and have looked around for a replica that would fit but have had no luck. My next favorite is the BBS cross-spoke style. You guys show 3 styles that will fit:
    BBS RC $323 et35 16.4 lbs
    BBS RX $247 et35 20.8lbs
    ASA AR1 $159 et38 17.6lbs
    I don't know how much my stock wheel weighs (it's the 15x7 4x100 et41 BBS cross-spoke) and how much of a difference lighter wheels will make. I know unsprung weight is important, but how much so?
    Also, my stock offset is 41 but it might be cool to push them out a tad as long as that won't affect my geometry too much or cause rubbing. The et35 will push the wheel edge out 6mm from stock, right? Can I go more without having problems? The iX has a fender flare that the iS doesn't have, so they have some room before they would actually protrude from the side of the car.
    The recommended tire size is 205/60 with the 16" wheels, but could I go with a 225? The RC is 7.5" and the others are 7", what's the advantage of the extra wheel width?
    I know this is a ton of questions, I appreciate your taking the time to assist me and I'll definitely call you when I pull the trigger on this.
    Rob
  25. #75
    Jul 2004
    Wisconsin
    94' BMW 325i, 96' Chev. Beretta
    Alright, I'm thinking of gettting some 17x8s. What would be the recommended tire size? I'm thinking of tracking it every one in a while. I also don't want too harsh of a ride, am thinking of getting aftermarket suspension, but am currently stock.
    Cardomain
    upcoming mods:
    (ordered) Cosmos CAI
    (summer project) aftermarket bumpers + painted bumpers/skirts
