Hi there,
I've scanned my E60 and have a slew of codes -- not sure what they mean, and what the fixes should be.
SIM/SGM module:
93CC Airbag sensor, B-pillar, left (Y-direction)
93CD Airbag sensor, B-pillar, right (Y-direction)
I'm assuming these have to do with my passenger restraint malfunction (and light) that I need to fix.
DME/DDE:
299B - IBS Sensor
27A0
281E Variable Air Intake: Activation
2774 - Engine cutoff time
AFS: -- these are weird because I don't have any active steering lights on
6140 Motor position angle not initialised (active steering)
6145 6145 No monitoring of angle sum relation
614A
CE93
DSC:
5F12 Front axle brake pads (i think I fixed this already)
5F13 Rear axle brake pads --- these won't reset -- even after a new sensor. Any thoughts?
5F62
DWA:
9D00 Communication fault with siren / DWA bus
KLIMA:
E714
9C54 - Battery voltage?
SBSR:
95BA Seat occupancy detector, passenger: not released -- what does it mean as "not released"?
Is there a resource I can look at that explains these fault codes/fixes?
Ok you've pulled the codes and recorded them. Now you need to clear all the codes and drive the car for a day or two and pull the codes again. Problem is you don't know what is a active code or a code hanging around for a period of time. BMW is great about capturing information. However in your case as a new owner you don't know when the system was last cleared to obtain a currant picture.
Here's a in depth roster of BMW codes: http://www.bimmerfest.com/forums/att...hmentid=402436
